Thread Closed
Force and Friction on an Inclined Plane
Share Thread Thread Tools
Apr15-04, 05:58 PM   #1
This question is driving me insane please help.
A 25 kg block of ice slides down an incline 2.5 m long and 1.5 m high. A man pushes up the ice parallel to the incline so it slides down at a constant speed. The coefficient of friction between the ice and incline is 0.10. Find the force exerted by the man.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Apr15-04, 06:15 PM   #2
Mentor
Quote by wikidrox
Sliding at constant speed implies equilibrium: the forces in any direction add to zero.
Start by identifying all the forces on the block of ice. I count four.
May12-05, 02:13 AM   #3
ok I have the same problem.
The four forces I have found are:
Fg = 147.1N (directly down)
FN = 195.9N (perpendicular to the slope)
Ff = 19.6N (up parallel the slope)
F = 147.1N (down parallel the slope)
just want to make sure here..
now I add the 4 vectors together and find out what Force I need to add (up parallel to the slope) in order to make the net force = 0
thanks
May12-05, 02:53 AM   #4
Quote by bullroar_86
First, you have to draw your "free body diagram". (Did you do that bullroar?)
There are trig functions that should be applied here because the block is at an incline of [tex]\theta[/tex].
Once you draw it, you should have something like::
[tex] \Sigma F_{x} = F_{g}\sin\theta + F_{push} + f_{k} = ma[/tex]
[tex] \Sigma F_{y} = n - F_{g}\cos\theta = 0[/tex]
May12-05, 08:23 AM   #5
Mentor
Not sure where you are getting these numbers. The four forces are:
(1) weight = mg, acting down. This will have components perpendicular and parallel to the incline. If you call the angle that the incline makes with the horizontal [itex]\theta[/itex], then [itex]W_{parallel} = mg \sin \theta[/itex] down the incline and [itex]W_{perpendicular} = mg \cos \theta[/itex] into the incline.
(2) normal force, N, which is the reaction to the forces pulling the block against the incline. [itex]N = mg \cos \theta[/itex], acting out of the plane. (This comes from setting the net force perpendicular to the plane equal to zero.)
(3) friction force = [itex]\mu N = \mu mg \cos \theta[/itex] acting up the plane.
(4) the applied force F that acts up the incline.
To find the applied force, do as PhysicsinCalifornia advised: set the net force parallel to the plane equal to zero: [itex]mg \sin \theta - \mu mg \cos \theta - F = 0[/itex].
Thread Closed
Thread Tools
Similar Threads for: Force and Friction on an Inclined Plane
Thread Forum Replies
Friction on an inclined plane Introductory Physics Homework 2
Friction, inclined plane. Introductory Physics Homework 0
Friction on an inclined plane Introductory Physics Homework 5
friction of an inclined plane? Introductory Physics Homework 2
