| Thread Closed |
pn junction diode |
Share Thread |
| Jan14-08, 04:32 AM | #1 |
pn junction diode
Say we have a silcon pn junction (diode) - i.e., a block of p-type on
left, attached to a block of n-type semiconductor on right: anode ------[ p | n ]------ cathode Because of diffusion we get a barrier potention at the junction, which makes the n-side/cathode 0.7V higher than the p-side/anode: ~~~~~~~~ - 0.7V + anode ------[ p | n ]------ cathode (*) 1) Now is there any way to "measure" this potential difference right from the diode using some instrument? Now to get ride of the depletion layer (barrier) we need an "opposite" external voltage equal in magnitude to the 0.7V shown in (*) : ~~~~~~~ (barrier potential) ~~~~~~~ - 0.7V + anode ------[ p | n ]------ cathode ~~~~~~~ + 0.7V - ~~~~~~~ (external voltage) 2) Now, why isn't the resulting voltage of the diode 0V (sum of barrier and external)? How come we only measure the external 0.7V using a voltmeter when the diode is forward biased? 3) Is there anything wrong with the thought process I've outlined above? |
| Jan14-08, 08:27 AM | #2 |
The instrument to measure is a voltmeter, or for more accurate results you can use a scope (only when the diode is on).
Correction: Because of diffusion the electron-hole paris recombine and a depletion layer is formed. To overcome this depletion layer an external potential (generally 0.7V for Silicon) is needed, hence you measure 0.7V and not 0V. Once the depletion layer is formed it prevents the further recombination of holes and electrons. |
| Jan14-08, 08:29 PM | #3 |
| Thread Closed |
Similar discussions for: pn junction diode
| Junction area of diode | Introductory Physics Homework | 1 | ||
| PN junction diode | Electrical Engineering | 12 | ||
| PN Junction Diode | Electrical Engineering | 16 | ||
| Junction area of a diode | Electrical Engineering | 1 | ||
| pn junction problem in diode | Electrical Engineering | 1 | ||
