Finding freq., Wavelentgh, Phase Velocity, and attenuation constant
The discussion revolves around a wave equation given in the form of \( v(z, t) = 5 e^{-\alpha z} \sin(4\pi \times 10^9 t - 20\pi z) \). Participants are tasked with finding the frequency, wavelength, phase velocity, and attenuation constant based on this equation.
  • Mixed
  • Participants explore the relationships between wave parameters such as frequency, wavelength, and phase velocity using the provided wave equation. There are attempts to derive the attenuation constant from the amplitude at a specific distance.
Some participants have offered insights into the interpretation of the attenuation constant and its dependence on the wave's amplitude. Questions have been raised regarding the elimination of time from the calculations and the role of the sine term in the context of the amplitude.
Participants are navigating the implications of the wave equation's terms and their physical meanings, particularly in relation to the amplitude and its decay over distance. There is an ongoing examination of how different components of the equation interact with each other.
VinnyCee
Given...
[tex]v\left(z,\,t\right)\,=\,5\,e^{-\alpha\,z}\,sin\left(4\pi\,\times\,10^9\,t\,-\,20\pi\,z\right)[/tex]
where z is distance (m), find...
(a) Frequency
(b) Wavelength
(c) Phase Velocity
(d) At z = 2m, the amplitude is 1 [V], Find the attenuation constant ([itex]\alpha[/itex]).
[tex]f\,=\,\frac{1}{T}[/tex]
[tex]y\left(x,\,t\right)\,=\,A\,cos\left(\frac{2\pi\,t}{T}\,-\,\frac{2\pi\,x}{\lambda}\,+\,\phi_0\right)[/tex]
[tex]u_p\,=\,f\,\lambda[/tex]
(a)
Using the first term ([itex]\frac{2\pi\,t}{T}[/itex]) in the argument to the cosine in the general form above...
[tex]\frac{2\pi}{T}\,=\,4\pi\,\times\,10^9\,\,\longrightarrow\,\,T\,=\,\frac{2\pi}{4\pi\,\times\,10^9}\,=\,0.5\,\times\,10^{-9}[/tex]
[tex]f\,=\,\frac{1}{T}\,=\,\frac{1}{0.5\,\times\,10^{-9}}\,=\,2\,\times\,10^9\,=\,2\,Ghz[/tex](b)
Using the second term ([itex]-\,\frac{2\pi\,x}{\lambda}[/itex]) in the argument to the cosine in the general form above...
[tex]\frac{2\pi}{\lambda}\,=\,20\pi\,\,\longrightarrow\,\,\lambda\,=\,\frac{2\pi}{20\pi}\,=\,\frac{1}{10}\,=\,0.1\,m[/tex](c)
[tex]u_p\,=\,f\,\lambda\,=\,\left(2\,\times\,10^9\right)\,(0.1)\,=\,200,000,000\,\frac{m}{s}[/tex](d)
[tex]1\,=\,5\,e^{-2\,\alpha}\,sin\left(4\pi\,\times\,10^9\,t\,-\,40\pi\right)[/tex]
[tex]5\,e^{-2\alpha}\,=\,1\,\,\longrightarrow\,\,-2\alpha\,=\,ln\left(\frac{1}{5}\right)\,\,\longrightarrow\,\,\alpha\,=\,0.8047[/tex]
Right?
How did you eliminate 't' in part d?
There is no "t" in (d). The "attenuation" constant is the rate at which the magnitude of the wave degrades- and that depends entirely upon the coefficient of the cosine term, [itex]5e^{-\alpha z}[/itex]. And here, we are given that z= 2.
What about the sin term. 1= 5xexp(-alpha x z) x sin term which contains t?
  • · Replies 105 ·
13K
  • · Replies 16 ·
