Why is my computer randomly restarting and freezing?
  • Thread starter Thread starter Nusc
    Computer
The discussion revolves around a user's computer experiencing random restarts and freezes. Participants explore potential hardware and software causes, including overheating, fan issues, and thermal connections, while considering previous attempts to resolve the problem through reformatting.
  • One participant notes that the CPU fan was not initially moving, which may indicate a hardware issue.
  • Another suggests that overheating could be the cause and questions the proper installation of the fan.
  • Concerns are raised about the power supply fan potentially contributing to the overheating issue.
  • Some participants discuss the importance of the thermal connection between the CPU and its heat sink, suggesting that misalignment could lead to overheating.
  • One participant claims that Intel CPUs do not freeze or restart due to overheating, proposing that a malfunctioning hard drive might be the issue instead.
  • A suggestion is made to check BIOS settings for fan speeds and temperatures to gather more information about the system's state.
  • Another participant reports an unexpected improvement in system stability after changing the orientation of the power supply fan.
Participants express differing views on the causes of the computer's issues, with some attributing it to overheating and others suggesting a potential hard drive failure. The discussion remains unresolved as no consensus is reached on the root cause.
Participants mention various assumptions about hardware functionality and the effectiveness of previous troubleshooting steps, but these assumptions are not universally accepted or verified.
This discussion may be useful for individuals experiencing similar issues with computer stability, particularly those interested in hardware troubleshooting and diagnostics.
Nusc
Initially my computer either kept restarting or freezing. It soon became more frequent so I checked the CPU fan. I noticed the fan wasn't moving.
Now, however, the CPU fan is moving after a few weeks after I took the fan off and replaced it back again. My computer still restarts and freezes
Does anyone know what the solution to my problem is?
The CPU is a P3 @ 500 mhz with a SEC II cooler fan.
Is this a hardware of software issue? What can I do to rule this out?
I've had this issue of my computer restarting in the past however not freezing. My solution was to reformat my computer and it worked temporarily of course.
Computer science news on Phys.org
Since you've reformatted several times and still get the same problem, it may not be a malicious software. It seems like a overheating problem. Are you sure the fan was installed properly?
But you can narrow down the causes by doing a virus scan. If that finds nothing, then it probably is a heating issue.
There's a fan in the power supply which could also be the issue.
To check if it's a heat issue, see if the computer doesn't crash as often when it's cold i.e. when it hasn't been running.
Also, there may be an issue with the thermal connection between the CPU and it's heat sink.
Initially the fan was never touched until the restarting became more frequent.
I can't do a virus scan, my computer would never last that long without restarting or freezing.
HOw is the fan in the power supply an issue? I just bought a third one after going through two. The one I currently have has this huge fan in it facing towards the CPU. I just faced it the other way so it hits the top of the tower chasis.
Running it in cold or warm temperatures doesn't make much of a difference. It's purely random. Sometimes it lasts unusually long. As for the thermal connection, I'm not sure what that is.
re: thermal connection: The heat sink is generally glued to the processor with thermal glue -- if the alignment is off, or if the connection is broken by something, heat is transferred much less efficiently from the processor and the processor can overheat even with plenty of fan power.
If I recall, Intel CPU chips don't freeze or restart the computer when they overheat. Only AMD chips do that. If an Intel CPU overheats, it greatly lowers the speed of the computer. If you reformatted the HD and it still freezes/restarts, then it's definitely not software related.It's probably a bad hard drive. Can't really fix that unless you get a new one.
Okay, I would do the following to try and pinpoint the possible causes.
You can go into your BIOS. This should give you a wealth of information about various components, such as fan speeds, temperature, and voltages. This can give you some idea of state your computer's environment just after a failure.
Its is also possible to monitor CPU temp once the OS has booted up. You can use various software packages. An example of such a software is Asus' PC Probe. They tap into the built in sensors on your motherboard. If that doesn't suite you, then you'll have to google for alternate packages that your motherboard manufacturer may have provided.
For some reason my computer hasn't restarted or froze in the last three hours.
I suspect that it's because I faced the big fan of my power supply outward towards the chasis rather than directly onto my CPU. Isn't that strange?
Man, I'm so happy!
  • · Replies 20 ·
17K
  • · Replies 18 ·
35K
