Solving Temperature Profile in Long Thin Plate
  • Thread starter Thread starter ZeroScope
    Temperature
The discussion focuses on determining the temperature profile T(x,y) in a long thin plate that is 30 units wide, with three sides maintained at zero temperature and one edge heated to create a linear temperature gradient. The boundary conditions are established, with the heated edge described by the equation T(x,0) = kx, where k represents the proportionality constant. The participants clarify that the gradients for the positive and negative slopes of the temperature profile do not need to be added together, as the profile is defined by a single linear equation along the heated edge.
  • Understanding of partial differential equations
  • Familiarity with boundary value problems
  • Knowledge of heat transfer principles
  • Basic graphing skills for visualizing temperature profiles
  • Study the derivation of the heat equation in two dimensions
  • Learn about boundary conditions in partial differential equations
  • Explore methods for solving linear differential equations
  • Investigate the application of Fourier series in temperature distribution problems
Students preparing for exams in thermodynamics, engineers working with heat transfer, and researchers studying thermal profiles in materials.
ZeroScope
Determine the temperature profile in a long thin plate 30 units wide and kept at zero temperature at three sides. The remaining short edge is heated in such a way that a temperature profile falling off, linearly on either side of the centre of the edge, is produced. To establish the two-dimensional temperature profile,
T(x,y),
i) sketch the situation,
ii) decide which type of differential equation describes the problem,
iii) rephrase the boundary conditions given in the description as formulae,
This is half a question for an exam that i am taking tomorrow. I can solve everything else about the question but there is one thing that i can't get my head around.
When deciding boundary conditions all are equal to zero apart from the heated edge.
Now i know in order to find the BC for the heated edge that the gradient of the temperature profile must be calculated. (this is a triangle on a T, x graph).
Obviously i would get two gradients, one for the positive slope and one for the negative slope. Do i add these together? If so then i get 2t for the T(x,0) edge.
For more insight into what i mean by the graph i have attached a paint document showing it.
Its just accured to me that as the question states that "the remaining short edge is heated in such a way that a temperature profile, falling off linearly on either side of the centre of the edge, is produced.
Does this just mean the the profile is : T(x,0) = kx? (proportional to x)
  • · Replies 37 ·
