Diffraction Grating: Questions & Answers
  • Context: Undergrad
  • Thread starter Thread starter _Mayday_
    Grating
The discussion revolves around the concept of diffraction grating, focusing on the experimental setup, data collection, and the relationship between wavelength and frequency of light. Participants explore the mechanics of measuring angles and interpreting results from a diffraction experiment, particularly using a sodium lamp.
  • Homework-related
  • One participant asks about measuring angles from the central maximum (m=0) for different colors and how these relate to frequency.
  • Another participant clarifies that "m" represents the order of the diffraction pattern and "d" is the groove period of the grating.
  • There is a request for a simpler explanation of grooves and how to measure them, indicating some confusion about their role in the diffraction process.
  • Participants discuss that "d" is the distance between the grooves and confirm that it remains constant throughout the experiment.
  • One participant expresses understanding of how to apply the formula to find wavelength and inquires about the arrangement of colors based on their frequencies.
  • A later reply notes that longer wavelengths correspond to larger diffraction angles, with specific mention of the order of colors from blue to red in the first positive order.
Participants generally agree on the definitions of "m" and "d" and the relationship between wavelength and diffraction angle. However, there remains some uncertainty regarding the measurement and implications of grooves, as well as the arrangement of colors, which has not been fully resolved.
Some participants express confusion about the technical details of grooves and their measurement, indicating a potential gap in understanding that may affect their experimental outcomes.
This discussion may be useful for students and enthusiasts interested in experimental physics, particularly those studying diffraction and the properties of light.
_Mayday_
I've been reading into diffraction grating recently, and have a few questions to ask. Firstly here is a diagram to help explain what I am on about.
http://img411.imageshack.us/img411/3972/gratingey6.png
Ok, so here is a simple diagram. If I was using a sodium lamp to shine onto the grating, it would project something similar to this, just I forgot to put the gaps in.
Firstly Am i correct in saying, in terms of collecting the data from this, that I would measure the angle from m=0 for each different colour, and the actual colour itself?
Secondly After having taken these reading, how are they relevant to their frequency? I would use the formula [tex]n \lambda= d \sin \theta[/tex] , lamba being the frequency so that is what I am after, sin theeta is the angle that I have measured, but what would "d" and "n" represent?
Thirdly What type of conclusion am I likely to draw from such results? Where would I expect higher frequencies and lower ones? And why would they be there?
I hope, this is clear enough as I have trouble explaining what I actually mean! =] Thanks.
Science news on Phys.org
m is the order of the diffraction pattern (this is your n). d is the groove period.
Look at the http://en.wikipedia.org/wiki/Diffraction_grating" on this wikipedia page.
Ah, thanks yeh, so my [tex]m[/tex] is the [tex]n[/tex] in the formula.
On the topic of grooves I followed your link, but failed to understand what they had to say on grooves "The grating equation shows that the angles of the diffracted orders only depend on the grooves' period, and not on their shape. By controlling the cross-sectional profile of the grooves, it is possible to concentrate most of the diffracted energy in a particular order for a given wavelength."
Is there a simpler explanation of what they are? And how to measure them?
d is the distance between the groves.
^ What are the grooves? Is it the spaces between the projected light segments on the wall? What are they measured in?
Do you know the double slit diffraction experiment? Where you have 2 slits separated by a small distance?
Now a gratting is like this with multiple slits (groves) separated by a distance of d. Usually you measure the slit distance by stating the number of lines/distance.
If you read further of Fabrication in the above link, I think you'll understand.
Ok, so then it is the distance in which the slits in the grating are spaced? So througout the experiment "d" will actually be constant?
"So througout the experiment "d" will actually be constant?"
yes
I think I have grasped the overall idea of the experiment now. Thank you, I know what I am looking for and how to put that into the formula to get a wavelength. What would one expect in terms of how the colours would arange themselves? I know that different colours have different frequencies, but how owuld they arrange themselves? And why?
Thanks for all your help so far, I think I'm getting it now.
The larger the wavelength, the greater the diffraction angle.
"In the first positive order (m = +1), colors with increasing wavelengths (from blue to red) are diffracted at increasing angles."
Thanks dlgoff for all you help I understand it now. =]
  • · Replies 18 ·
9K
