Register to reply
Why the earth is zero potential?
by Physicsissuef
Tags: earth, potential
Share this thread:
turbo
#2
Jan20-08, 04:07 PM
PF Gold
turbo's Avatar
P: 7,363
In what context do you ask this? Are you asking why AC power systems use the local ground potential as the zero-point?
Physicsissuef
#3
Jan20-08, 04:11 PM
P: 908
Quote Quote by turbo-1 View Post
Why the earth is zero potential (0 V)? In electrical point.
arildno
#4
Jan20-08, 04:22 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
For convenience.
It is potential differences that matter, not potential values.
However, one might object to that and wonder:
Why should the Earth's potential be constant?
The short answer to that is that any addition of electric charge down there won't usually affect it (the ground is very large).
However, in extremely rare cases, like massive dumps of charge, the Earth potential might change somewhat on a local scale. And that is a bother for elictricians..
belliott4488
#5
Jan20-08, 04:22 PM
belliott4488's Avatar
P: 666
Electrical potential is defined only in terms of differences, that is, the potential difference between two points can be calculated, but there is no absolute definition of the electrical potential at one point (this is because the physically observable field, the electric field, is given by a derivative of the potential, so only differences are physical).
The Earth is often chosen to be the zero point for convenience, much like choosing the origin of a coordinate system. It is not the only possible choice, and in fact the potential is often to be zero at r = infinity, so that the potential at any distance closer to a source charge at r = 0 will be negative.
EDIT: Sorry, I posted this response a few milliseconds after arildno posted his. (hers?)
arildno
#6
Jan20-08, 04:27 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
His, usually.
turbo
#7
Jan20-08, 04:37 PM
PF Gold
turbo's Avatar
P: 7,363
Earth-grounding is a means of establishing a reasonably-consistent zero point for the transmission of AC power. Please note that ground potential is not the same everywhere, and can swing widely with lightning strikes nearby, more slowly with magnetic storms, etc, and there may be other events that can induce currents in the ground so that ground potential is changed. Dairy farms are often afflicted with stray voltage problems that shock cows and make them nervous and unproductive. Imagine that you're a cow that is going to be milked, and as you are led into the milking stall, your wet nose touches the pipe-frame of the stall and you get a nice shock! Such problems can be caused by these differentials in ground potential. They are generally addressed by improving the ground-reference integrity of the neutral line to local ground, and may require that the primary and secondary neutral/ground reference at the transformer be separated. Ground zero-point is not the same everywhere.
You can also have AC power that is not referenced to earth ground and has a zero-point that is not at ground potential.
Edit: This is a REALLY responsive forum. I got claim-jumped by two other members before I could compose what I hope was a cogent explanation.
Physicsissuef
#8
Jan21-08, 06:48 AM
P: 908
It is truly unimaginable. I can't understand how something is zero potential or whatever. It must have some property which makes the ground zero potential. And how then the Fe have lets say 1volts e. potential, Cu 0.3 volts, or whatever. Sometimes voltage is defined as electron's pressure.
belliott4488
#9
Jan21-08, 06:56 AM
P: 666
Quote Quote by arildno View Post
His, usually.
belliott4488
#10
Jan21-08, 07:00 AM
P: 666
Quote Quote by Physicsissuef View Post
Once again, potential is not absolute, it's relative. You can pick any point and call it "zero" and then measure all other voltages in reference to that point. The Earth is a convenient choice, since it does not change for most practical purposes.
There is no reason to say that one material (e.g. Fe) has a different potential than another (Cu). You can charge up any conductive material to whatever voltage you like (within reason), if you have means to do so, e.g. a generator.
Physicsissuef
#11
Jan21-08, 07:16 AM
P: 908
If the ground if doesn't have 0 potential, do you know what will happen, if I connect R with 0? Look on this picture. The whole system will burn out. So it means, that the ground is zero potential, in the most of the cases, but the question is why?
turbo
#12
Jan21-08, 07:36 AM
PF Gold
turbo's Avatar
P: 7,363
In an AC power system, ground is CHOSEN as the zero-point because it is a relatively stable reference. Ground may not be at the same electrical potential at the generating station and at a step-down transformer outside your house, but it is close enough for purposes of commercial AC transmission. Ground is not some magical zero-potential electrical state - it is a relatively stable reference that is accessible everywhere, so the power companies exploit that.
Physicsissuef
#13
Jan21-08, 08:49 AM
P: 908
If the ground is not zero potential, why when I connect R and 0, the R will burn out?
CompuChip
#14
Jan21-08, 08:54 AM
Sci Advisor
HW Helper
P: 4,300
If ground is not zero potential, then the potential of R will be higher, or the potential difference between them will be smaller.
For convenience.
Quote Quote by belliott4488 View Post
It's a matter of choice.
Integral
#15
Jan21-08, 09:12 AM
Mentor
Integral's Avatar
P: 7,320
The power company has designed earth ground to be the zero, you are forced to follow the same convention.
NoTime
#16
Jan21-08, 09:58 AM
Sci Advisor
HW Helper
P: 1,571
You might consider that the resistance of ground (dirt if you will) approaches zero when the current spreads out. For most intents and purposes it is works just like any other conductor.
Think of ground as a piece of wire.
Physicsissuef
#17
Jan21-08, 10:46 AM
P: 908
Quote Quote by NoTime View Post
If I get piece of ground and put it in pan tile, and than make electric circuit, will it work as same as, if I make electric circuit with the ground?
NoTime
#18
Jan21-08, 10:59 AM
Sci Advisor
HW Helper
P: 1,571
No.
Do you understand the concept of parallel resistance?
The ground works like that.
This is why ground planes tend to involve long pieces of metal conductor buried in the ground.
Register to reply
Related Discussions
Does earth tidal friction use up or add to the moon's gravitational potential energy? Earth 9
Difference between potential energy on Earth and in orbit Introductory Physics Homework 8
Was Mars the Earth of the past and Venus the Earth of the future? General Discussion 6
Did the core of the Earth collide with the Earth billions of years ago? Earth 10
Potential on the Earth surface Introductory Physics Homework 2
