Have you tried using a laser system for distance and location measurements?
  • Thread starter Thread starter dingpud
    Lasers Practical
The discussion revolves around the use of laser systems for measuring distance and location, focusing on the components involved, such as laser emitters and receivers. Participants explore various methods and technologies related to laser ranging, including time-of-flight and phase comparison techniques, as well as applications in fields like surveying and civil engineering.
  • Some participants suggest using a PIN photodiode as a receiver for laser systems, while others mention the use of Avalanche Photodiodes (APDs) for their high speed and sensitivity.
  • There are two main methods for laser range finding: time-of-flight, which measures the time taken for a laser pulse to return, and phase comparison, which analyzes the phase difference of a continuous beam's brightness.
  • One participant inquires about the feasibility of recording the location of an object breaking a continuous laser beam at various distances, questioning the accuracy of such measurements.
  • Another participant mentions that time-of-flight systems can make thousands of measurements per second, providing a potential solution for accurately detecting beam interruptions.
  • Several links to resources and products related to laser measuring systems are shared throughout the discussion.
  • Participants express interest in the applications of laser range finders in surveying, civil engineering, and other industries.
The discussion includes multiple competing views on the best methods and technologies for laser distance measurement, with no consensus reached on a single approach or system. Participants share differing opinions on the effectiveness and accuracy of various techniques.
Some participants highlight limitations in measurement accuracy and the need for integrating multiple wavelengths to resolve ambiguities in phase comparison methods. The discussion also reflects varying levels of familiarity with the technologies mentioned.
This discussion may be of interest to individuals involved in engineering, surveying, or anyone exploring laser measurement technologies and their applications.
dingpud
Has anyone had any experience in using a laser system for measuring distance or location?
I am looking for the laser emitter as well as the receiver as kind of like a matched pair. I haven't really been able to find anything other than laser emitters on their own, and wanted to know if anyone has used a laser "system"
any links anyone has would be great...
thanks
For time-of-flight laser ranging you typically use APDs for the detector because you need high speed and sensitivity, you also need a timing chip capable of resolving a few 10pS.
Or buy something like this http://www.mdl.co.uk/laser_modules/laserace-im/index.html
yep, Photodiode, that's what I'm looking for.
Perfect, thanks.
pud
mgb_phys said:
For time-of-flight laser ranging you typically use APDs for the detector because you need high speed and sensitivity, you also need a timing chip capable of resolving a few 10pS. [/url]
Interesting -- Avalanche Photodiode (APD) -- I need to read more about how to use them. This is an interesting link I came across while googling laser APD:
http://www.analogmodules.com/Data_sht/7500.pdf
thanks
Not sure if this is what you are looking for but I have one of these for measuring distance.
http://www.stanleytools.com/default.asp?CATEGORY=LASER+MEASURING&TYPE=PRODUCT&PARTNUMBER=77-910&SDesc=TLM+100+FatMax%26%23153%3B+Tru%2DLaser%26%23153%3B+Distance+Measurer
CS
Laser range finders are popular in surveying and civil engineering.
http://en.wikipedia.org/wiki/Laser_range-finder
http://www.opticsplanet.net/rangefinders1.html
http://www.pages.drexel.edu/~twd25/webcam_laser_ranger.html
http://www.acroname.com/robotics/info/articles/laser/laser.html
http://www.seattlerobotics.org/encoder/200110/vision.htm
Tunnels, small tubes, and tubular geometries in between are profiled with laser profilometers.
http://www.asnt.org/publications/materialseval/solution/apr99solution/apr99sol.htm
http://www.ndt.net/article/v04n02/roberts3/roberts3.htm
http://www.solarius-inc.com/html/laser.html
In some industries, precision measurements are made with laser mircometers.
There are two main ways of doing laser range finders.
Time of flight = fire a short (ns) infrared laser pulse and start a clock, when the return pulse is detected by a photodiode you stop the clock. Divide c=3E8 m/s by the time = distance. This is useful for long range (upto several km) but lower accuracy (a few cm) and is fast (100,000 points/s) it's used for imaging scanners and laser-radar.
Phase = transmit a continual visible beam varying in brightness sinusoidally at a few kHz. Measure the brightness of the returned beam and compare the phase difference.
From the phase you can tell what fraction of the 'wavelength' the distance represents.
This is used for short distances (upto 10m) and high accuracy (mm) but is slow (5-10 seconds/reading) - it is used in the hand held DIY Disto measurers.
I didn't think of varying the beams brightness...that's interesting...
Say I had a continuous beam shooting from d=0 to d=1m. During the continuous beam, I want to swipe something through the beam (break the beam) at a location of 10cm. Then do the same thing at 13cm, then 25cm, then 80cm, etc. etc. Would there be a way to record the location of the breaking of the beam? Would this be possible? Accurate?
Thank you for the links...
The webcam laser range finder looks like a really cool project.
Thanks,
pud
Remember you aren't measuring the brightness of the returned beam to calculate the distance from the loss of signal.
You are comparing the phase of the change in brightness - eg, if you receive a maximum at the same time your are transmitting a maximum, the object must be a whole number of 'wavelegnths' away - where this is the wavelength of the sine wave not light.
It has a problem that you need to integrate lots of waves to get a good answer so it is slow, and there is an ambiguity - the object could be 0.1, 10.1, 20.1 m away if the wavelength of the change is 10m. To solve this real instruments autaomatically make the measurements at a few different frequencies.
Easily with a 'time of flight' system. These can make 10,000s of measurements/second and should give an accuracy of 1cm over that short range.
A typical system is used for counting traffic on a freeway - a single laser across 6 lanes can count vehicles breaking the beam and measure which lane they were in. Obviously you miss object which were completely hidden behind another object - unless you have another beam measuring from the other side.
Right, comparing wavelengths, you aren't going to be able to differentiate between one amplitude vs. another, one crest vs the other, etc.
The traffic counting system is interesting. I'll have to Google that and see what comes up.
Thanks
  • · Replies 0 ·
