Solve Thermal Expansion: Floating Glass Block in Methyl Alcohol
The discussion revolves around calculating the temperature at which a hollow glass block, initially floating in methyl alcohol, will sink when heated. The key equations involved are the volume expansion formula, V = V initial (1 + Beta x change in Temp), and the buoyant force equation, Buoyant force = rho x V x g. The coefficient of thermal expansion for methyl alcohol is specified as 1200 x 10^-6. The challenge lies in determining how the 93% submersion of the block impacts the buoyant force and overall calculations.
  • Understanding of thermal expansion concepts, specifically volume expansion.
  • Familiarity with buoyant force calculations and principles.
  • Knowledge of the coefficient of thermal expansion for liquids.
  • Basic algebra for manipulating equations and solving for unknowns.
  • Research the density of methyl alcohol to apply in buoyant force calculations.
  • Explore the relationship between buoyancy and thermal expansion in fluids.
  • Learn about the implications of varying temperatures on the density of liquids.
  • Study practical applications of thermal expansion in engineering and material science.
Students in physics or engineering courses, particularly those studying fluid mechanics and thermal dynamics, as well as educators looking for practical examples of buoyancy and thermal expansion principles.
chantalprince
A hollow glass block is floating in a container of methyl alcohol. Initially, everything is at a temperature of 20 degrees C, and just 7% of the block is above the suface of the alcohol. If you heat the container (gently and evenly- so that everything warms up together), at what temperature will the block sink to the bottom?
So far, I think I need these:
V = V initial (1+Beta x change in Temp)
Beta = Coefficient of Thermal expansion (volume)
Buoyant force = rho x V x g (but I am not given the density of methyl alcohol in my book)
Coef for Therm Exp. for Methyl alcohol = 1200 x 10^-6
I am pretty sure I will use the first equation, I just don't know how yet... I don't know any volumes,and I don't have any dimensions to get there, so I don't know how to begin. The 93% submerged tidbit has got to be useful, but I don't see how to use it :( Something to do with buoyant force...?
Thank you ahead of time for any help!
The buoyant force depends on the density of a substance which is inversely proportional to its volume. You know the buoyant force must support the weight of the sphere as well.
21K
