Constant force perturbation of the quantum SHO
The discussion revolves around the perturbation of the quantum simple harmonic oscillator (SHO) due to a constant force. Participants are analyzing the Hamiltonian for the SHO and its perturbation, aiming to derive the exact energies after applying a change of variables.
  • Participants discuss the form of the perturbed Hamiltonian and the implications of substituting variables. There are attempts to clarify the signs in the perturbation and the resulting energy corrections. Questions arise regarding the calculations of second-order corrections and the interpretation of results.
There is ongoing clarification regarding the correct formulation of the perturbation and its effects on energy levels. Some participants have confirmed similar results, while others are questioning specific calculations and interpretations. The discussion is active, with participants seeking to resolve discrepancies in their findings.
Participants are working under the constraints of homework rules, focusing on deriving results without providing complete solutions. There is an emphasis on checking calculations and understanding the implications of the perturbation on the energy levels of the system.
nathan12343
[SOLVED] Constant force perturbation of the quantum SHO
We're supposed to consider the Hamiltonian for the simple harmonic oscillator:
[tex]\hat{H}_{0} = \hat{p}^{2}/2m + m\omega^2\hat{x}^2/2[/tex]
With a perturbation, so that [tex]\hat{H} = \hat{H}_0 + \hat{H}'[/tex], where [tex]\hat{H}' = F\hat{x}[/tex]
I've already solved for the first and second order energy corrections, as well as the first order correction to the wave function. The last part of the question is to solve for the exact energies using the change of variables [tex]x' \equiv x + F/m\omega^2[/tex]
See above
When I substitute for x in the perturbed Hamiltonian, I get
[tex]\hat{H} = \hat{p}^2/2m + m\omega^2\hat{x'}^2/2 - F^2/2m\omega^2[/tex]
Which is of the same form as the unperturbed Hamiltonian, except for a constant, which would shift the energies down by the constant compared to the unperturbed case. However, when I solved for the second order correction to the energies, I got that there wasn't a constant shift, but instead the spacing of the energy levels increased by [tex]F^2(n+1/2)/m\omega^2[/tex] Since the energy correction looks a lot like the extra constant that was introduced to the Hamiltonian, I'm inclined to think that my reasoning is incorrect somewhere, and that I should get that the exact energies are equal to the 0th plus 2nd order energies, but that's just a guess.
Does anyone know where I'm going wrong?
I think you mean
[tex]\hat{H}'= -F\hat{x}[/tex] wrong sign
in order to get [tex]\hat{H} = \hat{p}^2/2m + m\omega^2\hat{x'}^2/2 - F^2/2m\omega^2[/tex]
The 2nd order corrections is exactly
[tex]E_n^2=-\frac{F^2}{2\,m\,\omega^2}[/tex]
Did you check your calculations?
EDIT: [tex]\hat{H}'[/tex] was correct.
No, it's [tex]H' = F\hat{x}[/tex], you have to plug in for x, which means solving for x in the equation for x' given above, there's some cancellation, and [tex]\hat{H}[/tex] comes out as I've given it above.
One part of the problem had us calculate [tex]\left\langle m\right|H'\left|n\right\rangle[/tex], which came out to:
[tex]F\sqrt{\bar{h}/2m\omega}(\sqrt{n+1}\delta_{m,n+1} + \sqrt{n}\delta_{m,n-1})[/tex]
Where I've denoted the nth stationary state of the unperturbed SHO by the n ket
So, the second order correction is
[tex]\sum\left|\left\langle m\right|H'\left|n\right\rangle \right|^2/(E_{n}^{0} - E_{m}^{0})[/tex]
Where the sum is to be taken over all m [tex]\neq[/tex] n.
The kronecker deltas in [tex]\left\langle m \left|\hat{H'}\right|n\right\rangle[/tex] kill off all the terms in the sum except for those which [tex]m = n \pm 1[/tex]
And, if you do the algebra, The second order energy correction comes out to:
[tex]F^2(n + 1/2)/m\omega^2[/tex]
I'm not seeing how you got your answer, Rainbow Child, can you explain?
P.S. Anyone know how to say hbar in LaTex? That doesn't look right
I found the same result
[tex]F\sqrt{\hbar/2m\omega}(\sqrt{n+1}\delta_{m,n+1} + \sqrt{n}\delta_{m,n-1})[/tex]
thus
[tex]m=n+1, \quad F^2\frac{\hbar}{2m\omega}\frac{n+1}{E_n^0-E_{n+1}^0}=F^2\frac{\hbar}{2m\omega}\frac{n+1}{(-\hbar \omega)}=-F^2\frac{n+1}{2m\omega^2}[/tex]
[tex]m=n-1, \quad F^2\frac{\hbar}{2m\omega}\frac{n}{E_n^0-E_{n-1}^0}=F^2\frac{\hbar}{2m\omega}\frac{n}{(\hbar \omega)}=F^2\frac{n}{2m\omega^2}[/tex]
and
[tex]E_n^2=-\frac{F^2}{2m\omega^2}[/tex]
P.S.1 My mistake for the sign!
P.S.2 In LaTeX the solutions is always the obvious \hbar=[tex]\hbar[/tex]. :smile:
Wow...you're totally, right, thanks a lot!
