Know any good capacitor brands?
  • Thread starter Thread starter chrisalviola
    Capacitor
The discussion revolves around the selection of capacitor brands and specifications for a power supply, particularly focusing on the importance of voltage ratings, capacitance values, and the implications of using different types of capacitors in switching power supplies.
  • One participant notes that a defective capacitor in their power supply may indicate poor brand quality and seeks recommendations for good brands.
  • Another participant argues that brand may not be important, emphasizing the need for exact specifications instead.
  • A question is raised about whether a capacitor rated for more than 10V can be used without affecting performance.
  • It is suggested that the voltage rating of the capacitor must be greater than or equal to 10V, with a larger rating providing a better safety margin, although this may increase physical size.
  • Participants mention that for switching power supplies, the electrolytic capacitor must be rated appropriately for that application, and some suggest checking suppliers like Digikey for options.
  • One participant confirms that using a higher voltage rating (>=10V) while maintaining the same capacitance (in "uf") is acceptable and will not affect output voltage.
  • Another participant points out that higher voltage ratings can lead to increased costs and size, questioning the necessity of using excessively high ratings.
  • It is noted that the equivalent series resistance (ESR) of the capacitor is crucial for switching power supplies, as higher ESR can lead to increased ripple voltage and stability issues.
  • One participant warns that using a 10V rated capacitor on a 7V line may not be sufficient, suggesting a need to consider capacitor deratings.
Participants express differing views on the importance of capacitor brands and specifications, particularly regarding voltage ratings and ESR. There is no consensus on the necessity of specific brands, and multiple perspectives on capacitor ratings and their implications remain unresolved.
Participants discuss various specifications and considerations for capacitors without resolving the implications of brand choice or the exact impact of different voltage ratings on performance.
chrisalviola
in my power supply its the first semiconductor that becomes defective, it must be the brand or its not a good quality, I need to buy a new one and solder it, is there any good brands out there or is it important?
It's not generally important. Just make sure it's an exact fit by specifications.
- Warren
the capacitor value is 2200uf 10v, can I use more than 10v and still produce the same results?
The rating on the cap must be greater than or equal to 10V. The larger the better (greater margin). However, as the voltage rating increases the physical size will also increase.
Also, make certain you choose the same type of capacitor. Based on the value I can pretty much tell you you are dealing with an electrolytic capacitor. When replacing electrolytics you must observe the proper polarity.
If you have a switching power supply then the electrolytic must be rated for this application. You might try Digikey, I recall they have a fair selection of this class of electrolytic .
If the power supply is just rectified AC stepdown transformer you can normally use just about any electrolytic that matches the voltage and capacitance.
yes this is a swithing power supply for my pc, this means I can use a higher rated voltage for my capacitor? like >=10v but same rate of "uf", would this produce the same output voltage?
yes. higher rated voltage is better but you pay more $$ and size is bigger. so if the voltage is only 5v, anything like 10v/16v rating works. why pay and use 100v or 1000v size capacitor?
some capacitor features may be important if you are dealing with rf but for most usage it is not a problem
The voltage rating is the largest voltage the capacitor can tolerate without being damaged. Obviously, higher is better, so you can replace the cap with a new one of equal or greater voltage capability.
- Warren
If it is on the output of a switching power supply, then the ESR rating for the cap (equivalent series resistance) can be an issue. The higher the ESR, the higher the ripple voltage at the power supply output, which can cause issues in the circuit being powered. Also, the value of the ESR affects the stability margin of the switching power supply. You need to read the specifications/datasheet for the capacitor that you are replacing, and match the ESR the best that you can. In general, a lower ESR is better.
Sometimes just putting a 10V rated cap on a 7V line isn't enough. This is something I deal with at work. You might want to look into capacitor deratings as well.
  • · Replies 23 ·
