Vector Product Direction & Magnitude Calculation
The discussion revolves around the calculation of the vector product of two vectors, A and B, with specified magnitudes and angles relative to the x-axis. The original poster seeks clarification on the direction of the vector product and its magnitude.
  • Exploratory, Conceptual clarification
  • The original poster attempts to determine the direction of the vector product and its magnitude, while also expressing a need for understanding the right-hand rule. Some participants inquire about the reasoning behind the original poster's approach and the confusion regarding the right-hand rule.
The discussion is ongoing, with participants providing guidance on the right-hand rule and exploring the original poster's understanding of the vector product. There is an emphasis on clarifying concepts rather than reaching a definitive conclusion.
The original poster mentions a time constraint, indicating urgency in completing the homework, which may affect the depth of their initial reasoning.
starchild75
vector A has magnitude of 2.80 m, 60 degrees above x axis. vector B has magnitude of 1.90 m 60 degrees below x axis. Is the direction of the vector product positive z direction or negative z direction? What is the magnitude of vector B times vector A. I already got vector A times vector B.
AB sin theta.
Do you have any work or reasoning to show?
Sorry, I was in a hurry to get this thing done by midnight. I got it completed, but I need help understanding the right hand rule.
What is confusing you about the right hand rule? If you are confused about the procedure of it:
Place your fingers of your right hand in the direction of the first vector in the product. Then, curl your fingers towards the second vector in the product. If you can't, then flip your hand around. After you have curled your fingers, your hand should be in a "thumbs-up" formation. Your thumb is pointing in the direction of the product vector.
  • · Replies 16 ·
