| Thread Closed |
Roots of polynomials... |
Share Thread | Thread Tools |
| Jan23-08, 09:42 PM | #1 |
Recognitions:
The roots of the equation [itex]x^3-x-1=0[/itex] are [itex]\alpha,\beta,\gamma[/itex] [itex]S_n=\alpha^n +\beta^n +\gamma^n[/itex] (i)Use the relation y=x[itex]^2[/itex] to show that [itex]\alpha^2,\beta^2,\gamma^2[/itex] are roots of the equation [itex]y^3-2y^2+y-1=0[/itex] (ii)Hence, or otherwise find the value of [itex]S_4[/itex] (iii)Find [itex]S_8,S_{12},S_{16}[/itex] 2. Relevant equations [tex]\sum \alpha=\frac{-b}{a} \ \sum \alpha\beta=\frac{c}{a} \ \sum \alpha\beta\gamma=\frac{-d}{a}[/tex] 3. The attempt at a solution Just need help with the first part for now. Using I substituted y=x^2 into the equation they gave me in hopes to get back the original equation but that did not work out. Should I just find the sum of the roots and then the sum of the squares of the roots for the original equation and then find the sum of the roots for the eq'n in y and show that they are equal? |
| Jan24-08, 12:07 AM | #2 |
Recognitions:
Are you permitted to use rational roots theorem, and fundamental theorem of algebra? The way you ask the question gives the impression that you are studying something beyond PreCalculus.
| Jan24-08, 05:37 AM | #3 |
You don't need anything deep like that. If y= x2, then it is easy to show that y3- 2y2+ y- 1= x6- 2x4+ x2- 1= (x3-x-1)(x3-x+ 1). Since [itex]\alpha[/itex], [itex]\beta[/itex], and [itex]\gamma[/itex] make the first factor 0, they make the entire polynomial 0.
| Jan24-08, 09:14 AM | #4 |
Recognitions:
| Jan24-08, 11:01 AM | #5 |
Recognitions:
| Jan24-08, 12:03 PM | #6 |
| Jan24-08, 02:32 PM | #7 |
Recognitions:
I could not pick any better rational values to test. According to the textbook of Precalculus, we pick using factors of the constant term and coefficient of the leading term, the positive and the negative values. These are based on integers. |
| Jan24-08, 03:07 PM | #8 |
Apparently you simply did not understand what the question was asking! It is obvious, from the "rational root theorem" you cite, that neither of these equations has rational roots! The problem did not ask us to find any rational roots, or find any roots at all. It only asked us to show that roots of one equation must satisfy the other. That true because the given 6th degree polynomial (after substituting x2 for y) has the first 3rd degree polynomial equations as a factor.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Roots of polynomials...
| Roots of Trigonometric polynomials? | General Math | 3 | ||
| Polynomials do or don't have integer roots? | Precalculus Mathematics Homework | 12 | ||
| multiple roots of polynomials | Calculus & Beyond Homework | 5 | ||
| solutions for roots polynomials. | General Math | 2 | ||
| Roots of Complex Polynomials | Calculus | 1 | ||
