Experimenting with Geiger-Müller Tube: Half-Life of Protactinium (Pa)
  • Context: Undergrad
  • Thread starter Thread starter _Mayday_
    Tube
The discussion revolves around an experiment to determine the half-life of protactinium (Pa) using a Geiger-Müller tube. Participants explore additional activities that could be conducted during the experiment, as well as considerations regarding radiation detection and measurement techniques.
  • Experimental/applied
  • One participant suggests measuring the radioactivity of rainwater, which may contain cosmic ray exposure, as an additional experiment.
  • Another participant raises concerns about potential false positives with the Geiger-Müller tube and suggests exploring variations in radiation intensity based on direction.
  • There is a discussion about conducting a background count with the Pa source removed to achieve better statistical data due to low counting rates.
  • A participant questions the isotopic composition of the Pa sample and its implications for measuring decay constants.
  • A separate inquiry is made regarding the behavior of a Geiger-Müller tube when exposed to radiation without being activated, questioning if accumulated doses would affect future readings.
Participants express various ideas and suggestions, but there is no consensus on the best additional experiments or the implications of certain measurement techniques. Multiple competing views remain regarding the use of the Geiger-Müller tube and the specifics of radiation detection.
Participants mention the importance of background counts and the need for knowledge about the isotopic vector of the Pa sample, indicating that assumptions about the sample's characteristics are crucial for accurate measurements.
This discussion may be useful for students and educators involved in experimental physics, particularly those interested in radiation detection and measurement techniques using Geiger-Müller tubes.
_Mayday_
Hey,
On Monday I am doing an experiment to determine the half-life of protactinium (Pa), using a Geiger-Müller tube. The experiment itself is very straight forward and simple, but I have 70 minutes to do it in, which is a lot of time. I was wondering if there was anything else I could do with this apparatus to make the time left over constructive? I have already used to to measure how penetrating certain particles are through different materials.
The 70 minutes does not include time for writing up, so it is a long time, any ideas would be great.
Thanks.
Well, if it rains around then (don't know what part of the world you're in) you could collect some rain and measure the events per second from the fresh rain water (it was just a good ways up in the sky and exposed to cosmic rays, should have some radioactivity to it). Not difficult or anything, but mildly interesting just to see how radiactive rain water is. Of course I don't know how your teacher/TA/whatever would feel about you bringing water near the Geiger-Muller tube (probably not that expensive but it sucks to have to replace lab equipment).
Explore what might create a false positive with your counter.
How about variations in radiation intensity with direction?
Is there any significant (Radon) radiation from concrete vs. other building materials/soil?
Could you please expand a bit on that. What do you mean by a false positive? Thanks :smile:
I might try that if it's rainy tomorrow thank you.
I think what Loren Booda is suggesting is to do a background count, i.e. with the Pa source away from the detector. Due to low counting rates, a background count would take longer to achieve good statistics.
To measure the half-life (or decay constant) one usually has to do two measurement over some period of time. Then there are the two counting periods and the waiting period in between. Otherwise, one counts for one period, but one must know the mass of isotope present in order to determine the decay constant from the activity.
What is the pedigree of the Pa sample? Does one know the isotopic vector?
See this taken from ( www.nndc.bnl.gov/chart ). Use cursor to find Pa click on chart, then click on 1 under Zoom to see the details.
http://img213.imageshack.us/img213/8680/z91n139zl1ct12r4057sl3.png
Thanks, Astronuc, background count.
Dear Sir,
I need to ask about the Geiger Muller tube that is used for radiation detection in Japan by public. What if the GM exposed to radiation dose (gamma or beta) more than its limit but it wasn't connected to the high voltage which activate it, (Current+ cathode+ anode>> ionization+ cpm). Was this dose accumulated in the GM and as turn it on it will give indication for the high dose or not?
Thank you
BR
14K
  • · Replies 19 ·
11K
