Why we can see light and not heat?
  • Context: High School
  • Thread starter Thread starter Physicsissuef
    Heat Light
The discussion centers on the differences between light and heat, particularly why light is visible while heat (thermal radiation) is not. Participants explore the nature of heat, its reflection, and the perception of thermal radiation by different organisms.
  • Some participants suggest that thermal radiation is outside the visible spectrum, which ranges from approximately 400nm to 700nm.
  • Others argue that some animals can perceive heat, indicating that visibility is dependent on the biological structure of eyes.
  • There is a discussion about the nature of heat, with some participants clarifying that heat is the transfer of energy rather than a substance that can be possessed.
  • One participant mentions that shiny surfaces can reflect heat, challenging the notion that heat cannot be reflected.
  • Confusion arises regarding the definition of heat and its relationship to temperature and energy, with participants attempting to clarify these concepts.
  • References to previous discussions and external resources are provided to elaborate on the differences between thermal energy and heat.
Participants express differing views on the nature of heat and its visibility, with no consensus reached on the definitions and implications of heat versus temperature. The discussion remains unresolved regarding the perception of heat and its properties.
Some participants highlight limitations in understanding the definitions of heat and temperature, as well as the implications of energy transfer, which are not fully resolved in the discussion.
Physicsissuef
Why we can see light and we can not see heat? Why can't heat be reflected?
Science news on Phys.org
By heat I assume you mean thermal radiation. If this is the case then the reason is that the photo receptors in our eyes are only sensitive to wavelengths between roughly 400nm to 700nm and thermal radiation has a wavelength greater than 700nm.
What makes you think it can't?
Some animals can see heat (either infrared or ultra-violet). It's just the way our eyes are made, what we CAN see we call it visible light... I don't think there's any more to it than that. If we could see infrared we wouldn't think it at all special, we'd just see an extra colour. Just like some electronic cameras easily detect infra-red, at no extra cost.
UV Heat? :confused:
This caused a bit of a hullaballo a few years back when people realized their HandyCams were recording the naughty bits of their loved ones right through their clothes. Manufacturers hastily installed filters in their cams to prevent this. But the filters can be removed...
We don't really see either, but rather the effects of them. What is called light, is the effect of a quantity of electromagnetic energy (photon).
Heat is a measure of energy content, that can be felt, or observed. As an example ( a section of steel is going to be cut, or tempered, with the addition of heat it goes thru visible changes, dull red- cherry red- orange- yellow- white, these colors are very dependable indicators of the temperature of the steel being heated) we see the "effect" of heat.
RonL said:
Heat is a measure of energy content, that can be felt, or observed...
Just to make one thing clear, heat is not temperature nor is it energy. Heat is the transfer of energy from a higher temperature to lower temperature, something cannot have "heat", and to say that something "has heat" is non-nonsensical. One can think of heat as the microscopic analogy of work.
If you have a space heater, look at the shiny surface behind the heating element. It's there to reflect the heat.
I'm confused:confused: If at 1200 degrees, i remove the flame used to bring the temperature up, how do you describe the state of the steel until it cools to room temperature ?
First, the flame increases the internal energy of the steal, by transferring energy to the steel, this energy transfer is called heat as opposed to work which would be done if the steel bar were compressed. When the flame is removed, the steel bar begins to radiate energy to it's surroundings and it's temperature decreases. This thermal radiation is known as heat.
As I said previously, something does not have heat, but the energy transferred down a temperature gradient is defined as heat. In the macroscopic analogy of work, something cannot have work, but is can transfer energy by doing work.
Further reading:
https://www.physicsforums.com/showthread.php?t=169821 - an earlier thread discussing the differences between thermal energy and heat.
http://hyperphysics.phy-astr.gsu.edu/Hbase/thermo/temper2.html
http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/inteng.html
Thanks Hootenanny
Knowing something, and using the proper words, or definitions to describe what is known, is so important. Lots of study for me. Maybe the next six years will produce a marked improvment in my post. Hope were all still around that long.
Thanks for the links.
Ron
  • · Replies 19 ·
  • · Replies 33 ·
  • · Replies 24 ·
  • · Replies 66 ·
  • · Replies 30 ·
