Magnitude of initial acceleration
The problem involves calculating the initial acceleration of a charged particle in an electric field created by another charged particle. The context includes concepts from electrostatics and Newtonian mechanics.
  • Participants discuss the application of Coulomb's Law and Newton's Second Law to relate electric force and net force. There are questions about how to start solving the problem and the relationship between the equations involved.
Some participants have provided guidance on using the equations to find the acceleration, while others express uncertainty about their understanding of the concepts and how to apply them to the problem. There is an ongoing exploration of the relationship between the forces and the equations presented.
Participants note that they have recently learned the relevant equations and lack familiarity with similar problems, which may affect their confidence in applying the concepts.
sonastylol
[SOLVED] Magnitude of initial acceleration
A particle of mass 67 g and charge 25 microC is released from rest when it is 89 cm from a second particle of charge -10 microC. Determine the magnitude of the initial acceleration of the 67 g particle. Answer in units of (m/s)^2.
I understand how to find magnitude of vectors but I don't even know where to start with this one..
Can someone please give me a detailed push in the right direction? Thank you so much
You know Coulomb's Law:
[tex]F_E = \frac{k*q*q'}{r^2}[/tex]
And you know Newton's 2nd Law:
[tex]F_{NET} = ma[/tex]
If the electric force is the net force, what is the relation between these two equations?
to be honest I am not sure what the answer to:
we only just barely learned those equations, and i haven't seen any type of sample problem close to this one...
I don't know where to start, even with your help..
Thanks again
The only force acting on the 25microC charge is the electric force FE, and thus the electric force IS the net force on the charge in question. So we have:
[tex]\frac{k*q*q'}{r^2} = ma[/tex]
You know the magnitude and signs of each charge, you know the value of the constant "k," you know the distance between the two charges "r," and you know the mass of the charge in question. Now all you have to do is solve the above equation for the acceleration "a." Don't forget to convert the charges to Coulombs, the mass to kilograms, and the distance to meters. Does this help?
  • · Replies 21 ·
