Analysis - proof involving 1-1, image and pre image of sets
The discussion revolves around proving a property of injective functions, specifically that if a function f is injective, then the preimage of the image of a subset C under f equals C itself. The subject area involves set theory and properties of functions.
  • The original poster attempts to prove the set equality by showing both sides are subsets of each other. They express uncertainty about how to incorporate the injective nature of the function into their reasoning.
Participants are engaging in clarifying the role of the injective property in the proof. Some guidance has been offered regarding the definition of injective functions and its implications for the proof, but explicit consensus on the approach has not been reached.
The original poster acknowledges a potential oversight in their reasoning related to the injective property and is seeking hints rather than complete solutions. There is an emphasis on understanding definitions and their applications in the proof process.
b0it0i
Prove:
If f is injective (1-1), then f^-1 [ f(C) ] = C
f: A -> B
C is a subset of A, and D is a subset of B
note f^-1(D) is the preimage of D in set A
and f(C) is image of C in set B
My attempt:
Assume f is injective, WMST f^-1 [ f(C) ] = C
to show set equality, we have to show that the left side is a subset of the right side, and vice versa
I have already shown that C is a subset of f^-1 [ f(C) ]
my problem is showing that f^-1 [ f(C) ] is a subset of C
I assumed x is an element of f^-1 [ f(C) ]
by definition of preimage f^-1(D) = { x element of A | f(x) element of D}
hence, f(x) is an element of f(C)
and by definition of image f(C) = { f(x) | x element of C}
can i conclude that, since f(x) is an element of f(C), hence x is an element of C
therefore the proof is complete
but i believe this is wrong, since i have not used the fact that f is injective (1-1)
can anyone provide any hints?
This is precisely where you use the fact that f is 1-1!
just by stating the definition of 1-1
for all x1, for all x2, if x1 does not equal x2, then f(x1) does not equal f(x2)
or the contrapositive form, if f(x1) = f(x2), then x1 = x2
how would i use that to jump to my conclusion?
would i need to introduce two points x1 and x2
where x1 is an element of A, and x2 is an element of C?
i'm not really sure how to use the fact f is 1-1
If f(x) is in f(C), then this means there is an x' in C such that f(x)=f(x').
I see!
that makes sense
i should have looked at the definition of image more closely
thanks a lot
  • · Replies 21 ·
  • · Replies 26 ·
