Kinematic Equations for Constant Speed
  • Thread starter Thread starter stevenwho
The discussion revolves around a kinematics problem involving a car that accelerates from rest for a specified duration before moving at a constant speed. Participants are exploring the calculations related to acceleration, final velocity, and time taken to cover a subsequent distance.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting to apply kinematic equations to determine the car's acceleration and final velocity. There are questions about the relevance of initial conditions and the correct interpretation of the problem statement. Some participants are recalculating values based on identified errors in the original poster's approach.
The discussion is ongoing, with participants providing feedback and suggesting recalculations. There is an acknowledgment of potential confusion regarding the application of kinematic equations, and some guidance has been offered to clarify the correct formulas to use.
There are indications of confusion regarding the time variable used in calculations, with some participants noting discrepancies in the original poster's values. The problem's constraints, such as the transition from acceleration to constant speed, are under examination.
stevenwho
Kinematic Equations... Constant Speed
Question 1) A car pulls away from an intersection when the light turns green. After uniformly accelerating for the next 4.0s, the car has traveled a distance of 50m. The car then proceeds at constant speed.
1. What was the car's acceleration
2. How fast was the car traveleing when it finished accelerating
3. How long will it take for the car to travel another 50 m at this constant speed?
The 5 kinematic equations
For #1... I used a kinematic equation and I found this info
Initial Velocity = 0
Time = 45s
X = 50
a = ?
X = distance
a = acceleration
So then I used x=intitial velocity + acceleration*time
and got 1.11m/s... Am I right?
For #2... I found
Time = 4 seconds
X = 50 minutes
a = 1.11m/s
V= ?
Would objects position at time = 0 be relevant here?
I got a answer of 14.72 m/s... Is that right?
For #3
I said X= 100 (50 m + 50 m)
said initial velocity = 0
a = 1.11m/s
t = ?
I got t = 90s... Kind of makes sense, 14.72m/s + 90s = 104 something M...
? - the unknown. Please help :D
Thanks
I think you have a problem right away.
Time = 45s
X = 50
a = ?
Why are you using 45s as the time? It appears to be 4.0s in your problem. Try recalculating your acceleration.
I'm not sure what this is, and I think you're mixing your formulas up.
X = distance
a = acceleration
For this #2, you're close, except you'll have to recalculate using the new acceleration you should have found above. The easiest formula to use to find the velocity at that point is:
[tex]v_2 = v_1 + at[/tex]
For #2... I found
Time = 4 seconds
X = 50 minutes
a = 1.11m/s
V= ?
For #3 below, I think you've really gone astray. It's only asking for the time for the next 50m, and an important piece of information is:
Remember, a constant speed means NO acceleration. So you can just use a constant velocity equation, such as:
[tex]v = \frac{dist}{time}[/tex]
So just toss this stuff below out and try again.
For #3
a = 1.11m/s
t = ?
Thanks
Good luck!
Still can't find the answer to the cars acceleration
Well, you need to use the correct equation, which I mentioned above. You have
X = initial velocity + acceleration * time
but that's not the correct equation. The correct equation is:
[tex]\Delta x = ut + \frac{1}{2} a t^2[/tex]
Where u = initial velocity. You can solve for aceleration using
[tex]\Delta x = 50m[/tex]
[tex]u = 0[/tex]
[tex]t = 4.0s[/tex]
So now we have:
[tex]50 = (0)(4) + \frac{1}{2} a 4^2[/tex]
You can do the rest.
  • · Replies 20 ·
