[SOLVED] River channel problem using Bernoulli and Continuity
by tere_lai
Tags: bernoulli, channel, continuity, river, solved
tere_lai
tere_lai is offline
#1
Jan27-08, 11:31 PM
P: 4
A river (100 m wide) flows through its rectangular channel at a depth of 2.560 m at a velocity of 2.050 m/s. What is the velocity of the discharge if the channel is narrowed to 90 m?
2. Relevant equations
Continuity equation: Q1 = 100m x 2.560 m x 2.050 m/s
Q2 = 90 m x H2 x V2
Bernoulli equation: V^2/2g + P/pg + z = constant
3. The attempt at a solution
I can't seem to set up the equations properly in order to find intercept. I'm sure that P1 (ie. pressure1) is zero, but P2 isn't. I actually tried solving the question with P2=0 but it's wrong.
A little help?
(you may have seen this in "Introductory Physics" but I don't know how to move/delete the previous thread, sorry)
Phys.Org News Partner Science news on Phys.org
Review: With Galaxy S5, Samsung proves less can be more
Making graphene in your kitchen
Study casts doubt on climate benefit of biofuels from corn residue
Pyrrhus
Pyrrhus is offline
#2
Jan28-08, 12:26 PM
HW Helper
Pyrrhus's Avatar
P: 2,280
Hey there, in open channel flow usually the version of Bernoulli equation used is:
[tex] y + \frac{v^2}{2g} + z = constant [/tex]
In your case the z value probably can be ignored assuming the river doesn't have any vertical variations in its geometry. You could use this equation which is also known as the specific energy.
[tex] y + \frac{v^2}{2g} = constant [/tex]
tere_lai
tere_lai is offline
#3
Jan28-08, 03:35 PM
P: 4
The height of the water (z) is assumed to change due to the narrowing of the river channel. I think I know how to answer the question now...
Pyrrhus
Pyrrhus is offline
#4
Jan28-08, 06:02 PM
HW Helper
Pyrrhus's Avatar
P: 2,280
Great!, good luck, if you have more questions feel free to ask them.
tere_lai
tere_lai is offline
#5
Jan28-08, 06:09 PM
P: 4
thanks for your help!
Register to reply
Related Discussions
UFO Hunters on The SciFi Channel and The History Channel Science Fiction & Fantasy 18
Bernoulli and Continuity Question!! Introductory Physics Homework 0
[SOLVED] Boat in the river problems Introductory Physics Homework 0
Bernoulli Continuity Water Jet Problem Introductory Physics Homework 0
[SOLVED] Bernoulli, Poisson & Normal Probability Precalculus Mathematics Homework 10
