| Thread Closed |
photoelectric effect |
Share Thread | Thread Tools |
| Jan28-08, 02:17 PM | #1 |
Is in the photoelectric effect, the electrons are oppositing the electromagnetic field or they are excited from the energy?
| Jan28-08, 03:16 PM | #2 |
Recognitions:
I don't understand your question. However, the photoelectric effect involves an electron absorbing a photon and, being more energetic, leaving the atom.
| Jan29-08, 06:15 AM | #3 |
| Jan29-08, 07:45 AM | #4 |
Mentor
photoelectric effectUV radiation can cause photoemission if the work function is below the photon energy. Now what is it exactly that you want to know here in this thread? Zz. |
| Jan29-08, 12:00 PM | #5 |
| Jan29-08, 02:26 PM | #6 |
Mentor
This is getting utterly confusing. You WERE asking about the photoelectric effect, weren't you? Why is it optical conductivity now?
Glass bulb? When did that come in? Did you mention about glass anywhere till now? There's no "photoemission" using UV source on glass bulb, is there? Why don't you start from the very beginning and ask your question once again. But this time, please put in as much effort and information in your question so that we know (i) what you know (ii) what exact it is the picture that you have in your mind. If you see that you have to ADD new stuff as you go along, it means clearly that you omitted important information in your original question. Zz. |
| Jan29-08, 03:12 PM | #7 |
| Jan29-08, 04:17 PM | #8 |
Recognitions:
The vacuum is used so the electrons can stream without interacting with anything. The radiation is always electromagnetic, as long as the frequency is high enough to excite the electrons of the material being used.
| Jan29-08, 05:11 PM | #9 |
Mentor
What kind of radiation? Any radiation in which the photon energy is higher than the work function! I thought I mentioned this already. Electrons do not travel very far in air, and even if they do, a lot of them get scattered off and would not reach the anode. This is not what you want when you are using a photocell to detect EM radiation. If you are trying to detect UV, the "glass" has to be either quartz or fused silica, because ordinary glass absorbs UV. Zz. |
| Jan30-08, 01:31 AM | #10 |
| Jan30-08, 04:10 AM | #11 |
Mentor
If they are connected to a wire, they would be the SAME thing, not two different things. The anode has to be at a higher potential then the cathode, the latter is usually grounded.
Zz. |
| Jan30-08, 11:51 AM | #12 |
And why in my text book says, that the kinetic energy of the electrons doesn't depends from the intensity of the radiation?
| Jan30-08, 01:00 PM | #13 |
Mentor
Your textbook doesn't explain this? Please read for example, this: http://www.colorado.edu/physics/2000...oelectric.html Zz. |
| Jan30-08, 04:21 PM | #14 |
| Jan30-08, 04:34 PM | #16 |
| Jan30-08, 05:10 PM | #17 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: photoelectric effect
| The Photoelectric Effect Help | Introductory Physics Homework | 6 | ||
| Photoelectric Effect. | Introductory Physics Homework | 1 | ||
| Photoelectric Effect | Introductory Physics Homework | 8 | ||
| Photoelectric effect | Quantum Physics | 0 | ||
| photoelectric effect | Introductory Physics Homework | 5 | ||
