Proof of CLopen Sets Homework Statement
  • Thread starter Thread starter Hummingbird25
    Proof Sets
The discussion centers on the properties of clopen sets in the context of topology, specifically within the Euclidean space \(\mathbb{R}^n\). The user, Hummingbird, explores the implications of a subset \(T\) being both closed and open, leading to the conclusion that if \(T\) is neither \(\mathbb{R}^n\) nor empty, its complement \(U\) must also be clopen. This results in a contradiction regarding the connectedness of \(\mathbb{R}^n\). The user also inquires about the application of uniform continuity in proving the continuity of a function \(g\) defined on \(\mathbb{R}^n\).
  • Understanding of clopen sets in topology
  • Familiarity with the concepts of open and closed sets in \(\mathbb{R}^n\)
  • Knowledge of uniform continuity and its definitions
  • Basic principles of connectedness in topological spaces
  • Study the properties of connected spaces in topology
  • Learn about the definitions and implications of uniform continuity
  • Explore the concept of complements of sets in \(\mathbb{R}^n\)
  • Investigate the relationship between clopen sets and connectedness in topological spaces
Students and educators in mathematics, particularly those studying topology, as well as anyone interested in the properties of clopen sets and continuity in \(\mathbb{R}^n\).
Hummingbird25
Hi
I have been working with sets which are both closed and open the socalled clopen sets. I have some question.
Lets say that [tex]T \subseteq \mathbb{R}^n[/tex] is a subset which is both closed and open, and then if [tex]T = \mathbb{R}^n[/tex] or [tex]T = \emptyset[/tex]. Assume that [tex]\{T \neq \mathbb{R}^n|T \neq \emptyset\}[/tex]
Proving this results in a contradiction.
(1) Let [tex]U = \mathbb{R}^n \setminus T[/tex] and show that U is open and closed and not-empty.
If [tex]U = \mathbb{R}^n \setminus (T = \mathbb{R}^n) = \emptyset.[/tex] since [tex]T = \mathbb{R}^n[/tex] which is non-empty and both closed and open according to above. Thus [tex]U = \mathbb{R}^n\setminus \emptyset = \mathbb{R}^n.[/tex] which therefore upholds the claim in (1).
(2) Let [tex]g: \mathbb{R}^n \rightarrow \mathbb{R}[/tex]
be defined as:
[tex]g(x) = \left( \begin{array}{cc}1 \ \ \mathrm{for \ t \ \in \ T}\\ 0 \ \ \mathrm{for \ u \ \in U} \end{array}[/tex]
Prove that g is continious at every point [tex]t_{0} \in T[/tex]. is it something which uniform continouity which I need to use here?
If yes then I need to show here that for any t in g converges towards [tex]t_0[/tex]??
If yes then
Proof
By the definition of uniform continuity then
[tex]g: \mathbb{R}^n \rightarrow R[/tex] be continuous at every [tex]t_0[/tex] if and only if there for every [tex]\epsilon > 0[/tex] exists a [tex]\delta > 0[/tex] such that [tex]|g(t) - g(t_0)| < \epsilon \Leftrightarrow \|t - t_0 \| < \delta.[/tex]
Is the trick then to show that g upholds the defintions above??
Sincerely Yours
Hummingbird.
What are you allowed to use? If R is a "clopen" set such that it is neither the empty set nor all of Rn, then S= complement (R) is neither the empty set nor Rn. S is closed because R is open- and R is also closed, of course. Then Rn= R union S where both R and S are closed: Rn is not a connected set. If you are allowed to use the fact that Rn is a connected set, that's a contradiction.
I confess that I am unable to figure out what you meant to say. Could you restate it?
  • · Replies 24 ·
