| Thread Closed |
VI Characteristic |
Share Thread |
| Jan28-08, 08:37 PM | #1 |
VI Characteristic
Hi, I have the following circuit: http://i137.photobucket.com/albums/q...t3Circuit1.png Also, the following is known: X=60 V R1= 10 Ω R2= 20 Ω R3= 10 Ω R4=5 Ω R5=20 Ω R6 = 5 Ω 2. Relevant equations V = IR y = mx + b 3. The attempt at a solution How do I go about finding a V-I characteristic of this circuit? I know that the slope of the graph is the resistance but I am confused as to how to start this one. I found the resistance across the source by using circuit reduction. I got that to be 32 ohms. So is the V-I characteristic just V = 32i? or is it just a constant line y = 60? (in this case V is on the y-axis and I is on the x-axis) Thanks! 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Jan29-08, 09:15 AM | #2 |
X is in series with R1 and R2, so you can associate their characteristics. Since this sub circuit is in parallel with R3, you can now associate their characteristics. The resultant characteristic is associated with R4 and R5 which are in series and finally that characteristic is associated with R6 in parallel. |
| Thread Closed |
Similar discussions for: VI Characteristic
| JK Flipflop Characteristic | Engineering, Comp Sci, & Technology Homework | 7 | ||
| characteristic of R | Calculus & Beyond Homework | 0 | ||
| VI Characteristic | Engineering, Comp Sci, & Technology Homework | 9 | ||
| Characteristic? | Calculus & Beyond Homework | 3 | ||
| characteristic equation | Differential Equations | 13 | ||
