How to Simulate a Bouncing and Spinning Ball in Two Dimensions?
  • Context: Graduate
  • Thread starter Thread starter gcoope
    Ball Spinning
This discussion focuses on simulating a bouncing and spinning ball in two dimensions, specifically addressing the physics of collision with a stationary wall. Key variables include initial velocity (u), initial angular velocity (ω), radius (r), coefficient of friction (μ), coefficient of restitution (e), mass (m), and moment of inertia (I). The resultant velocities post-collision are determined by the equations vj = -e*uj and the impulse m(1+e)uj, with rotational impulse affecting angular velocity as ω increases by μm(1+e)uj/I. The conservation of angular momentum about the point of contact is crucial for accurate simulation.
  • Understanding of basic physics concepts such as momentum and angular momentum
  • Familiarity with collision mechanics and the coefficient of restitution
  • Knowledge of rotational dynamics, including moment of inertia
  • Experience with 2D simulations and physics engines
  • Research the principles of conservation of angular momentum in collisions
  • Explore the implementation of physics engines like Box2D for 2D simulations
  • Learn about the effects of friction in collision scenarios
  • Study the mathematical modeling of rigid body dynamics in simulations
Game developers, physics simulation engineers, and anyone interested in implementing realistic 2D motion dynamics in simulations or games.
gcoope
I'm looking to simulate a bouncing and spinning ball in two dimensions. I have the detection working fine but I'm having a little difficulty with the physics.
I have a moving ball colliding with a stationary immovable wall.
I would like to know the resultant velocities of the ball in terms of:
initial velocity u,
initial angular velocity ω,
radius r,
coefficient of friction μ
coefficient of restitution e,
mass m,
moment of intertia I
obviously first we resolve normally to the plane.
we have vj = -e*uj
so the impulse = m(1+e)uj
now I think there should be a rotational impulse proportional to this by a factor of the coefficient of friction,
so ω increases by μm(1+e)uj/I
but I get stuck here. I haven't considered the initial angular velocity of the ball and its impact on the resultant velocity and resultant angular velocity.
I hope someone can be of help,
thanks a lot,
Giles.
You can't unless you impose constraints on how the ball is spinning, i.e. the orientation of the spin axis. Say you define the motion of the ball in the "collision plane" which is defined as the plane formed by the initial velocity vector and the normal to the surface. Now assume that the ball is spinning and that, while the ball is in contact with the surface, the point of contact on the ball does not slide relative to the point of contact on the surface. If you want the velocity of the ball after the collision to remain in the collision plane, the spin axis must be in a plane perpendicular to both the surface and the collision plane. Now note that the collision of this kind conserves angular momentum about the point of contact P because there are no torques about that point acting the ball. You need to conserve angular momentum about point P to relate the "after" quantities to the "before" quantities. After the collision the component of the angular velocity perpendicular to the collision plane becomes ##V_{CM}/R## where ##V_{CM## is the velocity of the center of mass.
  • · Replies 60 ·
  • · Replies 32 ·
  • · Replies 35 ·
