Why Does My C Program Skip Input Fields?
The discussion revolves around a C programming issue where a program intended to read student names and scores is skipping input fields. Participants explore the behavior of input functions like gets and scanf, and their interactions in the context of reading multiple inputs in a loop.
  • One participant describes a problem where the program prints prompts for name and scores simultaneously, leading to skipped input.
  • Another participant suggests changing gets to scanf("%s", name);, but notes that this does not allow for full names with spaces.
  • A participant mentions that gets is designed for reading from data streams rather than standard input, which may contribute to the issue.
  • There is a suggestion that using scanf may be causing the input to be skipped due to how it handles input buffering.
  • One participant proposes that the problem might be related to the compiler or platform being used, indicating variability in behavior across different environments.
  • Another participant shares a modified version of the code that appears to work correctly, emphasizing the importance of using the correct syntax with scanf.
  • Concerns are raised about buffer overflow risks when using scanf, with a suggestion to consider alternatives like sscanf.
Participants express differing views on the best approach to handle input in C, particularly regarding the use of gets versus scanf. There is no consensus on a single solution, as multiple methods are proposed and debated.
Participants note that the behavior of input functions can vary based on compiler settings and configurations, and that mixing different input methods may lead to unexpected results.
Individuals learning C programming, particularly those interested in input handling and debugging common issues related to user input in console applications.
Erised
Problem in C, please help :)
Hello all, So I'm learning C nowadays and I got stuck at this rather simple program. I have no idea what the problem in the program is so I hope someone can help.
The program is for reading the number of students in a class, likewise reading their names and scores in sci, math and english and then calculating the average and displaying the names and avg.#include<stdio.h>
#include<conio.h>
main()
char name[25];
float Sci, Math, Eng, average;
int n,i;
printf("Enter the number of students\n");
scanf("%d",&n);
for(i=0; i<n; i++)
puts("\nEnter name");
gets(name);
printf("\nScience=");
scanf("%f",&Sci);
printf("\nMath= ");
scanf("%f",&Math);
printf("\nEnglish= ");
scanf("%f",&Eng);
average=(Sci+Math+Eng)/3;
puts("\n\nName:");
puts(name);
printf("\nAverage Score= %f", average);
getch();
Now the problem is-
When i run the program, it first asks me to enter the no of students, after that it prints 'enter name' and 'science=' at the same time instead of waiting for me to enter the student's name in response to the 'enter name'.
So I only have the option of entering the scores and finally it displays 'Name:' and a blank line followed by the average.Another program with a for loop only for gets and puts works fine for a specified number of students works(I removed the score and average part), the problem comes in when i put the 'enter the number of students' statement and make the program for 'n' students instead of using a number there.
I'm using Dev C++ for programming, please help me out if anyone knows what the problem is. Okay I tested it on Turbo C++ IDE and it still shows the same problem.
Technology news on Phys.org
Hi...ı have changed ur gets statemant..please check ıt..ıt works now well...
Please chck code below..ı have modıfıed ıt..
#include<stdio.h>
#include<conio.h>
main()
char name[25];
int n,i;
scanf("%d",&n);
for(i=0; i<n; i++)
scanf("%s",&name);
scanf("%f",&Sci);
printf("\nMath= ");
scanf("%f",&Math);
scanf("%f",&Eng);
puts("\n\nName:");
puts(name);
getch();
Now the problem is-
Yeah, the above post got it.
puts, and gets are intrinsic functions, and unless you put a mechanism to pause the compiler will code in the next lines of instruction for the machine to operate.
scanf, which normally interprets from the terminal, will automatically pause for input. It's part of its defined function.
There's a funct. that pauses, but I can't recall it right now. And I don't have my reference handy.
And the hacks are a lurchin' and I can't even pull off a decent search. Dreaded dead-end beatniks at the beck and call, but that's my prob. I guess.
gets, though, is really designed to pull from another data stream than the std kbd input. Like a data file. Where it really shines, in its concise handling, and speed thereof.
@brk235,
Shouldn't it be scanf("%s",name); without the ampersand
Anyway, this wouldn't allow me to enter a proper full name like 'John Smith'. When I executed the code, it let me enter the name but not the scores in the first loop :-/
The output looked like this:
Enter the number of students:
Enter Name
John Smith
Science=
Math=
English=
Name:
John
Average=some garbage value
Enter name
(doesn't let me type the string)
Science=
Math=
English=
20[/U]
Name:
Smith (from the string that I entered the first time)
Average =20.000
Enter Name
___
Thanks for helping..
@delta_moment
Is system("pause"); the command you're talking about? Hmm it doesn't work. The gets(name); isn't being executed by the compiler. It just skips that statement:/
But a simple program like the one below works just fine.
main()
char name[25]
int i;
for(i=0;i<3,i++)
puts("Enter name");
gets(name);
puts("Name:");
puts(name);
getch();
Could be your compiler, or configuration, or platform.
You may have to point the gets statement at the std. input. I don't know.
There's so many variables these days.
From looking at the code in the latter post, the problem appears when you combine scanf and gets. I'd just say you're throwing the compiler.
It's easy to do, I do it all the time. Just remember, that when a C program is compiled, it's converted to machine language, and the memory/drive/CPU access is all dynamic. Among many other data transfers. And, it's easy to trip out the computer, or yourself.
Some compilers will catch things for you and make assumptions, others will not.
I'm not sure, but since the combination seems to be what's throwing things, for now, I'd just avoid it, and stick to one or the other.
This works:
Code:
#include<stdio.h>
main()
        char name[25];
        int n, i;
        printf("Enter the number of students:  ");
        scanf("%d",&n);
        for(i=0; i < n; i++)
                printf("\nEnter name: ");
                scanf("%s", name);
                printf("\nScience: ");
                scanf("%f", &Sci);
                printf("\nMath: ");
                scanf("%f", &Math);
                printf("\nEnglish: ");
                scanf("%f", &Eng);
                puts("\n\nName:");
                puts(name);
                printf("\nAverage Score = %f\n", average);
Whoever said you don't need to use an ampersand when using scanf with an array is correct, as 'number' is already a pointer to number[0]. Ampersands says the address of n, which gives scanf the address of n. Scanf is a bad function to use to, as it's possible to overflow buffers. Try using sscanf as you can specify input length, format etc.
http://www.cplusplus.com/reference/clibrary/cstdio/sscanf.html
Code:
Enter the number of students:  12
Enter name: Karl
Science: 13.1
Math: 11.1
English: 2.2Name:
Karl
Average Score = 8.800000
The next thing to learn, would be to use a struct to do the same thing.
