| Thread Closed |
[SOLVED] Kinematics in 2-dimesions |
Share Thread | Thread Tools |
| Jan30-08, 01:15 PM | #1 |
A soccer player kicks the ball toward a goal that is 25.0 m in front of him. The ball leaves his foot at a speed of 19.2 m/s and an angle of 65.8 ° above the ground. Find the speed of the ball when the goalie catches it in front of the net. (Note: The answer is not 19.2 m/s.) 2. Relevant equations x=V(0)t+(1/2)gt^2 V^2=V(0)^2+2gy V= sqrt(Vx^2+Vy^2) 3. The attempt at a solution Ok let me define all the variables I've got so far V(0)= 19.2 Vx0= 7.87 x= 25 (12.5 for one half) gx= 0? (not so sure about this one) Vx= ?(at top of apex ) Vy= 0 (at top of apex) gy=-9.8 y= 15.626 Vy0= 17.5 (initial y veolicty) Ok so the first thing I did was find the inital velocity for the x and y componets using sine and cosine, so V0x= 19.2cos65.8= 7.87 V0y=19.2sin65.8= 17.5 I then used my inital y velocity to find out the heigth (y distance) of the shot Vy^2= Vy0^2+2gy 0= (17.5)^2+2(-9.8)y y= 15.625 I'm unsure where to go now in order to out the speed of the ball when the goalie catches it i know that V= sqrt (Vx^2+Vy^2). Should i try and figure out the two final velocities and then plug them into that equation? |
| Jan30-08, 01:53 PM | #2 |
You need to find the time at which the ball reaches the position of the net. What you've written as [tex]g_x[/tex] is actually just acceleration in the x-direction, g is simply used to denote gravitational acceleration (which only occurs in whats defined as the y-direction in this problem). If air resistance is ignored, acceleration in the x-direction is 0.
Thus you know speed in the x-direction will not change over the course of the motion. Once you've found the time, you need to find the x and y velocities, and as you said, the square root of the sum of their squares is the speed at that point. |
| Jan30-08, 02:04 PM | #3 |
Ahhh i see it now, the height wasn't even needed in this problem, thanks for the tip.
| Thread Closed |
| Thread Tools | |
Similar Threads for: [SOLVED] Kinematics in 2-dimesions
| [SOLVED] 2D Kinematics Help | Introductory Physics Homework | 10 | ||
| Extra Dimesions (the Calabi-Yau shape) | Beyond the Standard Model | 1 | ||
| How the dimesions fit in | General Physics | 1 | ||
| Dimesions | General Physics | 6 | ||
| F theory and curled dimesions | Beyond the Standard Model | 12 | ||
