Thread Closed
Maximum Amplitude, 50hx vs 60hz generator
Share Thread Thread Tools
Jan30-08, 10:10 PM   #1
We have an AC generator with output current I. I, as a function of time, is a sine wave whose frequency, f, is the same as the rotational frequency of the generator. So,
I(t) = I[tex]_{0}[/tex]sin(2πft), where I[tex]_{0}[/tex] is the max. amplitude of the current.
In terms of magnetic flux, [tex]\Phi[/tex][tex]_{B}[/tex]:
I = - (Constant * Change in [tex]\Phi[/tex][tex]_{B}[/tex]) / time
When the generator revolves at 50 revs/second, the maximum amplitude I[tex]_{0}[/tex] = 1000 A. If you increase the spead of the generator to 60 revs/sec, what is the maximum amplitude I[tex]_{0}[/tex]?
2. Relevant equations
Given above
3. The attempt at a solution
This question really stumped me. It's difficult to bring in additional equations since we don't know more about the generator -- it's obviously a concept question. I suspect that the maximum amplitude will increase proportionally.
We know that f(old) = 50 Hz, since it will be the same as the rotatation frequency. Thus, the period for this sine curve will be 1/50 second, as the amplitude goes from maximum to maximum. When f(new) = 60 Hz, the period will condense to 1/60 second.
Thinking about flux, there is no change in magnetic field (B) -- though the [tex]\Theta[/tex] between B and the area of the coil will be changing faster as rotations speed up. So change in fluz would be greater over a given unit of time (???). Thus, from the second equation, we know that I must also increase (???).
At this point, I simply guess that the change will be proportional -- since rotation is increasing in speed by 20%, so will maximum amplitude ??????????????
Thanks for your help!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Thread Closed
Thread Tools
Similar Threads for: Maximum Amplitude, 50hx vs 60hz generator
Thread Forum Replies
Period, amplitude, maximum speed, and total energy Introductory Physics Homework 0
Why 220@50hz and 120@60hz? Electrical Engineering 21
60hz supply - effect on psu output? Electrical Engineering 1
What do I need in order to use 110V 50Hz air condition to a place which has 220v 60Hz Electrical Engineering 2
what happens to the maximum velocity if you double both Amplitude and period of a SHM Introductory Physics Homework 1
