Solve Spring Hooke's law: Stretch of each Spring
The problem involves analyzing the behavior of springs under load, specifically applying Hooke's law to determine the stretch of multiple springs supporting a mattress when a person jumps onto it. The context includes gravitational potential energy and elastic potential energy in the springs.
  • Participants discuss the relationship between potential energy and spring displacement, questioning how to equate gravitational potential energy with elastic potential energy. There is exploration of the correct application of formulas and the implications of spring compression.
Some participants have provided guidance on setting up the equations, while others express confusion about the underlying concepts, particularly regarding the change in potential energy as the springs compress. Multiple interpretations of the problem are being explored, and there is no explicit consensus yet.
Participants are navigating the assumptions about the initial conditions of the springs and the effective height change as the springs compress. There is a focus on understanding the energy transformations involved in the scenario.
zvee_y
[SOLVED] Spring Hooke's law
The innerspring mattress is held up by 23 vertical springs, each having a spring constant of 5000N/m. A 44 kg person jumps from a 1.94m platform onto the innersprings. Assume the springs were initially unstretched and that they stretch equally. Determine the Stretch of each of the springs.
I use the equation mgh=(44)(9.8)(1.94) to find the potential energy. To find the stretch displacement, is it correct if I use Us=(1/2)kx^2 and substitute Us=mgh, k=5000 as given, and find x is the stretch of each springs?
It is if you multiply Us=(1/2)kx^2 by the number of springs and then equate to mgh.
Ok. So i did mgh=44*9.8*1.94=836.528J
Us=(1/2)*5000*x^2*23=836.528J. Find x from there to get stretch displacement. But the answer wasn't right. Did I do anything wrong in here?
As springs stretch(or compress), the person's potential energy also changes by mgx, where x is the stretch in the spring.
but they give h=1.94m. how is it a stretch?
The height is from spring when it is unstretched. When the person jumps on spring, the spring compresses and reduces in length, so the person's effective change in potential energy is mgh +mgx. (Hope I'm clear now)
oh ok i understand what you are explaining now. So to find x, we set it mgh+mgx=(1/2)kx^2*23 ?
can someone please help me with this questionn?? I am confused. :(
Didn't you get the correct answer using the formula in #7 ?
Well i got it right. But i just don't understand how is it mgh+mgx ??
Look, when the person is about to touch the bed (i.e springs), the change in PE is mgh; now as the springs compress, the person (along with spring) goes down (try to visualize the situation), and its PE further decreases.
Some other PF guy may give you a better explanation if my explanation is not clear enough.
There is nothing wrong with Sourabh N's explanation. When the springs are at their maximum compression, there is no kinetic energy. Only potential. So the change in the gravitational potential (over a distance of h+x) and potential in the springs (over a distance x) must be equal.
hehe Thank you. I think i got it. Just never think about that equation you know. Thanks a lots. Yes now i even understand more through DIck's explanation. mg(h+x)=(1/2)kx^2*23 hhehe...i totally got it now.
  • · Replies 35 ·
  • · Replies 17 ·
  • · Replies 24 ·
