Checking: Circle Equations Questions
  • Thread starter Thread starter DizzyDoo
    Circle
The discussion focuses on solving circle equations in a homework context. For the first problem, the equation of the circle with center (3, 4) and passing through (8, -8) is correctly derived as (x-3)² + (y-4)² = 169. In the second problem, the equation x² + y² + 4x + 6y – 17 = 0 is transformed to (x+2)² + (y+3)² = 30 after completing the square. The third problem requires finding the exact length of the diameter and the midpoint, with the correct length being √26 instead of the approximate value of 5.09.
  • Understanding of circle equations and their standard forms
  • Knowledge of completing the square method
  • Familiarity with the distance formula for calculating lengths between points
  • Ability to find midpoints of line segments
  • Study the derivation of the standard form of a circle equation
  • Practice completing the square with various polynomial equations
  • Learn how to calculate the distance between two points using the distance formula
  • Explore methods for finding midpoints in coordinate geometry
Students studying geometry, particularly those focusing on circle equations, as well as educators looking for examples of common mistakes and corrections in solving these types of problems.
DizzyDoo
[SOLVED] Checking: Circle Equations Questions
Last time I got people to check my homework here, I got things marked wrong when they where said to be right. Let's see if it happens again...
(1) The circle C has centre (3, 4) and passes through the point (8, 8).
Find an equation for C.
(2) Find the centre and radius of the circle x² + y² + 4x + 6y – 17 = 0
(3) A(4, 0) and B(3, 5) are the end points of a diameter of the circle C.
Find (a) the exact length of AB,
(b) the coordinates of the midpoint P of AB,
(c) an equation for the circle C.
None
Right here is my working for (1)
Since we know the circle centre and a point the circle passes through, I can use pythag to work on the radius right? It seems a little too simple to work, but I can't see anything wrong with it. After drawing a clear diagram;
(4+8)² + 5² = r²
r² = 144 + 25
r² = 169
r = 13
Therefore the equation must be (x-3)² + (y-4)² = 13
Correct?
Now, my working for (2);
The equation needs to be factorised, so I have to "complete the square" to get the stuff inside the brackets. This is usually where I go wrong, so check this bit carefully please!
(x+2)² - 4 + (y+3)² - 9 - 17 = 0
Rearraged:
(x+2)² + (y+3)² = 17
Ah, I have to go now, but I'll post the answers to 3 quickly:
a) I got 5.09
b) x = 3.5
y = 2.2
and
c) (x+3.5)² + (y+2.2)² = 5.09
Sorry about that lack of working out. Thank you for your time if you've read this far!
1) looks fine. I would make 2) to be (x+2)^2+(y+3)^2=30. Is that just a typo? For 3) they ask for the EXACT value of the length of AB, so I would write sqrt(26) rather than the approximation 5.09.
Thanks! Gotta hand it in later today, so we'll see if I've got them right.
