Solve Surface Integral for xy-Plane Projection
The discussion focuses on converting a surface integral into a double integral for the projection of a paraboloid defined by z = x^2 + y^2, specifically between z = 0 and z = 1. The user successfully identifies the projection region D in polar coordinates as D = {(r, θ) | 0 ≤ r ≤ 1, 0 ≤ θ ≤ 2π}. The differential area element is expressed as dS = √(1 + (2x)^2 + (2y)^2) dA, leading to the transformation of the surface integral into a double integral format. The user expresses confusion regarding the limits of integration and the implications of changing the bounds of z.
  • Understanding of surface integrals and their applications in multivariable calculus.
  • Familiarity with polar coordinates and their conversion from Cartesian coordinates.
  • Knowledge of differential area elements in the context of surface integrals.
  • Basic concepts of paraboloids and their geometric properties.
  • Study the derivation of surface integrals and their conversion to double integrals.
  • Learn about the geometric interpretation of projections in multivariable calculus.
  • Explore the implications of changing bounds in surface integrals, particularly with paraboloids.
  • Investigate the use of Jacobians in transforming integrals between coordinate systems.
Students and educators in multivariable calculus, particularly those focusing on surface integrals, geometric interpretations, and integral transformations.
awvvu
I'm not sure how to convert this surface integral into a double integral for evaluation.
[tex]\iint_S \frac{1}{1 + 4(x^2 + y^2)} dS[/tex]
S is the portion of the paraboloid [itex]z = x^2 + y^2[/itex] between z = 0 and z = 1.
How do you project this onto the xy-plane? From z = 0 to z = 1, we get circles of increasing radius. So do I just take z = 1, which is a circle of radius 1, and make the region:
[tex]D = \{(r, \theta) | 0 <= r <= 1, 0 <= \theta <= 2 \pi\}[/tex]
Also, I know:
[tex]dS = \sqrt{1 + (2x)^2 + (2y)^2} dA = \sqrt{4r^2 + 1} dA[/tex]
[tex]\iint_S \frac{1}{1 + 4(x^2 + y^2)} dS = \iint_D \frac{r}{1 + 4r^2} \sqrt{4r^2 + 1} dA[/tex]
I just don't know what the limits should be. The region I chose gives me the right answer but I'm not sure exactly why the projection was when z = 1. What if it was the paraboloid between z = 1 and z = 2 then? Do I have to split up the surface integral to be the circle at z = 1 and the paraboloid surface? I'm really confused about this projection stuff.
The plane z=a cuts the paraboloid in the circle a=x^2+y^2. So the domain in the x,y plane is x^2+y^2<=a or r^2<=a. If the limits were z=1 to z=2, then the r limits would be r=1 to r=sqrt(2).
