Calculating Work Out for a Sterling Engine
  • Context: Graduate
  • Thread starter Thread starter ofathens
    Engine Work
This discussion focuses on calculating the efficiency of a Stirling engine using the formula for thermal efficiency, n_th = W_out / Q_in. The work output (W_out) is derived from the torque (τ) and angular displacement (Δθ) of the wheel, with τ calculated as τ = αI, where α is angular acceleration and I is the moment of inertia. The conversation highlights the challenges of accurately measuring input heat and the impact of friction and air resistance on performance. An alternative method proposed involves using a weight attached to a rope wrapped around the wheel to measure power output more effectively.
  • Understanding of Stirling engine mechanics
  • Familiarity with thermodynamic efficiency calculations
  • Knowledge of rotational dynamics, including torque and angular acceleration
  • Basic principles of mechanical energy and power measurement
  • Research Stirling engine efficiency calculations and performance metrics
  • Learn about torque and angular momentum in rotational systems
  • Explore methods for measuring power output in mechanical systems
  • Investigate the effects of friction and air resistance on engine performance
Engineers, physics students, and hobbyists interested in thermodynamics and mechanical efficiency, particularly those working with Stirling engines or similar thermodynamic systems.
ofathens
I was reading a list of science experiment ideas, and came across one that intrigued me: calculating the efficiency of a sterling engine.
We can say that the efficiency n_th is:
n_th = W_out / Q_in
Assuming we are heating the engine with a beaker of hot water,
Q_in = m * c * [tex]\Delta[/tex]T
But how would we calculate work out? If the engine is making a wheel spin, as most sterling engines do, then we could calculate the work out as a rotational analog of the definition of work:
W_out = [tex]\tau[/tex][tex]\Delta\theta[/tex]
Where [tex]\tau[/tex] is the torque on the wheel, which we could substitute with
[tex]\tau[/tex] = [tex]\alpha[/tex]I
Where [tex]\alpha[/tex] is the angular acceleration, and I is the moment of inertia of the wheel.
Thus, we must be able to calculate the angular acceleration of the wheel, as well as its moment of inertia. Is this the easiest way to do this? How else could we measure the effieciency of a sterling engine?
Science news on Phys.org
Calculating work put into kinetic energy of a wheel would almost certainly give very poor results, because:
1. You need a long time to measure input heat accurately (you need to asume that input heat is much larger than the change of internal energy of the engine). However you can't accelerate a wheel with the full engine's power for a long time, because of the friction and air resistance.
2. Moving parts inside the engine are also accelerating, so wheel does not get the full power.
I would rather chose this method:
Let the engine propel the wheel that has very little friction, but a rope carriing a weight with mass m is wrapped several times around the wheel. On one side rope should be hanging free (but strained with weigth force), on the other side it should be fixed. If the rope is wrapped so many times, that the force on the fixed point is negligible, then the force sloving down the wheel is:
F=m*g
And power is: P=m*g*v=m*g*2*Pi*r*rotation frequency
You would probably want to maximize power by selecting a proper weight mass (since the rotation frequency will be dependent of the brake force)
  • · Replies 138 ·
9K
  • · Replies 60 ·
