| Thread Closed |
My tricky wave problem. ehh its probably not tricky. |
Share Thread | Thread Tools |
| Feb4-08, 06:40 PM | #1 |
a wave on a cable, mass per unit length(mu) 1.70 kg/m, is created by a machine providing 250(p) W of power. It creates waves of wavelength(lambda) 2.90 m and an amplitude(A) 2.90 m. What's the speed of these waves? 2. Relevant equations v = lamda/frequency k = 2pi/lamda w = 2pi/t = 2pi*frequency etc 3. The attempt at a solution i am given mu , p , a , lamba as well i can find k Since they give power and that is a main equation in the chapter, I would use the equation: p = (1/2)mu * w^2 * A^2 * v and solve for v. simple. butttt I simply cannot find the correct equation to find "w" the angular frequency. Every equation I've looked at it seems I'm just short 1 variable. if I could find T(period) or w(angular frequency) or f(frequency) I could figure out the solution. This is my first time checking out these forums. Any input would be greatly appreciated! ** ill be online refreshing constantly for the next couple hours : ) ** |
| Feb4-08, 10:57 PM | #2 |
sry to "bump" if its not allowed.
I considered setting 2 velocity equations equal to eachother and solving for the variables. [ f * wavelength = square root ( T / mu ) ] If I could solve for f or T I could get the final velocity. Yet that proposes 2 unknown variables so I believe I am still stuck. The assignment is due in about an hour so I'll continue to check until then! Thanks everyone! |
| Feb4-08, 11:09 PM | #3 |
Recognitions:
What happens when you substitute [tex]\omega = 2\pi f = \frac{2\pi v}{\lambda}[/tex]
| Feb4-08, 11:33 PM | #4 |
Thanks for the help! I thought of something similar to that to isolate v. I substituted your suggestion into the original equation. It seemed kind of long and drawn out as if there must be a simpler way. I doubt I have any simple math errors.
The answer turned up to be incorrect. I attached the full pic of the work either way. http://www.uploadyourimages.com/view...0204082330.jpg I have 27 min left. oooo this is getting close. |
| Feb4-08, 11:45 PM | #5 |
Recognitions:
If P=(1/2)*mu*w^2*A^2*v, and w=(2pi)/f and v=lambda/f, it would seem that w=(2pi*v)/lambda. it seems to me you know everything in the P equation except for v. Can't you just solve for it?
| Feb4-08, 11:49 PM | #6 |
Recognitions:
| Feb4-08, 11:53 PM | #7 |
Recognitions:
w has the units of 1/sec. (2pi*lambda/v) has the units of sec. (2pi*v)/lambda has the units of 1/sec. Which do you believe? Keeping track of units is G*d's gift to man. Uh, and women.
| Feb4-08, 11:57 PM | #8 |
so I probably should have used (2pi*v)/lambda
and I suppose im just dumb then... I cannot figure out the simple way to solve for the answer than how I did it. I simply plugged in for w the equation and solved the rest. meza please elaborate more if you could. |
| Feb5-08, 12:03 AM | #9 |
Recognitions:
You get v^3 on one side and a bunch of numbers on the the other. Then just take a cube root. Keep track of the units and make sure your answer comes out in m/sec. Otherwise, it's garbage.
| Feb5-08, 12:10 AM | #10 |
yea as I'm working the equation, if I would have used [(2pi*v)/lambda] instead of [(2pi*lambda)/v] I would have gotten it correct. I get v^3 equal to a #m/s.
times up, oh well. but thanks dick! but in doing that I just did the same as before, I simply plugged that as w and solved P=(1/2)*mu*w^2*A^2*v yet meza suggests I made that insanely difficult and that I need to re-look into basic algebra. (albeit he suggested an incorrect equation) Can one of you maybe elaborate on what I am totally overlooking then in that aspect? Thanks dick and meza though for all your help! |
| Feb5-08, 12:15 AM | #11 |
Recognitions:
You got the v and lambda inverted in the w solution. No big deal, it happens to everyone. But learn how to check your work by tracking units. You can find a lot of mechanical errors that way.
| Feb5-08, 12:24 AM | #12 |
Recognitions:
My original equation was incorrect. Sorry about that. I had the v and lambda exchanged. In anycase, the equation as given is:
[tex]P = \frac{1}{2}v \mu \omega^2 A^2[/tex] You know P, you know mu, you know A. Omega can be expanded into: [tex]\omega = 2\pi f = \frac{2\pi v}{\lambda}[/tex] which means the only unknown variable here is v: [tex]P = \frac{1}{2}v \mu 4 \pi^2 v^2 A^2[/tex] |
| Feb5-08, 12:26 AM | #13 |
Recognitions:
Units checking goes for you as well, mezarashi!
| Feb5-08, 12:34 AM | #14 |
Recognitions:
And now I feel guilty he couldn't complete his question on time >_< |
| Feb5-08, 12:40 AM | #15 |
yup! I redid the equation just like that and got it correct, regardless if I didn't get any points.
I did the same work as the first time, just switched that equation. http://img149.imageshack.us/img149/8...5080033qn2.jpg But I'm still hung up on, "If you were to have taken my suggestion, and done the substitution, you will find that you are only solving a simple algebraic equation of the 1st degree. That is, ax + b = c, solve for x where a,b,c are constants. With the best of intentions, I suggest you take up some tutoring on algebra if you honestly find solving such a problem difficult." ????? what was wrong with the way I did it? Using that exact formula, I can't see how I was so wrong in what I did. ![]() ha dont worry about it mez, I'm just happy someone even offered to help me out! |
| Feb5-08, 12:57 AM | #16 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: My tricky wave problem. ehh its probably not tricky.
| Tricky problem | Advanced Physics Homework | 2 | ||
| Tricky Problem (at least for me) | Introductory Physics Homework | 1 | ||
| A Tricky Problem | Differential Equations | 4 | ||
| Tricky Tricky little Identities | General Math | 2 | ||
