| Thread Closed |
"Quantum efficiency" of photon detectors |
Share Thread | Thread Tools |
| Feb5-08, 05:05 AM | #1 |
I am looking for a precise definition of "quantum efficiency"
of photon detectors, and also for information on how this is measured in practice. The context is the following. "Entangled" pairs of photons are generated by "parametric downconversion". A laser beam is shined on a certain kind of crystal. The crystal converts each absorbed photon into two photons, traveling in different directions, each with half the frequency (hence energy) of the absorbed photon. The downconverted beams travel until they reach two spacelike separated observers, traditionally called Alice and Bob. Alice and Bob each have a photon detector which can detect a photon with polarization "up" or "down", relative to an arbitrary direction (which each can specify, independently). They set their detectors in various directions and later get together to see if there was any correlation between the polarizations of their detected photons. Quantum mechanics predicts statistical correlations which are classically impossible. Alice <-------------- Crystal ---------------> Bob | | | Laser A problem in interpreting this experiment is that the detectors are typically inefficient, failing to detect some photons. Often, Bob will detect a photon, but Alice will not detect hers. These are called "singles" events, as opposed to "doubles", in which Alice and Bob each detects a photon at the same time. Since correlation of polarizations is meaningless for singles, they are excluded from the data to be analyzed. The only meaningful data are the doubles. The quantum mechanical predictions assume perfect detectors. But if we restrict our analysis to the doubles, how do we know that our sample of doubles is statistically identical to the sample of all photons? This is the so-called "fair sampling" or "detection" loophole, which leaves open classical explanations for results which would be classically impossible with perfect detectors. Physicists have been trying to close this loophole for about 50 years. It remains open, at least for the above experiment with photons. [A paper posted in the arXiv within the past month claims to close the "detection loophole" in an experiment using massive particles (ions) instead of photons. Are there any experts out there willing to venture an opinion on its significance? The reference is: D.N. Matsukevich, P. Maunz, D.L. Moehring, S. Olmschenk, and C. Monroe, "Bell inequality violation with two remote atomic qubits", arXiv:0801.2184 [quant-ph] ] Now for my questions. In analysis of such experiments, the "quantum efficiency" of the detectors is often mentioned, but I have never found a precise definition of this quantity in the literature. How is it defined, and how is it measured in practice? I can guess several plausible definitions, but I'm not sure they are equivalent. I'm particularly interested in the measurement question. In the above experiment, one plausible definition of "quantum efficiency" calculates it with a formula involving the ratio of singles to doubles. Another plausible definition would be possible if there were a way to determine the number of photons/sec in Alice's beam. Then one could define the quantum efficiency as the ratio of the number of photons/sec detected to the number of photons/sec present. The interest of this would be that it would determine the quantum efficiency independently of knowing the ratio of singles to doubles. Then one could use the observed ratio of singles to doubles as an experimental test to possibly rule out a classical explanation for the results. (If the quantum efficiency were *defined* as a function of the ratio of singles to doubles, this would be circular.) In principle, the number of photons/sec in Alice's beam could be determined by calorimetric experiments because all the photons in the beam have the same frequency, and hence the same energy via Planck's formula. From the heat produced by absorbing Alice's beam, one could deduce the number of photons/sec. But I have no idea if this might be experimentally possible. A recent paper quotes 10,000 singles/sec in Alice's beam, corresponding to a power of 5 x 10^(-8) ergs/sec. Is there any hope of measuring a heat/sec this small? While I'm writing, let me throw out another question. In papers describing experiments like the above, I have seen statements like: "The two-photon visiblity is 99%". What is the precise meaning of "two-photon visibility" in this context? This seems to be a different "visibility" than the quantity generally mentioned in interference experiments (which measures the "strength" of an interference pattern). |
| Feb7-08, 05:00 AM | #2 |
Stephen Parrott wrote:
> Now for my questions. In analysis of such experiments, > the "quantum efficiency" of the detectors is often mentioned, but I > have never found a precise definition of this quantity in the literature. > How is it defined, and how is it measured in practice? In high energy physics, we characterize photon detectors by quantum efficiency, which is the probability of getting a signal given that a photon of the appropriate wavelength is incident on the detector. A typical photo-multiplier tube has a quantum efficiency around 20% -- so for a blue photon incident on its photocathode, there is a 20% probability that it will release a photoelectron that gets captured into the dynode chain and generates a signal at the output (typical signals are a few tens of millivolts into 50 Ohms). The manufacture typically provides a graph of quantum efficiency as a function of photon wavelength. A better photon detector is the Visible Light Photon Detector (VLPC), which has a quantum efficiency around 80%. This is a glorified silicon photodiode cooled to ~10K. In HEP we usually want to detect charged particles, and do that by coupling a scintillator to a photon detector. By designing the detector to put 10 or more photons into the photodetector for a typical particle, we get excellent overall efficiency, even with a mere 20% photon efficiency. This does not apply to EPR-type experiments using photons, of course. Quantum efficiency can be measured by using a calibrated light source attenuated down to a few thousand photons per second. > In papers describing experiments like the above, I have seen > statements like: "The two-photon visiblity is 99%". What is the > precise meaning of "two-photon visibility" in this context? > This seems to be a different "visibility" than the quantity > generally mentioned in interference experiments (which measures > the "strength" of an interference pattern). I've not seen that term. But it seems related to efficiency. To me, a two-photon efficiency of 99% for visible photons seems unlikely. For N photons simultaneously incident on a detector with quantum efficiency e, the overall detection probability with a single-photon threshold is: P(N) = 1 - (1-e)^N For N=2 and e=.8, which is the best visible photon detector I know of, that gives 96%. Note that for UV or higher-energy photons, higher quantum efficiencies are possible, approaching 99% for few-MeV gammas. Tom Roberts |
| Feb8-08, 05:00 AM | #3 |
"Stephen Parrott" <postnews@email.toast.net> wrote in message news:47A6B0C2.1090003@email.toast.net... ... > The downconverted beams travel until they reach two spacelike > separated observers, traditionally called Alice and Bob. Alice and Bob > each have a photon detector which can detect a photon with polarization > "up" or "down", relative to an arbitrary direction > (which each can specify, independently). They set their detectors in > various directions and later get together to see if there was any > correlation between the polarizations of their detected photons. > Quantum mechanics predicts statistical correlations > which are classically impossible. > > Alice <-------------- Crystal ---------------> Bob > | > | > | > Laser > > A problem in interpreting this experiment is that the detectors > are typically inefficient, failing to detect some photons. Often, > Bob will detect a photon, but Alice will not detect hers. These are > called "singles" events, as opposed to "doubles", in which Alice and > Bob each detects a photon at the same time. Since correlation > of polarizations is meaningless for singles, they are > excluded from the data to be analyzed. The only meaningful data are > the doubles. > > The quantum mechanical predictions assume perfect detectors. > But if we restrict our analysis to the doubles, how do we know that > our sample of doubles is statistically identical to the sample of > all photons? This is the so-called "fair sampling" or "detection" > loophole, which leaves open classical explanations for results > which would be classically impossible with perfect detectors. > Physicists have been trying to close this loophole > for about 50 years. It remains open, at least for the above > experiment with photons. ... I have long wondered how unreliable detectors affect the "collapse of the wave function." Discussions of QM measurement assume perfect detection, which then must collapse the WF since it can't be elsewhere. But what if the detector misfires or fails to detect, then what "happens" to the wave? We don't even know when or if this happened, despite the concept of "knowledge" being presumed critical to measurement in QM. It reminds me of the Renninger negative measurement, where failure to detect the particle (in a case where the detector is reliable) means that the particle must be elsewhere - that is a case of "reallocation" rather than "collapse" of the WF. |
| Feb8-08, 05:00 AM | #4 |
Tom Roberts wrote:
> Stephen Parrott wrote: >> Now for my questions. In analysis of such experiments, >> the "quantum efficiency" of the detectors is often mentioned, but I >> have never found a precise definition of this quantity in the literature. >> How is it defined, and how is it measured in practice? > > In high energy physics, we characterize photon detectors by quantum > efficiency, which is the probability of getting a signal given that a > photon of the appropriate wavelength is incident on the detector. A > typical photo-multiplier tube has a quantum efficiency around 20% -- so > for a blue photon incident on its photocathode, there is a 20% > probability that it will release a photoelectron that gets captured into > the dynode chain and generates a signal at the output (typical signals > are a few tens of millivolts into 50 Ohms). The manufacture typically > provides a graph of quantum efficiency as a function of photon wavelength. Thank you. That's all very helpful, though it doesn't entirely answer my questions. As you say, the idea of "quantum efficiency" seems to be the ratio of photons detected to photons received. But I still am not clear on how one measures photons received. I don't see how that could be done unless one had a detector with 100% efficiency, or at least a precisely known efficiency, or some independent method which relates number of photons to some other measurable quantity such as energy. > >> In papers describing experiments like the above, I have seen >> statements like: "The two-photon visiblity is 99%". What is the >> precise meaning of "two-photon visibility" in this context? >> This seems to be a different "visibility" than the quantity >> generally mentioned in interference experiments (which measures >> the "strength" of an interference pattern). > > I've not seen that term. But it seems related to efficiency. > > To me, a two-photon efficiency of 99% for visible photons seems > unlikely. For N photons simultaneously incident on a detector with > quantum efficiency e, the overall detection probability with a > single-photon threshold is: > P(N) = 1 - (1-e)^N > For N=2 and e=.8, which is the best visible photon detector I know of, > that gives 96%. Note that for UV or higher-energy photons, higher > quantum efficiencies are possible, approaching 99% for few-MeV gammas. A typical statement of that type is the following, from "An experimental test of non-local realism" by S. Groeblacher, et. al., Nature 446 (2007), 871-875, arXiv:0704.2529v1 [quant-ph]. At the bottom of p. 5 (arXiv version) they write: "The two-photon visibilities are approximately 99.0 +- 1.2%... which - to our knowledge - is the highest reported visibility for a pulsed SPDC scheme." Their photons have wavelength 395 nm, which is on the border between visible blue light and low-energy ultraviolet. |
| Feb8-08, 05:00 AM | #5 |
[To the moderator (please remove before posting): this is a re-edit of
the post I submitted yesterday. Please ignore the previous submission and post only this one if possible. Thanks.] On 5 Feb, 11:04, Stephen Parrott <postn...@email.toast.net> wrote: > I am looking for a precise definition of "quantum efficiency" > of photon detectors, and also for information on how this is > measured in practice. The context is the following. > > "Entangled" pairs of photons are generated by "parametric > downconversion". A laser beam is shined on a certain kind of crystal. > The crystal converts each absorbed photon into two photons, > traveling in different directions, > each with half the frequency (hence energy) of the absorbed photon. > > The downconverted beams travel until they reach two spacelike > separated observers, traditionally called Alice and Bob. Alice and Bob > each have a photon detector which can detect a photon with polarization > "up" or "down", relative to an arbitrary direction > (which each can specify, independently). They set their detectors in > various directions and later get together to see if there was any > correlation between the polarizations of their detected photons. > Quantum mechanics predicts statistical correlations > which are classically impossible. > > Alice <-------------- Crystal ---------------> Bob > | > | > | > Laser > > A problem in interpreting this experiment is that the detectors > are typically inefficient, failing to detect some photons. Often, > Bob will detect a photon, but Alice will not detect hers. These are > called "singles" events, as opposed to "doubles", in which Alice and > Bob each detects a photon at the same time. Since correlation > of polarizations is meaningless for singles, they are > excluded from the data to be analyzed. The only meaningful data are > the doubles. > > The quantum mechanical predictions assume perfect detectors. > But if we restrict our analysis to the doubles, how do we know that > our sample of doubles is statistically identical to the sample of > all photons? This is the so-called "fair sampling" or "detection" > loophole, which leaves open classical explanations for results > which would be classically impossible with perfect detectors. > Physicists have been trying to close this loophole > for about 50 years. It remains open, at least for the above > experiment with photons. > Now for my questions. In analysis of such experiments, > the "quantum efficiency" of the detectors is often mentioned, but I > have never found a precise definition of this quantity in the literature. > How is it defined, and how is it measured in practice? The single count rate is given by (1) N1=e1*A , where A is the activity of the source (decays/sec) and e1 the overall detection efficiency for channel 1 (which not only includes the quantum efficiency of the detector, but also a transmission efficiency due to losses in the optics, and a geometrical factor (associated with the assumption of the photons being discrete particles and the detector only having a finite size)). So assuming statistical independence, the coincidence (double) count rate is then (2) N1,2=e1*e2*A , where e2 is the corresponding efficiency for channel 2 . And if you now take the ratio N1,2/N1=e2 and correspondingly N1,2/N2=e1, you know the overall detection efficiencies. This is, as far as I am aware, the only practical way to do it, because usually you don't know the activity A for sure (which in this way drops out). However, there is a potential flaw with Eq.(2): the point is that if you have correlated emissions (like in these kind of experiments), one would have to assume (because of angular momentum conservation) that the two photons are emitted exactly into opposite directions, i.e. (assuming the experiment is properly aligned) photon 2 should reach the detector whenever photon 1 reaches the detector; in other words, the geometrical efficiency is not statistically independent anymore, so if in general you have e1=e1_g*e1_q and e2=e2_g*e2_q (neglecting transmissive losses) , you would have here e2_g=1, and thus the coincidence count rate would be (3) N1,2 = e1_g*e1_q*1*e2_q*A rather than (4) N1,2 = e1_g*e1_q*e2_g*e2_q*A as for the statistically independent case (which is usually assumed here). This means that (5) N1,2/N1= e2_q instead of (6) N1,2/N1= e2_g*e2_q . But if one assumes a typical quantum efficiency e2_q=0.2 , Eq.(5) (which should apply for correlated emissions) would not be consistent with observations at all, as typically N1,2/N1=10^-3. This circumstance (and some others as well) has actually led me to formulate a theory for the photodetection process (see http://www.plasmaphysics.org.uk/photoionization.htm ) which not only could explain this discrepancy, but indeed also the outcome of the Bell test experiments in terms of semi-classical physics (at least as far as those involving light are concerned). In a nutshell: for crossed polarizers, the electromagnetic field in the two channels is anti-correlated (rather than correlated as for parallel polarizers) and this leads only to a very small probability of simultaneous photodetection considering the statistical nature of the process; see http://www.physicsmyths.org.uk/bell.htm for more). > While I'm writing, let me throw out another question. > In papers describing experiments like the above, I have seen > statements like: "The two-photon visiblity is 99%". What is the > precise meaning of "two-photon visibility" in this context? > This seems to be a different "visibility" than the quantity > generally mentioned in interference experiments (which measures > the "strength" of an interference pattern). As I understand it, 'visibility' is defined here as (N1,2_max- N1,2_min)/(N1,2_max+N1,2_min) , where N1,2_max is the coincidence count rate for parallel polarizers, and N12_min for crossed polarizers. > [A paper posted in the arXiv within the past month claims > to close the "detection loophole" in an experiment using > massive particles (ions) instead of photons. Are there any > experts out there willing to venture an opinion on its > significance? The reference is: > > D.N. Matsukevich, P. Maunz, D.L. Moehring, S. Olmschenk, and > C. Monroe, "Bell inequality violation with two remote atomic > qubits", arXiv:0801.2184 [quant-ph] ] This experiment apparently still involved coincidence detection of photons, and thus the issues associated with the photodetection process remain. Thomas |
| Thread Closed |
| Thread Tools | |
Similar Threads for: "Quantum efficiency" of photon detectors
| Photon "Wave Collapse" Experiment (AJP Sep 2004, Thorn et al.) | General Physics | 5 | ||
| Photon "Wave Collapse" Experiment (Yeah sure; AJP Sep 2004, Thorn...) | Quantum Physics | 128 | ||
| Critique of the "photon" theory of electromagnetic radiation | General Physics | 21 | ||
| how to create "good" quantum states from "good" quantum numbers? | Quantum Physics | 0 | ||
| "strings, branes, & LQG" forum should be "Quantum gravity and theories of everyth | Forum Feedback & Announcements | 0 | ||
