How Far Does a Helium Balloon Stretch a Spring?
The problem involves a helium balloon attached to a spring, with the goal of determining the distance the spring stretches when the balloon is in equilibrium. The context includes concepts from mechanics, specifically forces and potential energy, as well as buoyancy principles.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the forces acting on the balloon, including buoyant force, weight of the balloon, and spring force. There are attempts to set up equilibrium equations, with some confusion about the correct representation of potential energy and the forces involved.
Some participants have provided insights into the forces at play and have attempted to formulate equations for equilibrium. There is ongoing exploration of the correct expressions for forces and potential energy, with no clear consensus yet on the approach or solution.
Participants question the density values used for air and helium, as well as the representation of potential energy terms. There is also mention of the need for clarity on the weight contributions from both the helium and the balloon material.
~christina~
A light spring of constant k= 90.0N/m is attatched to a table vertically.
A 2.00g balloon is filled with helium (d= 0.180kg/m^3) to a volume of 5.00m^3 and is then connected to the spring, causing the spring to stretch as shown. Determine the distance L when the balloon is in equillibrium.
http://img222.imageshack.us/img222/9371/93040485ij0.th.jpg
I think...not sure ...
[tex]K_i + U_i = K_f + U_f[/tex]
[tex]K_i + (U_g + Ui_s) = K_f + (U_g + Ui_s)[/tex]
B= \rho Vg
(B= buoyant force of air)
I know that if it is in equillibrium it would be:
[tex]\sum Fy= 0[/tex]
I'm not sure how to put all this that I compiled together...good grief
first of all I think that
the equation would sort of look like this:
[tex]K_i + (U_gi + Ui_s) = K_f + (U_g + Ui_s)[/tex]
BUT AM I Supposed to use this equation? or...F= kx
and how do I incorperate the buoyant force into that?
[I do know that the weight of the balloon will be a force downward and the spring will be a downward pulling force and the buoyant force is facing up but other than that...well I tried.]
And now I'm officially confused and lost here...:cry:
(I need help setting up the equation)
help please
Thanks
What are the vertical forces acting upward on the balloon? What are the vertical forces acting downward on the balloon? The sum must be zero for equilibrium.
For example, you know that one vert force acting downward is the weight of the balloon. Try to think of all the forces.
(BTW, what are these U terms -- Ui etc? Potential energy?)
well. yes the pot e = Ui (initial potential E [it's a general equation])
forces acting upward on balloon => Buoyancy force of air
Forces acting downward=> weight of balloon & the force of the spring (not sure how to represent that except by F= -kx)
so would it be ...
[tex]\Sum F= F_b - Mg - 1/2 kx^2 = 0[/tex]
somehow this equation looks funny to me.. I'm not sure about that.
Thanks
so would it be ...
Thanks
Restoring force of spring = 1/2 kx^2? Write the correct expression and eqn will become correct.
Note that Mg would be weight of helium + the weight of the material of the balloon itself. You'll need the density of air.
Oh...um
[tex]\Sum F= F_b - Mg - F_s = 0[/tex]
[tex]\Sum F= F_b - g - kx = 0[/tex]
[tex]\Sum F= (1,000kg/m^3)(9.8m/s^2)(5.00m^3) - (0.9kg + 0.002kg)(9.8m/s)- (90.0N/m)(x) = 0[/tex]
I think I'd then solve for x and that should be it right?
Thanks
Where did the M go from the 1st eqn? Anyay, you've included that in the last eqn.
What have you put for density of air? Put the correct density of air and that'll give you the answer.
hi guys I'm new to the forum so hello, I'm a bit stuck on the same question. I didn't use the potential energy method above. But went with Forces.
The only force up is the boyant force which i think is the the volume of the balloon X air density...
5 x 1.29 = 6.45N
this must be equal and opposite to the combined forces of the spring kx, and the weight of the balloon and the helium within it.
with this i get 6.45=0.0196 + 0.9 + 90x
solving for x i get = 0.06144, which is way off the answer is .604m
where am i going wrong?
5 x 1.29 = 6.45N
This is mass of air displaced by the balloon in kg, not N.
Check this step also.
yep forgot to times by 9.8 cheers
10K
10K
14K
