Thread Closed
Are these the best tests for convergence of the following series?
Share Thread
Feb7-08, 08:44 AM   #1
(a) [tex]\displaystyle{\sum_{n=1}^{\infty}\Bigg(\frac{(-1)^{n}}{n^{1 + \frac{1}{n}}}\Bigg)[/tex]
(b) [tex]\displaystyle{\sum_{n=1}^{\infty}\Bigg(\frac{e^{\frac{1}{n}}}{n^{2}}\Bi gg)[/tex]
(c) [tex]\displaystyle{\sum_{n=1}^{\infty}\Bigg(\frac{(-1)^{n}n!}{n^{n}}\Bigg)[/tex]
(d) [tex]\displaystyle{\sum_{n=1}^{\infty}\Bigg(\frac{1}{n^{1 + \frac{1}{n}}}\Bigg)[/tex]
(e) [tex]\displaystyle{\sum_{n=1}^{\infty}\Bigg(\frac{ln(x)}{n^{\frac{3}{2}}}\Bi gg)[/tex]
(f) [tex]\displaystyle{\sum_{n=1}^{\infty}\Bigg(1 - e^{\frac{-1}{n}}\Bigg)[/tex]
2. Relevant equations
The test that we have messed with are:
Telescoping, Geometric, P-Series, Ratio, Root, Simple Comparison, Limit Comparison, Absolute Convergence, Alternating Series, Dirichlet, Integral, Gauss
3. The attempt at a solution
First, I got they all converge:
(a) (d)
I worked 'd' first. I did a limit comparison test with 1/n
[tex]\frac{\frac{1}{n}}{\frac{1}{n^{1 + \frac{1}{n}}}} = n^{n}[/tex]
That limit is 1. And since its absolute value converges (a) converges.
(b) Basic Comparion test wtih <= [tex]\frac{e}{n^{2}}[/tex]
(c) Alternating series test
(e) Integral test
(f) Im not sure which test to apply
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Feb7-08, 01:18 PM   #2
(d) is wrong,a dn so is (a), not sure how to prove if they are convergent (if they are).
Is (d) divergent?
Feb7-08, 01:19 PM   #3
(a) is convergent by alternating series test.
Did I end up proving (d) divergent or is my proof wrong?
I'm also quite lost on (f) since I can't integrate that function nicely
Feb7-08, 02:26 PM   #4
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Too many questions at once! d) is divergent. It's the same as 1/(n*n^(1/n)). For n^(1/n) show that the log of that approaches zero. So n^(1/n) approaches 1. So you can do a comparison with say 1/(2n). For f) expand e^(-1/n) in a power series using e^x=1+x+x^2/2!+etc and keep only the terms that matter.
Thread Closed
Similar discussions for: Are these the best tests for convergence of the following series?
Thread Forum Replies
Convergence tests for sequences not series Calculus 6
Series tests Calculus 6
Real Analysis, Series, Tests. Calculus & Beyond Homework 0
Stationarity of Time Series: Tests Set Theory, Logic, Probability, Statistics 1
Convergence tests??? Introductory Physics Homework 0
