What Is Hopping Energy in Quantum Physics?
  • Context: Graduate
  • Thread starter Thread starter adventure
    Energy
The term "hopping energy" refers to the energy required for a particle to transition between lattice sites, commonly represented as "t" in the tight-binding approximation. This concept is crucial in quantum physics, particularly when analyzing systems using the discretized Schrödinger equation on a square lattice. The hopping energy is mathematically defined as γ = ℏ²/(2ma²), where "a" is the lattice constant, and it establishes the energy scale of the system, influencing properties such as bandwidth.
  • Understanding of quantum mechanics principles
  • Familiarity with the tight-binding approximation
  • Knowledge of the Schrödinger equation
  • Basic concepts of lattice structures in solid-state physics
  • Study the tight-binding model in quantum mechanics
  • Learn about the discretization of the Schrödinger equation
  • Explore the concept of bandwidth in solid-state physics
  • Investigate the role of lattice constants in quantum systems
Students and researchers in quantum physics, solid-state physicists, and anyone interested in the mathematical modeling of particle behavior in lattice structures.
adventure
hi,
what is the meaning of hopping energy? i know some, but i like understand deeply.:shy:
adventure said:
hi,
You really should provide some context on where you found this phrase, since this could be a number of things. Keep in mind that the MORE you explain your question, the less we have to go back and forth to narrow down exactly what it is that you are asking.
If by "hopping energy", you mean the term normally assigned as "t" in the hopping integral such as in the tight-binding approximation, then it is really what its name says, the energy needed for the particle to hop from one location of the lattice to another.
You can't understand anything "deeply" on a public forum. The only way you can do that is through a proper study.
Zz.
It's something like a kinetic energy. If you discretize the Schroedinger equation on a square lattice then you find that the hopping term [itex]\gamma=\hbar^2/(2ma^2)[/itex] where [itex]a[/itex] is the lattice constant. The hopping energy generally sets the energy scale of your system (for example the bandwidth is usually measured in terms of the hopping constant).
edit: proably it should be [itex]\gamma=\hbar^2/(ma^2)[/itex]
