Thread Closed
Contact Force
Share Thread Thread Tools
Feb8-08, 01:24 AM   #1
Contact Force
Two blocks are in contact on a frictionless table. A horizontal force F is applied to M2, as shown. If M1 = 1.51kg, M2 = 3.96kg, and F = 4.55N, find the size of the contact force between the two blocks.
So first I found the acceleration (F=ma)
4.55/(1.51+3.96) = 0.83 = acceleration
Im suck from here
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Feb8-08, 01:35 AM   #2
Try drawing a free-body diagram of M1, to make this easier. What forces are acting on it? You also know its acceleration, so what forces are causing this acceleration?
Feb8-08, 01:39 AM   #3
the horizontal force that was applied to M2...
Feb8-08, 01:59 AM   #4
Contact Force
If the force on M2 was also applied to M1 like you said, M1's acceleration would not be the 0.83 m/s^2 you calculated. So, a different force must be causing this acceleration...
Feb8-08, 02:00 AM   #5
would gravity play a factor?
Feb8-08, 02:04 AM   #6
No, let me explain this differently. Now, draw the free body diagram of M2. There's the 4.55 N force acting on it, but there is another horizontal force acting in the opposite direction, the contact force. Newton's Third Law states there are equal and opposite forces, so this applies to the contact force. So, the contact force is acting on M1, giving it its acceleration, if I'm thinking of this problem right (force acting on M2, and M2 is pushing on M1). Does this help? I deeply apologize if I overcomplicated the problem.
Feb8-08, 02:12 AM   #7
So the contact force is the force acting in the opposite direction?
Which would be .83*1.51 =1.25 N is that the contact force?
or do I do 4.55 N - 1.51 N = 3.3 N
and ya that's the problem.. m2 is pushing m1
Feb8-08, 02:15 AM   #8
The contact force is merely the mass of M1 times its acceleration. Remember, the contact force is the force giving M1 its acceleration. Do you see why?
Feb8-08, 02:20 AM   #9
im sorry terbum, this is just so confusing for me.. probably b/c it's getting late..
so how do i find the acceleration of M1 if it isn't 0.83m/s^2
Feb8-08, 02:24 AM   #10
The acceleration you solved for was the acceleration for the system. So, BOTH M1 and M2 have an acceleration of 0.83 m/s^2.
Yeah, I had a tough time with this topic when I learned it, too. It does get a little confusing. I guess if you want to learn it, keep doing problems. Practice never hurts.
Feb8-08, 02:41 AM   #11
Recognitions:
Homework Helper Homework Help
Quote by am08 View Post
The accn of M1 is 0.83 m/s^2, as you have calculated. A force of 4.55 N is pushing on M2, which in turn is pushing on M1, and both masses are moving together, and so their accn must be same.
The last step remaining is to find out what force acting on M1 produces an accn of 0.83 m/s^2? You know mass of M1, and accn 'a'. Apply Newton's 2nd law.
Thread Closed
Thread Tools
Similar Threads for: Contact Force
Thread Forum Replies
[SOLVED] Contact Force Introductory Physics Homework 4
Contact force problem Introductory Physics Homework 2
Contact Force Introductory Physics Homework 1
Contact Force problem Introductory Physics Homework 0
