Discuss events which are simultaneous in one frame?
  • Context: Graduate
  • Thread starter Thread starter neopolitan
    Events Frame
The discussion revolves around the concept of simultaneity in the context of relativity, specifically addressing what is meant by events being simultaneous in a given frame. Participants explore different interpretations of simultaneity, including reception and transmission simultaneity, and question the implications of relativity on the meaning of simultaneity.
  • Some participants propose that simultaneity may refer to "reception simultaneity," where photons from two events reach an observer together, or "transmission simultaneity," where photons are released simultaneously from equidistant sources.
  • One participant argues that transmission simultaneity can be defined by calculating the time it takes for light to reach the observer, asserting that two events are simultaneous if the calculated transmission times are identical in the observer's frame.
  • Another participant highlights that different observers in relative motion may disagree on whether two events are simultaneous, due to the effects of their respective frames on the synchronization of clocks.
  • Concerns are raised about the assumption of privileged information in determining simultaneity, suggesting that if one frame is given special status, simultaneity may be perceived differently.
  • It is noted that an observer moving relative to synchronized clocks may perceive them as unsynchronized, despite the clocks being synchronized in their own rest frame.
Participants express differing views on the nature of simultaneity and whether it can be considered lost in relativity. There is no consensus on the implications of simultaneity across different frames, and the discussion remains unresolved.
Limitations include the dependence on the definitions of simultaneity and the assumptions made about the observers' frames of reference. The discussion does not resolve the mathematical or conceptual complexities involved in defining simultaneity.
neopolitan
I have scanned the simultaneity related posts and cannot find a succinct answer to a question I have - I accept that the answer is probably buried in one or more of them.
My question is related to the common claim that you somehow lose simultaneity in relativity, or that the idea of simultaneity is somehow meaningless.
What, precisely, are we referring to when we discuss events which are simultaneous in one frame?
I give you the two options which I think we could be talking about:
Reception simultaneity - photons from two events reach the observer together (this is a third event if you like, one in which the observer and the two photons are collocated in both time and space).
Transmission simultaneity - photons from two events are released simultaneously, such that if the sources were equidistant (and remain equidistant - in other words the observer is at rest), the photons would reach the observer at rest together. Under most circumstances however, the photons will not reach the observer simultaneously and knowledge of where the photons were released is required to know that their release was in fact simultaneous.
Is the simultaneity we talk about one of these, or something different?
Am I mistaken about the concept that "simultaneity is lost" and/or "simultaneity is meaningless in relativity"?
I do have a follow on question, but it may be moot if the answers I get to this clarify something else for me.
cheers,
neopolitan
It's the second one--if an observer assumes that both signals move at c relative to himself, and subtracts the calculated time for the light to traverse the distance between the point of emission and himself (as measured by rulers at rest in his frame) from the time the light actually reaches him (as measured by his own clock), giving the calculated time the light was actually transmitted in his frame, then two events are simultaneous in his frame if the calculated transmission time for each is identical. A functionally identical way of defining the time of events in a given frame is for each observer to have an array of clocks at rest relative to themselves, attached to rulers also at rest relative to them, and with the clocks "synchronized" using the assumption that light travels at the same speed in all directions in their frame--for example, one could synchronize two clocks by setting off a flash at their exact midpoint, and making sure they read the same time when the light from the flash reaches them (this is one version of the 'Einstein clock synchronization convention'). Then to find the time of a given event, I just look at the reading on the clock right next to it as the event happened, so I'm defining times of events purely in terms of local measurements and don't have to worry about light delays; this will give the same answer as the earlier method, and two events will be simultaneous if the clock that was next to one event when it happened showed the same time as the clock that was next to the other event when it happened.
However, if different observers in relative motion each define simultaneity in this way, making the assumption that light travels at the same speed in all directions in their own frame, then a consequence of this is that they will disagree about whether two given events happened simultaneously or not. For example, suppose I am on board a rocket which is moving relative to you from left to right, and in my rest frame I synchronize clocks on either end of the rocket by setting off a flash at the midpoint of the rocket and making sure each clock reads the same time when the light from the flash reaches them. But in your frame the clock on the right side is moving away from the position on your ruler where the flash was set off, while the clock on the left side is moving towards it, so if you assume both light signals move at the same speed in your frame, you must conclude the light reached the left clock before the right clock; thus, in your frame my two clocks are out-of-sync and the events of the light hitting each one are non-simultaneous.
Why is the assumption made that each observer should assume light moves at the same speed in each direction, then? Basically the reason is that all the fundamental laws of physics seem to have the property of "Lorentz invariance" meaning that if different observers construct their coordinate systems in this way, the basic equations representing the laws of physics will be the same when expressed in these different coordinate systems. If the laws of physics weren't Lorentz-invariant, but instead were invariant under the Galilei transformation where different coordinate systems have no disagreements about simultaneity, then there would be a physically preferred definition of simultaneity and we wouldn't be using coordinate systems where light moves at the same speed in all directions in every frame.
If you're interested, I drew up some diagrams of two ruler-clock arrays sliding next to each other in this thread, showing how in each array's rest frame the clocks of the other array are out-of-sync, and how this is crucial to understanding how it can be that in each array's rest frame the clocks of the other array are running slower and the distance between markings on the other ruler are shrunk.
But doesn't assume privileged information?
Either you give the location of each event to both of the observers, each in terms of their own frames (in which case they can both work out that the transmissions were simultaneous) or you give neither information about location, and there is no longer enough information to detemine whether any simultaneity was involved.
Of course simultaneity will be lost if one frame is given privileged status.
Think of the synchonisation convention that you referred to. An observer at rest relative to the two clocks at their midpoint will observe the clocks as synchronised. This has to do with location. If that observer gets up, takes a step towards one or other of the clocks and stops again (returning to rest), the clocks will no longer be directly observed as synchronised. They are still synchronised though, irrespective of the direct observations made.
If an observer in a frame which is not at rest relative to the clocks makes an observation at the midpoint between the clocks, the clocks will be seen as synchronised - at that point. This must be the case since photons released from each clock meet each other at that midpoint (the photons not being affected by the inertia of any observer). The photons will hit the eye of the observer together.
That observer in a frame which is not at rest relative to the clocks will directly observe the same apparent lack of simultaneity as an observer at rest relative to the clocks does if they are in the same location (by this I mean if they are physically collocated, not that they agree about where they are). Both will be able to use the information they have to hand to work out that the clocks are simultaneous - with each other.
If I used your example of a rocket with lights flashing on each end, I could actually work out why the disagreement occurs, and timing of the flashes would make sense to both observers. (The maths is essentially the same as I used in an earlier strand to point out that there is no twins paradox, just a poorly framed scenario.)
Is the simultaneity that you are talking about? or is it a simultaneity that is "lost" on another level - that is, both observers can work out that the clocks are synchronised, but there is no simultaneity between the observations, direct or inferred, because the when of each tick of the clocks is not agreed?
To try to clarify what I mean here, at the instant when both observers are collocated at the midpoint between two clocks, the one who is at rest relative to the clocks will say that the ticks observed happened together a period of t1 ago, while the one in motion relative to the clocks will say that the ticks observed happened together a period of t2 ago. t1 does not equal t2.
cheers,
neopolitan
This simply cannot be true. If you assume that the speed of light is constant for everyone meaning information moves at constant C and that laws of physics are in all frames the same then I (on the spaceship) and you (observer) would see the same time dilation (laser beam takes the same amount of time to get to the front clock).
Not true. Suppose the ship is 24 light-seconds long in my frame, moving at 0.5c to the right, and at time t=0 in my frame the flash is set off at position x=12 ls, and at that moment the left end is at position x=0 ls while the right end is at x=24 ls. In this case, at t=8 seconds the light heading in the left direction will have moved 8 ls to the left of x=12 ls, so it'll be at x=12-8=4 ls. Meanwhile, since the left end of the ship started at x=0 ls and is moving to the right at 0.5c, after 8 seconds it'll have moved 8*0.5 = 4 ls to the right, so it'll be at x=4 ls too; thus, the light must hit the left clock at time t=8 ls.
Meanwhile, at t=24 s, the light moving to the right has moved 24 ls to the right of x=12 ls, so it'll be at x=36 ls. And the right end of the ship started at x=24 ls, and since it's moving to the right at 0.5c, 24 s later it will have moved 24*0.5 = 12 ls to the right of this position, so it'll be at x= 24 + 12 = 36 ls as well. So, this must be the time the light catches up to the right clock, at time t=24 s, a full 16 s after it caught up to the left clock.
Of course, this is just in my frame where the ship is moving. In the ship's own rest frame, the two clocks are at rest at equal distances from the position the flash was set off, so naturally if we assume both signals move at the same speed in this frame we'll conclude the light must have hit both ends at the same time. This is what is meant by the relativity of simultaneity--different frames disagree on whether a pair of events at different locations happened "at the same time" or "at different times".
Very nice explained, but i still don't agree. I cannot and will not accept the modern explanation of relativity because it's wrong and full of illogical assumptions.
Here, look at this link:
http://www.phys.unsw.edu.au/einsteinlight/jw/module3_weird_logic.htm"
This animation is clearly evidence that light is just like sound only that it has a different base. Sound is also constant and it is the basic physical phenomenon that gives us information about sound of the "flying block". Light is also constant and it is th basic physical phenomenon that gives us information about what it is around us. If you went to do experiments with sound and sound barrier you'd also find the same time dilation as you find it with light. So if you study sound and its properties you indirectly study the behaviour of light and infromation that it sends to you. Light barrier exists and it manifests in Cherenkov radiation and its blueish glow. The only thing we have to figure out is how to break it.
I don't understand what you mean by "give" the location. Each observer has their own ruler at rest relative to themselves--you can imagine the two observers' rulers moving alongside one another at arbitrarily small separation, as in my illustration--so to figure out the position of a given event in each frame, you just have to look at which marking on each ruler was right next to the event as it happened.
Again, synchronization has nothing to do with when observers see events, I thought I made that clear. An observer defines the time of an event using rulers and clocks at rest relative to themselves--they can either use their ruler to determine the distance of the event and subtract the time the light would be calculated to reach them from the time they actually see it to determine the "actual" time of the event in their frame (the first method I discussed), or they can presynchronize clocks at different locations using light signals, and then define the time of the event in terms of the reading on a local clock from their system that was right next to the event as it happened (the second method I discussed, which will give exactly the same answer as the first).
They'll be seen as showing the same time when he looks through his telescope at each one at that moment, but this has nothing to do with what it means for an observer to say the clocks are "synchronized" in his frame, it's completely irrelevant.
This paragraph seems to be operating under the assumption that simultaneity has something to do with whether or not a given observer sees two clocks showing the same time at a given instant, so all I can tell you is that your assumption is wrong, simultaneity has nothing to do with that. It is determined by either the first method where you subtract off the time the signal took to reach you from the time you see the event, or by the second method where you have an array of clocks that are synchronized using the Einstein synchronization convention (itself based on the assumption that light moves at the same speed in all directions in your frame), and you use only local measurements from clocks that were right next to each event as it happened.
It would make sense to both observers, but the two observers would disagree about whether the two events happened simultaneously or not.
I don't understand this paragraph at all. What does "simultaneity between the observations" mean, and what does "the when of each tick of the clock" mean? What specific method are you imagining the observers use to assign time-coordinates to events? Maybe it would help if you gave a numerical example. Do you agree that if the observers use either of the two equivalent methods I discussed above, then if one observer finds that two events happened at the same time-coordinate in his frame, the other observer will find they happened at different time-coordinates in his own frame?
No, the one in motion will say that the ticks happened at two different times, because on his ruler they happened next to markings which are at unequal distances from him, so the only way he can account for the fact that they both signals reached him at the same time while still assuming they traveled at the same speed is to conclude they happened at different times.
Imagine we have two observers A and A' whose rulers are sliding next to each other at 0.6c, with A sitting at the x=0 ls mark on his ruler and A' sitting on the x'=0 mark on his own ruler. Let's suppose two events happened simultaneously in A's frame, so at t=0 seconds, event L happened next to the x=-10 ls mark on his ruler, and event R happened next to the x=+10 ls mark on his ruler. Meanwhile, at this time observer A', sitting at x'=0 ls on his own ruler, is next to the x=-6 ls mark on the ruler of A. So in the frame of A, A' is 4 ls from L and 16 ls from R; but since the markings on the ruler of A' seem to be shrunk by a factor of 0.8 in the frame of A, that must mean event L happens next to the mark x'=4/0.8 = 5 ls on the ruler of A', and the event R happens next to the mark x'=16/0.8 = 20 ls on the ruler of A'. So, we see that according to the ruler used by A the events happened at equal distances from himself, and according to the ruler used by A' they happened at unequal distances from himself.
Now since A' is moving at 0.6c in the frame of A, in 10 seconds he moves 6 ls to the right; so since A' was at x=-6 ls at t=0 s in the frame of A, at t=10 s A' will have reached the position x=0 ls, where A is too. And since the events L and R each happened 10 ls away from A at t=0 s, then at t=10 s both must be reaching the position of A as well. So, both observers see the signals from both events reach them at the same moment, when their positions coincide. If A assumes each signal moved at the same speed, then since they happened at equal distances from him according to his ruler, this is consistent with the notion that the two events must have happened at the same time in his frame. But since A' measured the two events to have occurred at different distances from himself (according to his ruler, L happened 5 ls away and R happened 20 ls away), if he also assumes the signals traveled at the same speed, he must conclude the events happened at different times in his frame (L must have happened 5 seconds before the signal reached his eyes, while R must have happened 20 seconds before the signal reached him).
Sound waves only moves at the same speed s in all directions if you're in the rest frame of the medium (air) which the sound waves are vibrations in. If someone is moving at a speed v relative to this medium s, then in their own rest frame they'll measure sound waves to travel at s+v in one direction and s-v in the other, according to classical physics. Before relativity physicists used to imagine that light waves actually were vibrations in a medium called the luminiferous aether which was supposed to fill all of space, which led them to conclude that light would only be measured to move at the same speed in all directions when the Earth was at rest relative to this fluid, so that they could determine the rest frame of the aether by checking for differences in the speed of light in different directions when the Earth was at different points in its orbit. This was the famous Michelson-Morley experiment which gave the surprising result that no matter what point in the Earth's orbit the experiment was done, light always seemed to have the same speed in all directions. The failure of these types of aether experiments was one of the major inspirations for Einstein's theory of relativity, which postulated that the laws of physics were such that all observers could measure the speed of light to be the same in all directions, and that if they constructed their coordinate systems under this assumption they would find that all the fundamental laws of physics had the property of obeying the same equations in each coordinate system (which can only be true for laws that have a mathematical property known as 'Lorentz-invariance', which all the known fundamental laws seem to have).
Cherenkov radiation is only observed when the speed of light is artificially slowed in a medium; the 'c' in the equations of relativity is always understood to be the speed of light in a vacuum, and no one has observed Cherenkov radiation in a vacuum.
Ok, taking this to be the the situation where the observer at rest and the observer in motion are collocated (the only time when the observer in motion will receive signals at the same time), I agree. Since the photons reach him at the same time as he is equidistant from the clocks, and they are in relative motion, he must assume one of the following: it is he who is in motion rather than the clocks, the speed of light (in a vaccuum) is not a constant, the ticks actually were not simultaneous in his frame, or something funny is happening with length contraction based on his location relative to the clocks.
I am willing to reject the last one there, since it implies that the universe cares where the observer is. I am willing to reject the first, since our scenario doesn't specify which is in motion. I at least only talked about relative motion.
That leaves us with two options. Personally I am not inclined to suggest that speed of light in not a constant, I actually think it is but a better reason than "it is a postulate" or "Michelson and Morley didn't detect an aether wind". I'd be interested to hear what your justification is, if it is discussable (mine is possibly not discussable in this forum).
So I am left with one option, ticks are not actually simultaneous in the frame of the observer who is in motion relative to the clocks. I agree.
Is it permitted to go further than that and discuss how that can be the case? Is it an illusion? Is it because world line for each is skewed with respect to each other (and again is this something real or just a "lie to children")?
My conceptualisation is that the rocket is skewed a little in spacetime by virtue of its motion such that the forward end is a little in the future, relative to the rear end. Relative the rocket, of course, it is not in motion so the clocks at each end are simultaneous. Relative to another observer, not at rest relative to the rocket, the clocks are not simultaneous. Such an observer will see the front end first (so see the tick from that one first) and then the rear end (so the tick from this one will be seen second) - of course traveling times for the photons have to be accounted for, if the separation between a departing rocket's nose and tail are sufficiently large or the speed is sufficiently low, then the nose may be seen second but still sooner than it may otherwise would have been expected.
Is this way off?
cheers,
neopolitan
Note to moderators and other similar types: I have qualified this with "my conceptualisation", I am not claiming any more than that.
neopolitan said:
Ok, taking this to the the situation where the observer at rest and the observer in motion are collocated (the only time when the observer in motion will receive signals at the same time), I agree. Since the photons reach him at the same time as he is equidistant from the clocks, and they are in relative motion, he must assume one of the following: it is he who is in motion rather than the clocks, the speed of light (in a vaccuum) is not a constant, the ticks actually were not simultaneous in his frame, or something funny is happening with length contraction based on his location relative to the clocks.
You're talking as if there is some objective truth about coordinate-dependent facts like whether the speed of light is the same in all directions, or whether two events at different locations are "really" simultaneous. But I don't see how experimental physics can give you objective truths about which coordinate system you "should" use. All that experiment can do is tell you that if observers construct their coordinate systems in some particular way, then the laws of physics expressed in that coordinate system will obey certain equations. The only physical claim of relativity is that if inertial observers construct their coordinate systems in the way described by Einstein, including the arbitrary axiom that the coordinate speed of light signals should always be c, then the equations for the fundamental laws of physics will look the same in all the coordinate systems constructed this way. This is a physical claim that could potentially be falsified by experiment. But even if it's true, that doesn't somehow prevent you from constructing the coordinate systems of inertial observers using a different rule, perhaps one under which the coordinate speed of light will be different in different directions, or one in which all inertial observers will have the same definition of simultaneity; it's just that when expressed in these coordinate systems, the equations describing the fundamental laws of physics will vary from one inertial coordinate system to another. But as long as you find the correct equations for whatever screwy coordinate system you use, you'll still get all the same predictions about coordinate-invariant physical facts (like what two clocks will read when they pass next to one another) as you would if you were using the standard inertial coordinate systems of SR.
Well, like I said above, I don't think that any coordinate-dependent statement is either "truth" or "illusion", it's just specific to your choice of coordinate system; the inertial coordinate systems related by the Lorentz transform are just the most "elegant" since the laws of physics have the same form in all these coordinate systems. But in terms of these coordinate systems, if you draw the lines of constant-coordinate-position and the lines of constant-coordinate-time (lines of constant time are also called 'surfaces of simultaneity') for two different frames in the same minkowski diagram, you do see that the constant-t lines defining a set of simultaneous events for each coordinate system are skewed relative to one another.
That's a decent way of thinking about it, although you actually have it backwards--as seen in a frame where the rocket is moving, at any given moment in this frame, the reading on the clock at the back end will be ahead of the reading on the clock at the front end at the same moment...the amount it's ahead is vx/c^2, where v is the speed of the rocket in this frame, and x is the separation between the two clocks in the rocket's own rest frame (so the separation between the clocks is actually smaller in the frame where it's moving)
Yes, if the clocks are synchronized in the rocket's rest frame, then they both show the same reading simultaneously (at the same time coordinate) in the rocket's rest frame.
Which clock an observer would see as showing the more advanced time could depend on whether they were in front of the rocket (so it was coming towards them) or behind it (so it was moving away), I think. But if you have two observers, one ahead and one behind, and both are at rest with respect to each other (so they share the same rest frame) and measure the rocket moving at speed v relative to themselves, then although they will see different things, as long as they compensate for signal delays when they calculate what time-coordinate a given tick actually happened at in their frame, then they will both come to the conclusion that the back clock's reading is ahead of the front clock's reading by the same amount (the vx/c^2 I mentioned earlier).
JesseM said:
That's a decent way of thinking about it, although you actually have it backwards--as seen in a frame where the rocket is moving, at any given moment in this frame, the reading on the clock at the back end will be ahead of the reading on the clock at the front end at the same moment...the amount it's ahead is vx/c^2, where v is the speed of the rocket in this frame, and x is the separation between the two clocks in the rocket's own rest frame (so the separation between the clocks is actually smaller in the frame where it's moving).
We always seem to get stuck at these little points.
The nose is in the future, the tail in the past. Therefore you see the tail before the nose, because it's been there longer. Yes, the clock on the tail will appear to be ahead of the clock on the nose from a frame which is not at rest relative to the rocket, if the clocks are simultaneous in the rocket's frame.
Think about clocks which are simultaneous in the rocket's frame both saying, for instance, 1 minute past Jesse o'clock. If I am in a frame which is not at rest relative to the rocket, then (taking into account the time taken for the photons to travel), I will see 1 minute past Jesse on the tail first, because I see things in this order "the past, now, the future", rather "the future, now, the past". I have to wait a little until I catch up to the nose of the rocket (time wise) before I see 1 minute past Jesse o'clock on the nose.
So, as you say, yes - the clock on the tail will run ahead of the clock on the nose as observed by an observer not at rest relative to the rocket. And like I said, the clock on the nose is a little in the future relative to the one on the tail.
Do you see what I mean?
cheers,
neopolitan
Glad you have an "or" there.
There is no real simultaneous, just "simultaneous in a frame".
Are you saying that the speed of light in a vacuum isn't the same in all directions? Let's get more specific, do you think there is any way to measure the speed of light in a vacuum so that it is not a constant?
If so, I'd be interested to hear it from you. If not, what's the real issue here?
Note that to the best of my knowledge I didn't suggest any screwy coordinate system designed to make the speed of light different in different directions, from what I can tell that was your own personal strawman.
cheers,
neopolitan
That is true... there is no absolute 0 velocity. You are always moving with respect to something, but at rest with yourself. Your simulaneity will be different from any other observers not at rest with you. Simultaneous is meaningless when you have different time frames.
The speed of light in a vacuum is the same in all directions no matter what frame you are in. This is why it is different from sound. If I am traveling at the speed of sound in air, then the velocity of air will be 0 to me in the direction I am going. This is not the case with light. Even if I go .99 the speed of light, light will still speed away from my perspective at c.
To use your phrasing above, there is no speed (of anything, not just light), just "speed in a frame". If I were to first synchronize my array of clocks using the Einstein method, but then move each clock forward or backwards based on their distance from me (for instance, a clock one meter to my right could be set one second forward, two meters to my right two seconds forward, one meter to my left one second backward, etc.), then this array of clocks with the altered times would define a new coordinate system with a different definition of simultaneity than my SR rest frame, and in this new coordinate system the one-way speed of light wouldn't be the same in both directions.
But I should point out that as long as the time-coordinate at a single location in my frame moves forward at the same rate as a normal physical clock at rest at that location, and distance in my frame is measured using rulers at rest in my frame, then the average two-way speed of light will always be c even if the one-way speed of light is different than c thanks to an odd clock synchronization scheme. Measuring the average two-way speed of light just requires a single clock (I can send a light signal away from the clock, bounce if off a mirror at a known distance, and divide the total distance it travels to the mirror and back to the clock by the difference in readings on the clock between the time the signal left and the time it returned), so synchronization schemes don't matter here. Even in this case, though, if I wanted to be contrarian I could define my coordinate system's time coordinate in such a way that a normal clock at rest relative to me was not ticking at the same rate coordinate time was advancing (or even where the coordinate time was such that the rate of ticking of such a clock is varying), and then the two-way speed of light in my coordinate system might not be c either.
It wasn't a strawman because I never accused you of doing so, I was just making a point that the speed of light is coordinate-dependent, and that it's only constant if inertial observers construct their coordinate systems in the way Einstein suggested. Again, this choice of coordinate systems is the most "elegant" since it ensures that each observer will have the same equations for the laws of physics, but I don't think that coordinate-dependent statements in these systems are somehow more "objectively true" than coordinate-dependent statements in more "screwy" coordinate systems.
Jesse
I knew once I had posted #12, that I should not have.
#11 is the post I really want a reply to.
Any chance of that?
I don't know what you mean here--been where longer? Yes, in your frame the tail clock will hit a given time before the nose clock hits it, but I don't see the connection between this and "the nose is in the future, the tail in the past".
Don't get what you mean by "order"--if you instead saw a given time on the head first, are you saying that would mean you'd be seeing things in the order "the future, now, the past"? Regardless of which clock is ahead, you'll always see any given clock show earlier readings before later ones, so doesn't that mean you're always seeing things in the order "past, now, future"? Or are you talking about the spatial "order" when you look at different clocks on the ship from back to front, rather than the temporal order of readings on any given clock? Or something else entirely?
I don't at all see by what you mean by "X is in the future relative to Y"--I can't think how this phrase would make sense as anything other than idea that X showed a later date than Y, rather than an earlier one--but if you agree the clock on the tail is ahead at of the one at the nose at a given moment in the observer's frame, I suppose it doesn't really matter how you choose to conceptualize this.
While my description at #11 was in part flippant, I am still keen to hear if anyone else can understand what I mean.
It could just be that my description was unclear. It could be that I am conceptualising things a different and difficult way. It could be that you have a fundamental misunderstanding of how times works. Or it could be no more than some sort of willful (albeit most likely subconscious) incomprehension on your part, Jesse, since at the end of your post, you seem to grudgingly accept that what I have to say has some sort of twisted validity anyway. I am not totally sure where the problem lies.
So ... let's see if anyone else reading this thread can work out what I mean before I have another hack at producing an explanation which might meet with your official approval.
I know what you mean, but I don't think it is an important argument. I can say "New York is an hour earlier than Chicago" meaning something like the sun rises in NY an hour before it rises in Chicago, or I can say "New York is an hour later than Chicago" meaning that the clock in NY shows 08:00 when the clock in Chicago shows 09:00. I don't think your post 11 is saying anything more important than that. It isn't a confusion about the math or physics, just an ambiguity in the english. Not worth arguing.
I think this is the key. The point is that simultaneity is an artificial construct arising from the definition of a coordinate system, not something objectively real in its own right. Fundamentally it appears that the universe doesn't care about simultaneity, only about causality. Two simultaneous events cannot be causally connected, so what does it matter if one happened before the other? On the other hand, a cause should always come before an effect, and this is exactly what we see in relativity. A cause will preceed the effect in all reference frames, and for the rest it doesn't really matter.
Dale,
It could be just the English, but the way I see it the nose end of the rocket will be more in the future, due to its being skewed in spacetime by virtue of its speed (relative to an observer who is not at rest relative to the rocket).
Possibly Jesse is confused because I used the word "relative" in an attempt to indicate that the nose is more in the future than the tail is (so in the future relative to the tail). I can see how this could be confusing.
But his understanding seems to be the reverse - that the nose is more in the past (because the nose clock reads an earlier time than one at the tail).
For me, this is just plain wrong, but it could be a matter of perspective. The question then is whose perspective is more valid. I feel that Jesse's perspective almost presupposes absolute time, linked to clocks.
Clocks don't tell you "when" you are any more than odometers tell you where you are. They just tell you how much time has elapsed. He seems to think that when you are in time is related to what your clock says.
What I am saying instead is that while the rocket is in motion, the nose will reach the instant when it is observed before the tail reaches that same instant (relative to an observer who is not at rest relative to the rocket). It therefore could be said to be "in the future" - although of course when it is observed it is "in the now".
cheers,
neopolitan
How did I grudgingly accept it? I just said that ultimately, how you conceptualize it doesn't matter as long as you get the right answers. But I still don't understand how you're conceptualizing it. Why does older = further in the past and younger = further in the future for you? Can you try to explain again?
Neopolitan, you are arguing over really unimportant things now compared to your initial question.
There are two important points in this thread. 1) in SR all observers are intelligent, meaning that they correct for the light propagation delay to figure out when an event really occurred not merely when it was observed. 2) when they do that they find that they disagree on wether or not two distant events really occurred simultaneously.
I'm not going to engage you in an unimportant debate about semantics.
OK, this kind of helps me see what neopolitan might have been talking about actually, although "New York is an hour later" (i.e., it's later in realtime to reach the same clock time) is a little different from "New York is an hour in the future", the latter just seems like really confusing phrasing if New York actually shows an earlier time than Chicago. Neopolitan, is this basically what you meant? If so, would you agree it's just a matter of ambiguity in language, that neither version is "more correct" than the other?
I'm not presupposing absolute time, I'm comparing the opinions about simultaneity of two different frames. In the ship's own frame, both clocks show the same reading at the same time, i.e. simultaneously. In that frame (call it frame A), the event of the tail clock reading 4 seconds would be one second in the future of the event of the nose clock reading 3 seconds. So, in the frame where the ship is moving forwards (call it frame B), if the event of the tail clock reading 4 seconds and the nose clock reading 3 seconds are simultaneous, then in this frame one can observe, in a single moment, a reading on the tail clock that is "in the future" of the reading on the nose clock as understood in frame A. That's all I meant! One could find another frame (call it frame C) in which the rocket is moving backwards, and in this frame the event of the tail clock reading 4 seconds might happen earlier than the event of the nose clock reading 3 seconds. So, going back to frame B, in frame B one can observe, in a single moment, a reading on the tail clock that is "in the past" of the reading on the nose clock as understood in frame C. There's obviously no absolute truth about whether one event is "really" in the future or the past of another event (unless one event lies in the other event's future light cone, in which case all frames agree on the order), all we can do is talk about the opinions of different frames, and perhaps relate them to one another as I do above.
What do you mean by "reaching an instant"? By instant do you mean something different than just a given reading on each clock? After all, if we pick any give reading--say, 3 seconds--then in the frame B where the rocket is moving forward, the tail will get to that reading first, not the nose, so I don't see what you mean by "the nose will reach the instant when it is observed before the tail reaches that same instant".
re DaleSpam and arguments about semantics - it is possible that what I am thinking about it not merely semantics. I don't know what is inside your head and, I hope, you don't know what is inside mine. I am trying to gain a better understanding of whether what Jesse and I are saying are the same thing or not.
re JesseM's reply to DaleSpam - it could be an ambiguity of language, but I have the benefit of being biligual (English is my mothertongue though) and know that sometimes limitations in language make it impossible to convey certain concepts. It is possible that what I am trying to express is being converted in your mind to precisely what you originally thought, but isn't what I meant. It seems it is just you, me and Dale - so I will have another crack at explaining.
An instant I mean as a "line of simultaneity", the events which share the same value of t in the frame to which it pertains.
So I am thinking of the rocket's frame, in which the rocket is not moving, and an observer's frame, in which the rocket is moving. An instant in the observer's frame is the set of events which share the same value of t. This "observer's instant" is not an instant in the rocket's frame, but a set of events which we can work out using lorentz transformations.
An instant in the rocket's frame, in which clocks at the nose and the tail read the same, is similarly not an instant in the observer's frame.
If we pick any instant in the observer's frame, and look at the rocket, we will see that clock on the nose reads less than the clock on the tail. We agree about this.
What I am saying is that the nose reaches any given observer's instant before the tail.
Imagine that we sit in two separate time machines, machines that shunt us into the future at faster rate than normal life (like fun events seem to do). We each have a watch, and we synchronise them before we switch our machines on.
If my machine shunts me into the future twice as quickly than yours, which one of us will have more time on their watch? I put it to you that the one who reaches the future first will have less time on their watch (that means me).
I agree that if we were worried about who is able to say 5 minutes have elapsed on their watch first, then that will be you. If we both turn off our machines when five minutes have elapsed on our watches (inside the time machines), you will have to wait around a while for me to turn my machine off, and will be able to say that your watch read 5 minutes first. But ... I will have gone further into the future than you.
Now, this was just an explanation, I am not suggesting that such time machines are possible. Just try to apply the same logic to the rocket and the two clocks. Relative to an observer not at rest relative to the rocket, the clock on the nose travels into the observer's future faster than the clock on the tail. The clock on the tail travels into the observer's future faster than the observer.
The observer also moves into the clocks' future faster than the clocks do.
This is where it gets less like semantics and more like something interesting ... can you model that? Not just wave it away, not just say "that's just relativity", not just show the mathematics on what must happen, but describe a model in which that is possible.
This also may be the point at which I get stomped on, so if you feel like coming back with "can you?" then I will have to politely decline.
cheers,
neopolitan
But as you point out, different observers have different "instants"...whose are you talking about above? If we talk about a given instant (line of constant t) in the rocket frame, then as seen in the outside observer's frame, the clock on the tail will intersect with this line before the clock on the nose. Maybe you're taking the opposite perspective, and considering a line of constant t in the observer's frame, and then pointing out that, in the rocket's frame, the clock on the nose will reach a given point on this line before the clock on the tail? If so let me know, this would help clear up my confusion about what you're trying to say (and if it is what you're saying, would you agree either perspective is equally valid?)
I don't think that's a good analogy, because no matter what frame you pick, the rate at which each clock is advancing forward in that frame will be identical, it's not like one is being "shunted into the future" faster, just that one has a "head start" of sorts.
Like I said, there's no difference in the rate no matter what frame you pick, so I would say "faster". But if my guess above is right, do you mean that in the rocket's frame at any given instant, the time on the nose-clock at that instant would be further in the outside observer's future than the time on the tail-clock at the same instant? In other words, if both clocks show a time of 3 seconds simultaneously in the rocket frame, we can note that in the outside observer's frame, the event of the nose clock showing 3 seconds happens further in the future than the event of the tail clock showing 3 seconds. So is that what you mean?
If so, I just want to note that even if we talk in this way, which clock is "further in the outside observer's future" depends on your choice of frame. We might take the frame of an observer who's moving relative to the first observer outside the rocket, but in the opposite direction as the rocket...in this new observer's frame, the time on the nose-clock at a given instant would be further in the first outside observer's past than the time on the tail-clock at the same instant.
As I said above, I think the problem with your analogy is that no matter which frame you choose both clocks tick at the same rate, and also that the question of which clock is further in the outside observer's future in the frame you're using will be different depending on the choice of frame (in the rocket's rest frame the nose clock will be, but in the frame of a third observer moving in the opposite direction relative to the outside observer the tail clock will be). But maybe I'm still not understanding what you're saying here, let me know.
We are discussing physics aren't we, not social work?
We have a rocket with two clocks and we have an observer who is not at rest relative to the rocket. If I want to know what it observed I expect to hear "I see a rocket in motion with two clocks on it, one on each end" not "I see some dorky physics guy observing me".
Of course I am discussing the observer's instant. Why is that so hard for you to grasp?
Yes, that is what I mean. See how even if the analogy is not perfect (I knew it wasn't by the way) it did help you to understand? More perfect and it would be too complex, and you would have been running around point out other errors and uncertainties rather than concentrating on the issue I wished to convey.
I guess I implied that you were willfully incomprehending so an implication here of stupidity on my part is fair enough. Your scenario is precisely the same as "what if the rocket was going backwards relative to the observer so that the tail was effectively the nose and the nose was effectively tail". Relabel nose and tail and we are back where we started, just as both of us expect. I am pretty sure that most of us understand that "nose" is the front bit and "tail" is the back bit. If you were thinking I had each part labeled permanently on the rocket so that the nose clock would behave the same way irrespective of the direction it traveled in relative to the observer then you did not read an earlier post properly.
Perhaps this is too confusing for you, but if you think about it, I am discussing a rocket which is departing from the observer - a rocket which is going forwards since the nose is further away than the tail. If you want to change the scenario so that the tail is further away than the nose, fine, then I agree the tail will reach the future before the nose and the clock on the tail will read a lower elapsed time than the nose - if the rocket is in reverse relative to the observer.
Which analogy are you referring to? The explanation analogy with the time machines? If so, they have done their job. Forget the analogy and go back to trying to understand what I said originally.
You can try to describe the model now as requested, if you like.
cheers,
neopolitan
If I've understood you correctly, you're discussing how the outside observer's instant is seen from the perspective of an observer on the rocket (i.e if we look at two simultaneous readings in the rocket-observer's frame, you're talking about which reading is in the future and which is in the past according to the outside observer's definition of simultaneity). I had been thinking you were talking about the perspective of an observer outside the rocket, and what time the two clocks show simultaneously in his frame. I think this is a pretty understandable confusion given that you didn't really spell out what you were talking about (DaleSpam also seems to have interpreted your comment as involving simultaneous readings in the rocket observer's frame rather than the rocket-observer's frame), so there's no need for condescending comments like "why is that so hard for you to grasp?"
No, it didn't. It was the previous comment about "instants" that helped me to understand (especially the comment 'An instant in the rocket's frame, in which clocks at the nose and the tail read the same, is similarly not an instant in the observer's frame', which clued me in that you might be talking about simultaneous readings in the rocket-observer's frame rather than the outside observer's frame), and you can see that I divined your meaning in the response to that earlier section. I hadn't even read the following paragraph when I fired off that response, and if your post had consisted only of the time travel analogy I don't think it would have helped me at all.
I have to say neopolitan, I consider your constant attempts to mind-read my motives (inevitably in uncomplimentary ways) really disrespectful. I meant no implication of stupidity here, the fact that I "want to note" something doesn't even imply that I think you would disagree with it, and it certainly doesn't imply I think you're stupid. Anyway as seen below, I think you were actually leaping to incorrect conclusions about what I was saying in that comment.
No, actually, it's a little more complicated. In your scenario, there have to be two observers whose frames we refer to--the first observer A who sees the rocket going forward, and a second B on board the rocket. Unless there's an error in my interpretation of your words, what you're saying is that if we look at readings on the two clocks which are simultaneous in the frame of B, then the reading on the nose clock has a greater time-coordinate in the frame of A than the time-coordinate of the reading on the tail clock in the frame of A. In my scenario, it's still true that the rocket is moving forward relative to A, but I'm introducing a third observer C who is moving in the opposite direction as the rocket in A's frame (so this observer C also sees the rocket moving forward, at an even greater speed than in A's frame), and saying that if we look at readings on the two clocks which are simultaneous in the frame of C, then the reading on the tail clock has a greater time-coordinate in the frame of A than the time-coordinate of the reading on the nose clock. This is an entirely different scenario from imagining that the outside observer A sees the rocket moving backwards, and then looking at readings on the two clocks which are simultaneous in the frame of an observer B on board the rocket, and noting that in this case if we look at two readings which are simultaneous in the frame of B, then the reading on the tail clock (which is now effectively the nose clock in A's frame) has a greater time-coordinate in the frame of A than the time coordinate of the reading on the nose clock (which is now effectively the tail clock in A's frame) in the frame of A.
Well, I'm sure you would agree with this, but for the rocket to be "going forward" that means the nose is further away than the tail when the rocket is moving away from the observer A, but it also means the nose is closer than the tail when the rocket is moving towards the observer A (and at some moment they will be equidistant as the rocket passes A). Whether the rocket is moving towards A or away from A makes no difference to our statements about simultaneity, as long as the rocket is moving forward in both cases.
Again, that wasn't what I was suggesting. I was still suggesting a scenario where the rocket was going forward relative to A (if the rocket was moving away from A, the nose would be further than the tail), but where instead of then looking at readings of the rocket's clocks which occur simultaneously in the frame of an observer B on board the rocket, we instead look at readings on the rocket's clocks which occur simultaneously in the frame of an observer C who is moving in the opposite direction as the rocket in A's frame, so that in C's frame the rocket is moving forward at an even greater speed than in A's frame. In this case the reading on the tail clock will be "further in the future" in A's frame than the reading on the nose clock (where again, the two readings we're talking about were chosen to be simultaneous in C's frame).
As an example, suppose the rocket is 10 light-seconds long in its own rest frame, and in A's frame its moving forward at 0.6c, so in A's frame the tail clock's reading is ahead of the nose clock's reading by 6 seconds. Now choose an observer C who sees the rocket moving forward at 0.8c, so in C's frame the tail clock's reading is ahead of the nose clock's reading by 8 seconds. Pick two readings which are simultaneous in C's frame, like the tail clock reading 10 seconds and the nose clock reading 2 seconds. In A's frame when the nose clock reads 2 seconds, the nose clock reads 8 seconds and won't read 10 seconds until a later time, so the event of the tail clock reading 10 seconds is "further in the future" in A's frame than the event of the nose clock reading 2 seconds. In contrast, if we picked two readings which were simultaneous in the frame of the observer B on board the rocket, like the tail clock reading 3 seconds and the nose clock reading 3 seconds, then we'd find that the event of the nose clock reading 3 seconds is "further in the future" in A's frame than the event of the tail clock reading 3 seconds.
OK, but then I don't really understand what you were asking with this earlier comment that I was responding to:
What is the difference between a "model" and just showing the "mathematics on what must happen" according to relativity? In physics when I hear the word "model" I just interpret it to mean a mathematical model, do you mean something different? And when you say "describe a model in which that is possible", what did you mean by "that" if you weren't referring back to your earlier picture involving one guy moving into the future faster than the other? Describe a model in which what is possible?
Ok, sorry if I offend. I am merely a little frustrated.
I only ever talked about one observer. I never invited a second one (on the rocket) and certainly not a third (alternatively one relative to which the rocket is moving backwards or one relative to which the rocket is moving forwards but twice as fast as the first observer perceives).
I just don't quite understand how you are helping by adding more and more observers.
I accept that it is confusing if you add more and more observers, but that with time and patience you can work out what each observes.
Can we dispense with the third observer at the very least. I am not sure what you want to prove with that observer. I admit that I misread it at first. But I understand less now what your intention is with the introduction of that observer than I did when I thought you wanted to somehow make the rocket appear to go backwards.
I am going to leave this for a while, because I do find it rather frustrating.
neopolitan
But in relativity talking about "observers" is basically just shorthand for talking about what's true in different frames, the actual presence or absence of biological humans at rest in a particular frame doesn't affect your actual problem. It seems to me that your argument depends critically on using the definition of simultaneity in the frame where the rocket is at rest as well as the definition in the frame where it's moving; as far as I can tell what you're saying is that if we take two simultaneous readings in the rocket's rest frame B, then of those two readings, the one on the nose will be further ahead in time in the frame where the rocket is moving A (the one where you want the 'observer' to be) then the one on the tail. Is this wrong?
If not, my point in introducing a third frame C was just to show that the nose-reading being further in the future than the tail-reading in the frame A of the "observer" depends critically on the fact that you picked two clock readings which were simultaneous in the rocket's rest frame B; if you instead picked simultaneous clock readings in another frame C moving in the opposite direction relative to A (still talking about the two clocks on board the rocket, and without changing the motion of the rocket), then out of these two readings, the one on the tail will be further ahead in time in A's frame than the one on the nose. Assuming you agree with this point, then that was my only reason for introducing the third frame C, we don't have to discuss it further.
  • · Replies 38 ·
  • · Replies 50 ·
  • · Replies 20 ·
  • · Replies 127 ·
10K
  • · Replies 51 ·
  • · Replies 36 ·
  • · Replies 17 ·
