Integration using Trig Substitution
The problem involves evaluating the integral \(\int \frac{\cos x \, dx}{\sqrt{1 + \sin^{2} x}}\), which falls under the subject area of calculus, specifically integration techniques involving trigonometric substitution.
  • Participants discuss using trigonometric substitution and explore different substitutions, such as \(y = \sin(x)\) and \(a \tan(\Theta) = y\). There are attempts to simplify the integrand but some participants express confusion about returning to the original equation. Others suggest using Pythagorean identities to aid in simplification.
There is an ongoing exploration of various substitution methods, with some participants suggesting that a standard integral form may be reached. However, there is no explicit consensus on the best approach, as participants are weighing the merits of different methods and expressing uncertainty about the necessity of using trigonometric identities versus simpler forms.
Participants note that the problem may require adherence to specific expressions and identities related to trigonometric substitution, which adds complexity to the discussion.
Brickster
[tex]\int \frac{cosx dx}{\sqrt{1 + sin^{2}x}}[/tex]
Expression: [tex]\sqrt{a^{2} + x^{2}}[/tex]
Substitution: x = a*tan[tex]\Theta[/tex]
Identity: 1 + tan[tex]^{2}\Theta = sec^{2}\Theta[/tex]
I have tried using Trig Substitution, but I end up getting an equation much like the one I started only it contains secants and tangents instead of cosine and sine. For some reason I only see a circular route that would just take me back to the original equation.
Try the substitution y=sin(x). That should then put the integrand in a familiar form.
as in changing the bottom from 1 + (sinx)^2 to 1 + y^2 ?I can get to:
[tex]\int \frac{sec^{2}\Theta d\Theta}{\sqrt{1+tan^{2}\Theta}}[/tex]
But after that it makes no sense, I just get back to the original equation when I sub. again.
After y=sin x, and then a tan theta = y, you should have the same integrand with a plus sign, not a minus. Then use the Pythagorean identities to simplify the square root.
So I should end up with:
[tex]\int sec\Theta d\Theta}[/tex]
Correct?
then I would get ln [tex]\left| sec\Theta+tan\Theta \right|[/tex] + C
If you use the substitution I suggested, then you end up with [tex]\int\frac{dy}{\sqrt{1+y^2}}[/tex]. This is a standard integral, is it not?
Yes, I'm fairly certain that is a standard integral, and it comes out to:
[tex]sin^{-1}y + C[/tex]
But I'm also fairly certain that I am supposed to solve this problem using the expression, substitution, and identity when I do the trig sub. Maybe I am overcomplicated the problem and should just stick to the arcsin answer, Gib Z's method seems to be the one I'm after
[tex]sin^{-1}\frac{y} + C[/tex]
Close; the solution is [tex]\sinh^{-1} y +C[/tex]
My mistake, you're right. Thanks!
It's always nice to know alternative methods, because we can know express the inverse hyperbolic sine function in terms of the natural logarithm =] Which we could have also done more directly, but o well!
  • · Replies 22 ·
  • · Replies 34 ·
