Register to reply
Does any one know how to make a stress strain diagram in MS excel?
by Saladsamurai
Tags: diagram, excel, strain, stress
Share this thread:
Saladsamurai
#1
Feb9-08, 05:22 PM
Saladsamurai's Avatar
P: 3,016
Or know of any good tutorials?
This is a PAIN to do by hand.
Phys.Org News Partner Science news on Phys.org
Mysterious source of ozone-depleting chemical baffles NASA
Water leads to chemical that gunks up biofuels production
How lizards regenerate their tails: Researchers discover genetic 'recipe'
TVP45
#2
Feb9-08, 06:18 PM
P: 1,127
Quote Quote by Saladsamurai View Post
What exactly are you doing? Do you already have values? Why don't you just use the published ones?
Saladsamurai
#3
Feb9-08, 06:48 PM
P: 3,016
Yes. I have the values. I am just having a hard time figuring out how to enter and plot the values? I tried using line chart, but it seems to be graphing a line for both strain and stress instead on just one line for stress VS strain.
What do you mean "published ones"?
TVP45
#4
Feb9-08, 07:00 PM
P: 1,127
Most materials have published stress-strain charts.
Anyway, back to Excel. What other choices do you see for plot type?
Saladsamurai
#5
Feb9-08, 07:09 PM
P: 3,016
These are all of the line charts, all the others are just pie, bar, scatter plots...
Saladsamurai
#6
Feb9-08, 07:23 PM
P: 3,016
I think the scatter plot will do it, I just can't figure out how to change the scaling of the axes.
I got it to look like this:
Now I just need to get the blown up graph for the elastic range. I want to make it show up underneath the main curve with its own scaling just like a standard stress-strain diagram
z-component
#7
Feb9-08, 08:40 PM
z-component's Avatar
P: 483
You can change the max/min values right on the open dialog box in your image. See the minimum and maximum fields? Nice curve, by the way.
Saladsamurai
#8
Feb9-08, 08:45 PM
P: 3,016
Right. The only thing is, I want to get a second curve in there. I want to expand (blow up) the linear portion of the graph. . .
FredGarvin
#9
Feb10-08, 01:40 PM
Sci Advisor
FredGarvin's Avatar
P: 5,095
Put in your second set of data. Highlight it and press control-c. This will put the data in your clipboard. Click once on your graph. Go to the edit menu and select paste special. You should the get a dialog box that will ask you if you want to paste it as a new series of data. Say yes. This will put the data on the same chart. However, you must click on either of the data sets and right click. Select format data series. There should then be a tab labelled Axis. Select it and there will be a selector box that says Primary or Secondary. Select secondary to put it on the other axis. You can then format the range of that axis separately.
Register to reply
Related Discussions
Stress-strain diagram using deformation ? Engineering, Comp Sci, & Technology Homework 2
Finding the max shear stress at a point on a plate (with a hole) Classical Physics 1
Stress vs. Strain Engineering, Comp Sci, & Technology Homework 2
Stress-strain diagram Introductory Physics Homework 0
Stress strain Engineering, Comp Sci, & Technology Homework 2
