Another 'Does this series converge?'
  • Thread starter Thread starter Mattofix
    Series
The discussion revolves around the convergence of the series defined by the sum from n=1 to infinity of n!*2^n*n^(-n). Participants are exploring the application of the ratio test to determine the behavior of the series.
  • Participants suggest using the ratio test and discuss simplifying the series. There are attempts to clarify the limit calculations involved in the ratio test, with some questioning the steps taken to arrive at the limit of 2/e.
The discussion includes various interpretations of the ratio test results, with some participants asserting different conclusions about convergence and divergence. There is ongoing clarification of the calculations and assumptions made in the process.
Some participants express uncertainty about the simplifications and limits involved in the ratio test, indicating a need for further exploration of the mathematical reasoning behind their conclusions.
Mattofix
The sum from n=1 to infinity of n!*2^n*n^(-n)
not a clue.
try using the ratio test
you should first make the series simple:
The series you have is the same as: the sum from n=1 to infiniti of
n!*(2/n)^n "because n^(-n) is the same as 1/n^(n)).
Now you can use the ratio test:
take the limite as n approaches infiniti of [(n+1)!*(2/n)^(n+1)] / [n!*(2/n)^n ]
this limit becomes after simplifying:
limit as n approaches infiniti of (2n+2)/n
you can fact the n out and cancel it out with the n in the denominator to get:
limit as n approaches infiniti of 2+(2/n) which equals 2
so because 2 is grater than one, this series converges by the ratio test
No, when you simplify that ratio, you get 2(n/(n+1))^n, whose limit is 2/e. This is less than 1, so the series CONVERGES.
If you get 2 as the limit, the ratio test says that it DIVERGES.
(2n+2)/n
=n*(2+2n^-1)/n
so now you cancel out the n in the denominator with the one above it
you get:
2+(2/n)
when you take the limit as n approaches infiniti you get 2
how do you get this?
i know that (1 + c/n)^n -> e^c as n-> infin
but how do you get 2/e, well c= -1, but how do you get that?
Alright,
the series you have is n!*2^n*n^-n
this can be simplifyed to become:
An= n!*(2/n)^n
so An+1= (n+1)!*(2/n)^(n+1) "you just replace n by n+1
The ratio test says lim as n goes to infinity of An+1/An
which is the same as:
lim as n aprroaches infiniti of [(n+1)!*(2/n)^(n+1)] / [n!*(2/n)^n]
(n+1)!/n! equals n+1 and (2/n)^(n+1)/(2/n)^(n) equals 2/n
so the limit becomes:
lim as n approaches infiniti of (n+1)*(2/n)
lim as n approaches infiniti of (2n+2)/n
you can factor out the
The limit becomes:
n*(2+2*n^-1)/n
cancel out the n in the denominator and the one above it:
now you have the limit as n aprroaches infiniti of 2+(2/n) or 2+2*n^-1
which equals 2
torresmido said:
Alright,
An= n!*(2/n)^n
The limit becomes:
n*(2+2*n^-1)/n
which equals 2
Wrong again. Not, "An+1= (n+1)!*(2/n)^(n+1)". An+1=(n+1)!*(2/(n+1))^(n+1). Mattofix, can you correct the rest? As masnevets has already pointed out, the ratio test limit is 2/e.
yeah - i know that torresmido is wrong.
i have handed it in already though.
but i got to 2(n/(n+1))^n and then didnt know how to get 2/e as the limit.
thanks for your help guys
Write it as 2/((n+1)/n)^n=2/(1+1/n)^n. Look familiar now?
Sorry guys ... I see my mistake now.
the limimit is 2/e so the series diverges by the ratio test
You mean converges, right? 2/e<1.
oh - yeah, now it makes sense
  • · Replies 22 ·
