Why did the ice pieces stick together in water?
The phenomenon of ice pieces sticking together in water occurs due to the temperature differential between the ice and the surrounding water. When ice, which is below 0 degrees Celsius, is placed in water, the water can flow into the thin spaces between the ice pieces. This water quickly freezes, causing the ice pieces to bond together. This process is a direct result of the thermodynamic principles governing phase changes in water and ice.
  • Understanding of thermodynamics and phase changes
  • Knowledge of the properties of water and ice at various temperatures
  • Familiarity with the concept of heat transfer
  • Basic principles of molecular interactions in solids and liquids
  • Research the thermodynamic principles of phase transitions in water
  • Explore the effects of temperature on the physical properties of ice
  • Learn about the molecular structure of ice and water
  • Investigate the concept of supercooling and its effects on ice formation
This discussion is beneficial for students of physics, chemistry enthusiasts, and anyone interested in the scientific principles behind everyday phenomena involving water and ice.
kthouz
Hey check this out:
I put 3pieces of ice in a glass and then put water. I left the glass alone for about 5minutes. When i came back i realized that those 3 pieces of ices were a bit sicked one another.
So what should be the scientific explanation?
Chemistry news on Phys.org
The ice was initially of lower temperature than 0 centigrade. The ice pieces were in contact but water could flow between or into the contacting regions and solidify owing to the ice being colder than 0 centigrade. The aqueous filled space between the ice pieces is very thin and can solidify quickly.
  • · Replies 23 ·
15K
10K
  • · Replies 30 ·
