Solve Resistance Question: Find R of Resistor with 60W Lamp & 120V
  • Thread starter Thread starter arod2812
    Resistance
The discussion centers on calculating the resistance (R) of a resistor in series with a 60W lamp connected to a 120V source, where the voltage across the lamp is 35V. The correct approach involves using the power formula P=IV to find the current through the lamp, which is 60W/35V = 1.714 A. Subsequently, the resistance of the resistor is calculated using R=(V_source - V_lamp)/I, resulting in R=(120V - 35V)/1.714A, which equals approximately 49.5 ohms. The initial calculation of 170 ohms was incorrect due to a misunderstanding of the current through the lamp.
  • Understanding of Ohm's Law
  • Familiarity with electrical power calculations
  • Basic knowledge of series circuits
  • Ability to manipulate algebraic equations
  • Study Ohm's Law and its applications in circuit analysis
  • Learn about power dissipation in resistors and lamps
  • Explore series and parallel circuit configurations
  • Practice solving electrical circuit problems involving multiple components
Students studying electrical engineering, hobbyists working on circuit design, and anyone seeking to understand the principles of series circuits and power calculations.
arod2812
A 60-W lamp is placed in series with a resistor and a 120-V source. If the voltage across the lamp is 35-V, what is the resistance (R) of the resistor?
I am pretty sure I am using the right equation, but I am not getting the right answer. What am I doing wrong?
P=IV --> 60W=I(120V) --> I=-.50 A
R=V/I --> (120V-35V)/.5A = 170 ohms (this is what I calculated but it isn't the right answer)
Voltage across the lamp is 35V, so that in P=VI,V=35 for the lamp.
Current through the lamp = P/V =60/35
A lamp rated as 60W would dissipate 60W when connected directly to the 120V supply -- when you add a resistor in series with it, it no longer dissipates 60W.
- Warren
  • · Replies 31 ·
  • · Replies 23 ·
  • · Replies 18 ·
