| Thread Closed |
[SOLVED] The speed of a bullet may be determined by allowing the bullet to pass throu |
Share Thread | Thread Tools |
| Feb11-08, 08:24 PM | #1 |
Hello! I am new here and this is my first time posting...I am working on a physics problem and I have been stumped on it for a while now. Any hints would be greatly appreciated.
1. The problem statement, all variables and given/known data The speed of a moving bullet can be determined by allowing the bullet to pass through two rotating paper disks mounted a distance d apart on the same axle. From the angular displacement Δθ of the two bullet holes in the disks and the rotational speed of the disks, we can determine the speed v of the bullet. Find the bullet speed for the following data: d=80 cm, ω=900 rev/min, and Δθ=31º. 2. Relevant equations My initial thought was that I would need to use the rotational kinematics formulas in some way or another: 1. ω = ω(initial) + αt 2. θ = θ(initial) + 1/2(ω + ω(initial))t 3. θ = θ(initial) + ω(initial)t + 1/2αt^2 4. ω^2 = ω(initial)^2 + 2α(θ - θ(initial)) to somehow get t, and then use the horizontal displacement over t to find v, the velocity of the bullet. 3. The attempt at a solution Some of my thoughts: I do not know what alpha, the angular acceleration is, so I cannot use it in order to find t. This rules out equations 1, 3, and four, leaving me with equation 2 to work with. Only one angular velocity was given in the problem, so the omegas in the formula confuse me, and I'm not sure if I need to use the same number for omega initial and omega final, or if I am supposed to assume constant angular velocity at all. If so, I think I can use 0 as theta initial and the 31 degrees as theta final to find t. If this is in fact the correct way to approach this problem (I have searched the chapter in the book and can't seem to find another approach), the last thing on my mind is the issue of radians and degrees. Should I change every aspect of the problem to radians, or to degrees? My initial impression was radians, but from the way I'm looking at it, I'm not sure if it would make a difference, or if there is a correct way to do this. I am again assuming that the velocity remains constant, so that is how I can find it, by dividing d by time. ANY hint or small tip in the right direction would be greatly appreciated. Thanks ahead for any help. |
| Feb11-08, 09:02 PM | #2 |
| Feb11-08, 09:12 PM | #3 |
Try to understand this: (my english is poor, sorry for that)
The first disc rotated by 31 degrees in the same time as the bullet took to travel 80 cm. omega of disc(which will be constant) =900x(2xpi)/60 rad/sec. (pi=3.14) convert 31 degrees into rad by multiplying by (pi/180). = 31x (3.14/180) time taken by disc to rotate 31 degree = (31x(3.14/180) / omega) seconds this time =0.80/v. ____________________________________ I may be wrong....... |
| Feb11-08, 09:23 PM | #4 |
Thanks so much for the help! Here's what I did and how I got it:
First converted d into meters, 80 cm = 0.80m Converted omega into rad/s, 900 rev/min(1 min/60 s)(2pi/1 rev) = 94.2 rad/s Converted degrees into radians (like you said), 31 degrees(pi/180 degrrees) = 0.541 rad Then I used equation 3 from above...theta initial and alpha are both zero, so I just took 0.541 rad / 94.2rad/s to get 5.74x10^-3 s for t (0.00571 s) Then I took 0.80m/0.00571s = 139 m/s How does this look, and thanks so much for the help! |
| Feb11-08, 09:49 PM | #5 |
Again, I'm pretty sure that it looks right.
| Feb12-08, 12:50 PM | #6 |
Bump...sorry if we're not allowed to bump.
| Feb12-08, 01:46 PM | #7 |
Recognitions:
do an order of magnitude estimate
disks 1m apart, rotate in 1/15 seconds hits are 1/6 of a turn apart = 0.01s so answer is roughly 100m/s You have made things slightly complicated for yourself with radians etc. That isn't actually realistic for anything other than a musket ball - but you never know how accurately the question was set! |
| Feb12-08, 04:57 PM | #8 |
Thanks...but is it still suitable, the way I did it in radians? So far, everything we've learned in class has been in radians for objects rotating about a fixed axis.
| Feb12-08, 05:24 PM | #9 |
Recognitions:
A bit unnecessary but the right answer.
| Feb12-08, 05:38 PM | #10 |
OK...thank you so much for the assistance, I really appreciate it.
| Thread Closed |
| Thread Tools | |
Similar Threads for: [SOLVED] The speed of a bullet may be determined by allowing the bullet to pass throu
| [SOLVED] bullet speed and thermal equilibrium | Introductory Physics Homework | 1 | ||
| [SOLVED] Horizontal Speed of bullet fragment | Introductory Physics Homework | 15 | ||
| Max bullet speed | General Physics | 3 | ||
| A bullet droppet and a bullet fired | Introductory Physics Homework | 4 | ||
| Max bullet speed | General Physics | 0 | ||
