Something like the Monty Hall Dilemma
  • Context: Graduate
  • Thread starter Thread starter Somefantastik
    Monty hall
The discussion revolves around a probability problem involving three prisoners and a jailer, similar to the Monty Hall dilemma. Participants explore the implications of the jailer's reasoning regarding the probabilities of execution and release when one prisoner seeks information about the others' fates. The scope includes mathematical reasoning and conceptual clarification of conditional probabilities.
  • Some participants assert that the jailer's reasoning is flawed, arguing that knowing which prisoner will be freed does not change the probability of execution for the inquiring prisoner.
  • Others clarify the conditional probabilities involved, stating that if one prisoner is to be executed, the jailer must provide information about the other prisoner who will be freed, leading to specific probability assignments.
  • A participant notes the confusion in notation, suggesting a consistent labeling of prisoners to avoid misunderstanding.
  • There is a discussion about the implications of the jailer's refusal to divulge information and how it affects the perceived probabilities of execution for the prisoners.
  • Some participants express uncertainty about the calculations presented, particularly regarding the probabilities of the jailer's responses based on which prisoner is executed.
Participants do not reach a consensus on the jailer's reasoning or the correctness of the probability calculations. Multiple competing views remain regarding the interpretation of the probabilities and the implications of the jailer's actions.
There are limitations in the clarity of notation and the assumptions made about the jailer's behavior, which may affect the understanding of the problem. The discussion also highlights the dependence on how the prisoners are labeled and the implications of the jailer's choices.
Somefantastik
[problem]
Three prisoners are informed by their jailer that one of them has been chosen at random to be executed, and the other two are to be freed. Prisoner A asks the jailor to tell him privately which of his fellow prisoners will be set free, claiming that there would be no harm in divulging this information, since he already knows that at least one will go free. The jailer refuses to answer this question, pointing out that if A knew which of his fellows were to be set free, then his own probability of being executed would rise from 1/3 to 1/2, since he would then be one of two prisoners. What do you think of the jailor's reasoning?
[solution]
Let Ci be the ith prisoner will be executed. Ji be that jailor tells that the ith will be free. Suppose the 1st prisoner is asking. Then
P(Ci) = 1/3
P(J3|C2) = 1
P(J2|C3) = 1
P(J2|C1) = P(J3|C1) = 1/2
Compute [tex]P(C1|J2)[/tex] = [tex]\frac{P(C1 & J2)}{P(J2)}[/tex] = [tex]\frac{P(J2|C1)P(C1)}{(P(J2|C1)P(C1) + P(J2|C3)P(C3))}[/tex] = [tex]1/3[/tex]
By the same token P(C1|J3) = 1/3 => Jailor's reasoning is wrong.
I don't understand how the probabilities in red were computed.
Take P(J3|C2). This means that C2 will be executed. Therefore, the jailor has to free number 3 because there's no other choice - he's not going to free prisoner A in this scheme. So P(J3|C2)=1. The same applies to the next one. As for the last one, it's prisoner A to be executed, so each of the others will be released with probability 1/2.
Somefantastik said:
[problem]
[solution]
P(Ci) = 1/3
P(J3|C2) = 1
P(J2|C3) = 1
The notation is a bit confusing. You referred to the prisoners as "A", "B", and "C" but here they are being referred to as 1, 2, and 3. I'm going to call them "A1", "B2", and "C3"!Also remember that the jailor is certainly NOT going to tell A1 that he will be set free.
P(J3|C2) is the probability that the jailor tells him that prisoner C3 will be set free given that prisoner B2 will be executed. If prisoner B2 is to be executed, and the jailer will NOT tell A1 that he is going to be released, he MUST answer that C3 is going to be released: P(J3|C2)= 1.
If, instead, it is C3 who will be executed, and the jailer will NOT tell A1 himself that he is going to be released, then he MUST anwer that B2 is going to be release: P(J2|C3)= 1.
However, if it is, in fact, A1 himself who is going to be executed, then the jailer can answer either B2 or C3- and they are equally likely: P(J3|C1)= P(J3|C1)= 1/2.
That's not quite correctly stated. He is in fact going to free both prisoner C and prisoner A- he just isn't going to tell prisoner A that he is going to be freed!
Yes, poor wording on my part. It may not make any difference to the calculation, but it's a huge difference if you happen to be Prisoner A!
