How Do You Solve the Derivative of \(4x - x^2\)?
The problem involves finding the derivative of the function \(4x - x^2\). Participants are discussing the application of the difference quotient and exploring algebraic manipulations related to derivatives.
  • Participants are attempting to apply the difference quotient to derive the function. There are questions about the accuracy of the algebraic manipulations and the correct formulation of the limit definition of the derivative.
The discussion is ongoing, with participants providing feedback on each other's attempts. Some guidance has been offered regarding the algebraic steps needed to simplify the expression, and there is acknowledgment of potential mistakes in the original poster's calculations.
There is mention of a possible lack of familiarity with the Power Rule, which may impact the original poster's approach to finding the derivative.
kwikness
Find the Derivative Function of (4x - x[tex]^{2}[/tex])
using formula:
[tex] \frac{dy}{dx} = \frac{f(x + \Delta x) - f(x)}{\Delta x}[/tex]
[tex] \frac{4(x + \Delta x) - (-x^{2})}{\Delta x}[/tex]
[tex] \frac{4x + 4(\Delta x) + x^{2}}{\Delta x}[/tex]
Not sure where to go from here..
Let d = [itex]\Delta[/itex]x.
f(x+d) - f(x) = 4(x+d)-(x+d)^2 - 4x + x^2
which simplifies to (4 - d - 2x)d (you should derive this). The rest should be easy.
First of all, you mean
[tex] \frac{dy}{dx} = \lim_{\Delta x \to 0} \frac{f(x + \Delta x) - f(x)}{\Delta x}[/tex]
as what you gave is just the difference quotient
[tex] \frac{\Delta y}{\Delta x} = \frac{f(x + \Delta x) - f(x)}{\Delta x}[/tex]
Not sure how you got there in the first place. If I plug [itex]f(x) = 4x - x^2[/itex] into the formula you gave, I get
[tex]\frac{ [ 4(x + \Delta x) - (x + \Delta x)^2 ] - [4 x - x^2 ] }{ \Delta x }<br /> = \frac{ 4 x + 4 \Delta x - x^2 - 2 x \Delta x - (\Delta x)^2 - 4 x + x^2 }{ \Delta x}[/tex]
which has some terms you don't have. Now try again.
That's because you haven't finished the algebra! You have 4x and -4x in the numerator! You have -x2 and x2 in the numerator!
Exactly, and the -4x and -x2 just happen to be some of the terms kwikness is missing :smile:
But I'm leaving him some work.
Thanks, when I wrote it down I was missing a part of the equation. Gahhh! I always make stupid mistakes like that.
You could just have used the Power Rule, but I guess you haven't learned it yet.
  • · Replies 40 ·
  • · Replies 31 ·
