Find velocity of object dropped through hole in center of earth
The discussion focuses on deriving the velocity of an object dropped through a hole drilled to the center of the Earth, utilizing a first-order differential equation for velocity, v, as a function of distance, r, from the Earth's center. The solution involves applying Gauss' Law to determine the gravitational force acting on the object and subsequently solving the differential equation to find the object's speed at the center. The results are validated through conservation of energy principles, assuming uniform mass density throughout the Earth.
  • Understanding of first-order differential equations
  • Familiarity with Gauss' Law in gravitational contexts
  • Knowledge of conservation of energy principles
  • Basic concepts of uniform mass density
  • Study the application of Gauss' Law in gravitational fields
  • Explore methods for solving first-order differential equations
  • Investigate the implications of uniform mass density in gravitational calculations
  • Review conservation of energy in mechanical systems
Students in physics, educators teaching gravitational mechanics, and anyone interested in theoretical physics applications involving gravitational fields and motion through varying densities.
maddogtheman
[SOLVED] Find velocity of object dropped through hole in center of earth
1. Homework Statement
Suppose that a hole has been drilled through the center of the Earth, and that an object is dropped into this hole. Write a first-order differential equation for the object's velocity, v as a function of the distance r from the Earth's center (i.e., an equation involving dv/dr), and solve it to determine the speed the object achieves as it reaches the center of the Earth. Check this speed with the result you get from simple conservation of energy considerations. Consider the Earth's mass density to be uniform throughout. [Hint: recall Gauss' Law as it applies to the gravitational field of a spherically symmetric mass distribution.]
Welcome to PF,
What have you attempted thus far?
Solved it thanks
  • · Replies 18 ·
  • · Replies 51 ·
