How Is Horizontal Distance Calculated for a Golf Ball in Flight?
  • Thread starter Thread starter Lacy
    Component
The discussion revolves around calculating the horizontal distance traveled by a golf ball in flight, based on its speed as a function of time. The original poster presents a problem involving projectile motion, specifically focusing on the horizontal and vertical components of the ball's trajectory.
  • Mixed
  • Participants explore the relationship between the horizontal and vertical components of motion, questioning the use of various equations to determine maximum height and horizontal distance. There is discussion about the initial velocity derived from a graph and how it relates to the calculations.
Several participants provide guidance on the equations to use, with some clarifying the distinction between initial speed and initial vertical velocity. There is an ongoing exploration of different methods to arrive at the correct calculations, but no explicit consensus is reached on a single approach.
Participants note potential confusion regarding the equations used and the values derived from the graph. The original poster's attempts at calculations reveal a need for clarification on the correct application of kinematic equations in the context of projectile motion.
Lacy
[SOLVED] x and y component problem?
http://loncapa3.physics.sc.edu/cgi-bin/plot.png?file=dengjh_sc_1202847653_17793457_plot.data
u will need that graph to solve this problem
) A golf ball is struck at ground level. The speed of the golf ball as a function of the time is shown in the figure., where t = 0 at the instant the ball is struck. How far does the golf ball travel horizontally before returning to ground level? i found this to be 112m and it is right
What is the maximum height above ground level attained by the ball?
S = (1/2)*a*t^2
Looks like the ball travels for 4 sec. When the speed is minimum (that speed looks like 27.5 m/s to me) it has reached its peak so the vertical component of speed has gone to zero. All the remaining velocity is horizontal, 27.5 m/s. And that's the horizontal velocity,Vh, during the entire 4 seconds. So the horizontal distance h is found from
Vh = h / total time
Vertical distance: It took 2 seconds to return to the ground from that peak,
S = (1/2)*a*t^2
now i tried using the equation but it didnt work. can someone point me to the right directioin
Welcome to PF Lacy,
Your URL is broken.
thank you i fixed it
The reason it didn't work is your equation is incomplete. The full equation is,
[tex]x = x_0 + v_0 t + (1/2) a t^2[/tex]
Where x0 is the initial displacement (in this case zero) and v0 is the initial velocity.
now I am trying to find max height would i use y=volt-.5at^2
would this be correct
y=34(2)-(4.9)(4)
48.4
Correct, where a = 9.81m.s-2 :approve:
y=34(2)-(4.9)(4)
48.4
How did you determine the initial velocity?
i looked on the graph and it started at 34m/s
i also got this equation but its different from the first one
you rearrange y-yo = Vosin(theta)t-
1/2gt^2 so that sin(theta) = (1/2gt^2)/Vo. Once you have
sin, plug in the variable in the y-yo = Vosin(theta)t-
1/2gt^2 formula.
which way do i do it I am confused
That is the initial speed, not the initial [vertical] velocity. However, you know the horizontal velocity (112/4) and the speed, therefore you can easily calculate the initial vertical velocity.
y=28(2)-(4.9)(4)
alright now i got 36.4 is this right
where vo=28 and t=2
Hootenanny said:
[...]However, you know the horizontal velocity (112/4) [...]
White space
would this be it
vo=.5at^2
where a=9.8 t=2
so vo=19.6m/s ?
You've use the wrong equation, but got the correct answer. The correct method would be as follows,
[tex]v = v_0 + at[/tex]
At maximum height [itex]v=0[/itex], hence,
[tex]v_0 + at = 0 \Rightarrow v_0 = -2g = 19.6 m.s^{-2}[/tex]
alright i got the right answer THANK YOU for all the help hootenanny :)
A pleasure Lacy :smile:
If you'd be so kind to mark the thread as 'solved' (look for "Thread Tools" in the top right-hand corner of the thread) that would be great.
  • · Replies 38 ·
