Hi , i have problems to learn recurtion
  • Thread starter Thread starter transgalactic
    Hi
The discussion revolves around understanding recursion, particularly in the context of coding subsets in Java. Participants explore the logic behind recursive functions and their application to set theory.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant expresses difficulty in grasping the logic of the subsets code related to recursion.
  • Another participant identifies that the example is related to set theory and suggests that recursion should terminate on the empty set.
  • A hint is provided regarding the function's operation on the empty set and how it can recursively find subsets from a given set.
The discussion does not appear to reach a consensus, as participants are still exploring the concepts and logic involved in recursion and subsets.
There are indications of missing clarity on the underlying logic of recursion and its application to subsets, as well as potential assumptions about familiarity with set theory.
transgalactic
i have this question which are femiliar to the
codes which we learned in class like subsets
but when i try to looks on the subsets code
i can't see the logic of it
how do i understand it??
Technology news on Phys.org
Langauge what, that is in ?
java
Sounds like your are learning recursion and the example you are using is taken from set theory, namely sets and subsets.
Hint: let your recursion terminate on the empty set.
if your function
f(S{})
works on sets, S{},
recognises the empty set {}, and
can find subsets from S{}, then
for every subset Si{} in S{} you can
call f(Si{}).
  • · Replies 133 ·
14K
  • · Replies 16 ·
