| Thread Closed |
Linear algebra, prove matrix inverse proof flawed |
Share Thread | Thread Tools |
| Feb13-08, 03:41 PM | #1 |
Theorem: Every square matrix which has a right inverse is invertible. More precisely: let A [tex]\in[/tex] M[tex]_{}nxn[/tex] (R) and suppose there is a matrix B[tex]\in[/tex] M[tex]_{}nxn[/tex] (R) such that AB = I[tex]_{}n[/tex]; then we have BA=I[tex]_{}n[/tex] as well. The object of this exercise is to explain why the following proof is flawed: Proof: Let G be the set of all matrices in M[tex]_{}nxn[/tex] (R) which have a right inverse in M[tex]_{}nxn[/tex] (R). Then G together with matrix multiplication is a group. Now proposition 1.3(b) implies the theorem: Proposition 1.3b: Let G be a group G, GxG[tex]\mapsto[/tex]G (a¦b) [tex]\mapsto[/tex]axb [tex]\forall[/tex]a,b,c[tex]\in[/tex]G, (a*b)*c = a*(b*c) [tex]\exists[/tex]e [tex]\in[/tex]G [tex]\forall[/tex] a[tex]\in[/tex]G, e*a=a=a*e a'*a=e [tex]\forall[/tex]a [tex]\in[/tex]G [tex]\exists[/tex] a'[tex]\in[/tex]G, a*a' = e For any a[tex]\in[/tex]G There exists precisely one right inverse a' and this is also a left inverse of a. We write a[tex]^{}-1[/tex] for the inverse of a. Proof of proposition 1.3b: Let a' be a right inverse of a (a'*a)*(a'*a)=a'*(a*(a'*a)) by associativity =a'*((a*a')*a) =a'*(e*a) because a' is a right inverse of a =a'*e because e is an identity element Let b be a right inverse of c:=a'*a c*b =(c*c)*b =c*(c*b) by associativity =c*e since b is a right inverse of c =c because e is an identity element Hence a' is a left inverse of a Note: proposition 1.3b is what is given in the lecture notes. 2. Relevant equations 3. The attempt at a solution Does this have something to do with matrix multiplication being associative and distributive but not always commutative? |
| Feb13-08, 03:48 PM | #2 |
Sorry, i can't seem to get latex to work here, it is making things superscript when they should be subscript and the arrows should be maps to.
| Feb13-08, 04:08 PM | #3 |
(1) It works better amongst regular text if you use [ itex ] instead of [ tex ].
(2) It works better still if you put an entire expression inside one pair of tags. (instead of putting a single symbol) |
| Feb13-08, 05:21 PM | #4 |
Is it that proposition 1.3b doesn't explicitly describe a group that is abelian, and for the theorem to be true it requires commutativity of the matrix and it's inverse, ie, that the right and left inverses are the same?
| Feb15-08, 05:41 PM | #5 |
G, G x G [tex]\rightarrow[/tex] G So applying proposition 1.3b to this case where we consider that all the elements in our G are only square matrices which have right inverses. So when applying matrix multiplication to two elements of our G, does it always produce another square matrix that itself has a right inverse ie. that it is invertible and of the original group G? If not, this might be the flaw?? Thoughts would be very appreciated, thanks. |
| Feb15-08, 06:11 PM | #6 |
On second thoughts, i think thr propsotion takes care of this fact because on the next line it says,
(a¦b) [tex]\mapsto[/tex]axb i think the ¦ sign might actually be a comma, i probably copied it wrong from the board. So i think this sentence is meant to mean that x assigns an element axb to the ordered pair a, b. There is another part to proposition 1.3b which i thought i didnt need to reproduce because the proof of a-1 also being a left inverse of a, had been shown. But here it is anyway because i can't think of anything else that is the flaw: suppose a''[tex]\in[/tex]G is another right inverse of a [tex]\Rightarrow[/tex]a'*(a*a'')=(a'*a)*a'' = a'*e=a' by associativity =e*a''=a'' I'm really out of ideas, anyone have any? |
| Feb15-08, 10:01 PM | #7 |
Ah, could this be the problem?
Let b be a right inverse of c:=a'*a c*b =(c*c)*b =c*(c*b) by associativity =c*e since b is a right inverse of c =c because e is an identity element Hence a' is a left inverse of a it says b is a right inverse of c, where c = a'*a but a'*a is not strictly defined to have a right inverse that resides within our G? |
| Feb16-08, 06:15 AM | #8 |
I haven't read through the entire thing but there is an obvious error right at the start:
| Feb16-08, 05:16 PM | #9 |
Also, it says that each square matrix of the set has a right inverse and so is a group because there is an inverse for each element. I hope i am missing a point there and that you are right because i just want to move on from this question lol, thanks again |
| Feb16-08, 08:31 PM | #10 |
If x[tex]\in[/tex]G, then y[tex]\in[/tex]G is an inverse element of x if x*y=e and y*x=e where e is an identity element of G. which is what we want to prove so can't make this assumption in doing so. This seems good to me? Thanks HallsofIvy, you guys are clever!! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Linear algebra, prove matrix inverse proof flawed
| Linear Algebra - Inverse of Matrices | Calculus & Beyond Homework | 2 | ||
| Prove help. rank of inverse matrix | Calculus & Beyond Homework | 1 | ||
| How to prove stuff about linear algebra??? | Introductory Physics Homework | 3 | ||
| How do I prove this? [Linear Algebra] | Introductory Physics Homework | 3 | ||
| Inverse Matrix Proof | Linear & Abstract Algebra | 2 | ||
