Acceleration, displacement, Kinematics Question
The discussion revolves around a kinematics problem involving acceleration and displacement. The scenario features Superwoman attempting to catch a free-falling parachutist before he reaches the ground, with specific parameters such as terminal velocity and time delays in action.
  • Mixed
  • Participants explore various equations related to motion, including those for displacement and acceleration. There is a focus on calculating the time it takes for the parachutist to reach the ground and how that impacts Superwoman's required acceleration.
Participants are actively engaging with the problem, providing suggestions and corrections to each other's calculations. There is an ongoing exploration of the correct time frame for Superwoman's acceleration, with some participants questioning the assumptions made in earlier calculations.
There is a noted confusion regarding the use of terminal velocity and the timing of Superwoman's response. Participants are also addressing the implications of initial conditions and the need to account for the time delay before Superwoman begins her descent.
ballerina_tee
[SOLVED] Acceleration, displacement, Kinematics Question
1. Superwoman is hovering above the ground when a person free-falling goes by her at a terminal velocity of 140 km/h. Unforunately, the parachute does not open. Forunately, Superwoman is around. If it takes her 1.9 s to realize the person is in distress, what mus her acceleration be if she is to catch the parachutist just before she hits the ground 1000 m below?
2. I think you use the equation d= v*t + 0.5 a*t^2 and rearrange for a which i got as a=d-v*t/ t^2
3. So I plugged in the numbers given in the question
a=d-v*t/ t^2
= (1000m) -(38.89) (1.9) / 1.9^2
=926.1/3.61
=256 m/s^2
That doesn't look right to me. The answer is supposed to be 3.53 m/s^2. I have no clue what I'm doing wrong! =( Please help! TIA.
I'm not sure why you're trying to find the acceleration of the parachutist. It makes no sense. The parachutist isn't accelerating, because he has reached terminal velocity. I don't understand why you have the time as 1.9 s.
What you need to do is figure out how much time it will take the parachutist to reach the ground starting from when he passes Superwoman. Once you know this, you can figure out what acceleration Superwoman needs to reach the parachutist before they get to the ground.
Also, you seemed to have dropped the 0.5 when you were rearranging your equation.
Thanks for your reply.
I did what you suggested and according to my calculations, I got 51.42 seconds.
I used this equation and solved for t.
d=1/2(v2+v1)*t
I just don't know what equations to use.
I got rid of the 0.5 by multiplying by 2. I forgot to add that.
a=d-v*t/ t^2 *(2)
This double what I think you should be getting. What you're using in your equation is the average velocity (which technically should have worked for this so I suspect you just made a math error). But anyway, the velocity isn't changing since it's constant, so you can just use v = d/t which gives t = d/v.
You can use the equation you had in your first post to find the acceleration of Superwoman. You know d, since Superwoman catches the parachutist just before he hits the ground. Since she was "at rest" when the parachutist went by, her initial velocity is zero, so your equation becomes simpler. What you have to figure out is t. Once you have that, you just solve for a.
So, if it takes the parachutist a certain time to reach the ground from 1000 m, and Superwoman waits 1.9 seconds before she starts moving, how much time is left before the parachutist hits the ground? This is what you need to find.
Ah, I feel so dumb.
So, to find t, you use t=d/v (1000/140)? I understand what the question is asking of me but I'm totally lost in what equations I should be using to solve the problem. The question isn't difficult but every time I try to solve, I get a number that is way off.
I'll try it again.
Okay, for the 10000th time lol,
I did t=d/v (1000m/38.89m/s) therefore t = 25.7 s
I plug that into the equation to find acceleration
a=d-v*t/ t^2 *(2)
= (1000m) - (0m/s)(25.7)/ 25.7^2 *2
= 1000/ 660.49 *2
= 1.5 X 2
= 3.02 m/s^2
Would this be correct?
The back of the textbook says the answer should be 3.53 m/s^2. Close Enough I guess.
Your time isn't quite correct. Remember that Superwoman waits 1.9 seconds before she starts moving. So if it takes the parachutist 25.7 seconds to reach the ground, and Superwoman waits 1.9 seconds, how much time is left? (i.e. how much time does Superwoman now have to get to the parachutist?) This is the time you need to find acceleration, it's NOT just the 25.7 s.
Nope. Your answer is not close enough, it's wrong. Fix the time and you will have it truly right.
Simple...25.7-1.9=23.8 seconds.
I used 23.8 instead of 25.7 into the equation and got 3.5 seconds
yay! Thank you!
You're welcome. :smile:
